Question about IBM (02R4087) Motherboard
I cannot see where on the motherboard to connect reset sw, power sw, power led and hddled. Also 2 red wires (1-5V and 2-5V); 2 white wires (1-D and 2-D), 2 blue wires (1+D aand 2+D) and 2 black wires (1ground and 2 ground) Motherboard IBM P4 2001 (also written FRU25P5090) Problem occurs when I'm replacing another motherboard with this one. Tried to find labelled connection points in vain
  • 4 more comments
  • David Nov 19, 2010
    Thank you - your solution was helpful. I take your point abvout the original IBM case. However, I need more info:
    1. Each of the connectors (reset sw, power sw, power led and hddled) has two wires (blue & white, yellow & white, green & white, red & white respectively) - which way round do they go? Is it always for each pair 'white on the right' or not? Can any harm be done connecting them the wrong way? I'm not trying anything until I know this ...
    2. You haven't told me anything about the other 4 sets of wires mentioned in the latter part of my question - where are they connected?
    Look forward to your response.
  • David Nov 20, 2010
    Thanks for the further input - sorry about the delay in replying - work and sleep intervened!
    The diagram and first picture show the connections I've made:
    1 2 3 4 5 6 7 8
    Touching pins 1 & 2 started the computer; so did touching pins 3 & 4; not the other 4 pins. So I decided to follow the order of colours of the cable and have connected white, blue, white, yellow respectively to pins 1 to 4. Now the computer starts when I press the front panel on/off button, and also when I press the reset button. They behave exactly the same.
    The only way to turn the computer off is to hold the on/off button (or reset button) for several seconds, or to pull out the power cable.
    The computer does not beep at all - it should, shouldn't it?
    Pictures 2 and 3 relate to the other wires - they do indeed come from the front panel USB ports. Do they perhaps connect to one of the other places that I've arrowed on the motherboard? What are those places for otherwise?
    Your previous reply is preceded by #; my response to your previous reply is preceded by **:
    # You either got faulty ram, cpu, video card, or mainboard if the machine is not powering on -- you don't get picture out of it.
    ** I’ve tried 3 different PC 100 RAM modules, and 1 PC 133 module separately, as well as the first 3 all together – same result: fan comes on, no beeps, no picture. Note: I’ve only just connected the video card now – before there was nothing connected, only the RAM in place. I have not got so far as connecting a HDD.
    # Try removing all the ram and power on, wait 20 seconds unplug, reseat one ram module and try powering on again
    ** I’ve tried this, and sadly it doesn’t help. But the computer beeps when there’s no RAM; pattern of beeps 1 3 3 1 – is that significant?
    # test all the components to confirm that they are OK
    ** I don’t know how to test the components – is there a simple way?
    Any other suggestions?
    My response to your previous reply is in red, bigger font:
    I've tried 3 different PC 100 RAM modules, and 1 PC 133 module separately, as well as the first 3 all together - same result: fan comes on, no beeps, no picture. Note: I've only just connected the video card now - before there was nothing connected, only the RAM in place. I have not got so far as connecting a HDD.
    I've tried this, and sadly it doesn't help. But the computer beeps when there's no RAM; pattern of beeps 1 3 3 1 - is that significant?
    I don't know how to test the components - is there a simple way?
    Any other suggestions? L
  • David Nov 22, 2010
    I haven't done anything over the weekend - busy with other commitments. I'll get back to you by tomorrow latest - thanks for you patience
  • IBM Master
  • 13,433 Answers
Its a special case, the connectors are above the 20pin main power cable.
the original ibm case would have a front panel connector that fits there, you have to use a screw driver, to find which of those pins turn the machine on and which reset it.
As for the leds, once you have found the power and reset, they will be on the remaining pins I cannot see where on the motherboard to connect - ekse_18.jpg
use a flat metal screw driver to connect two pins for a second to find out which two will start up the machine.
here is a pin out from another ibm mainboard
the connector looks like the same on as on your machine but it might be different don't be afraid to use your screwdriver.
Posted on Nov 18, 2010
  • 7 more comments
  • Ekse Nov 19, 2010
    on the power and reset it does not matter which way they are. To find out the polarity of the remaining connectors use a digital multimeter to measure the voltage from the pins when it shows + then you know whats + and whats -.
    As for the other wires I have no idea what they are. What or from where are they coming from?
  • Ekse Nov 19, 2010
    Oh I think I know what they are, they are the front panel USB connectors right? or where do they come from?
    They are connected to a USB header. But looking at the motherboard I don't see any USB headers.
  • Ekse Nov 20, 2010
    Hey,
    I don't see any pictures, email me directly at nikoht@gmail.com
    There is a problem with your machine, these wires being attached or not attached won't affect the computer starting up and turning off properly. the power button only connects two pins together to power on and does noting else. Reset also connects two wires together to pass along a reset signal.
    Try removing all the ram and power on, wait 20 seconds unplug, reseat one ram module and try powering on again.
    test all the components to confirm that they are OK.
  • Ekse Nov 20, 2010
    The connector in the bottom right of the mainboard next to the speaker and battery is the floppy drive connector.
    the one in the bottom left corner is something special.
    And then we have the power connectors at the top picture.
    When I was looking for the pinout of the powerconnectors I found this picture
    If you look at the bottom right "special" connector you see there are 3 jumpers connecting each 2 pins together.
    It is possibly a front panel audio connector + something else In one. or it might be a LPT port for a printer.
    This mainboard is far from standard connectors.
    This looks like the pinout of the power switch connector.
    '12345678'
    '--,__,--'
    Pin Colour Description
    1 Black HDD LED (Gnd)
    2 Yellow HDD LED (+ve)
    3 Green Power LED (+ve)
    4 Black Power LED (Gnd)
    5 Yellow Power Switch (Pair 1)
    6 Black Power Switch (Pair 1)
    7 Black Power Switch (Pair 2)
    8 Yellow Power Switch (Pair 2)
  • Ekse Nov 20, 2010
    the pinout is upside down. So you would connect the HDD led Black wire to the other end of the pins and to the one next to it the side of the led. Next the power led, its a and then the last one next to the power switches is ground for that led.
    So there is no reset switch, or then it works in some strange way that I've not seen before.
  • Ekse Nov 20, 2010
    Seems like I can post a plus sign ( + ) for some reason.
    the pinout is upside down. So you would connect the HDD led Black wire to the other end of the pins and to the one next to it the positive (+) side of the led. Next is the power led positive (+) pin and then the last one next to the power switches is ground for that led. So there is no reset switch, or then it works in some strange way that I've not seen before.
  • Ekse Nov 21, 2010
    did you send a comment? sorry I don't see it
  • Ekse Nov 21, 2010
    there is something wrong with this page, could you contact me via email for further assistance, also sent me the last comment(s) that you wrote here, I can't see a thing for some reason.
  • Ekse Nov 22, 2010
    Hey, something is wrong with this webpage and I can't see a thing, email me at nikoht@gmail.com
Idnt knw hw to cnnct power switch , hdd led ,speaker , reset.led+ , led- . pls help me by sorting out my problem.by full description . and photos of connecting cables.
The front wires are usually for power, hdd led. power button and reset button and sometimes extra usb ports and audio ports. All motherboards have a small section that has 8 to 10 grouped pins protruding that you can attach these wires to. The motherboard will diagrahm where the pins hsould go. For example the light for the hard drive wires are probably labeled "HDDLED" and there is two of them. One positive charge and and ground. On the motherboard, in the grouped pins there is a small label that goes:
''___'
'_____'
HDDLED
PWLED
It may look like this but in a different arrangement. What does this mean? Connect HDDLED to the top two pins. Doesn't matter which way the positive and ground go. And connect the power led PWLED to the bottom pins. Follow this for all the other labels.
Jul 05, 2011 | Computers & Internet
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
New tower
the symbol is there writen there on the board or abrivation you can follow it.. like( pwr sw/ Hddled/ spkr..
Apr 17, 2009 | MSI K8N Neo3-F Motherboard
Wiring front panel
if you go to this website
http://www.foxconnchannel.com/support/downloads.aspx
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
Apr 13, 2009 | Foxconn 760GXK8MB-RS Motherboard
MSI MS6511 jumpers overview?
Dear User here is confiruration.
1.Orange with + sign and orange is for HDD LED.
2. Green with +Sign and Green is for Power LED.
3.Red is for Power switch.
4. Blue of Black is for Reset switch
Mar 29, 2009 | Computers & Internet
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Hooking my Neo4 mobo back up.
Hi weeman105, case wire colors do vary from case to case. The most common case wire colors for negative are "white & black". All other colors like blue, green, red orange are most commonly "positive". The four pin connector with only the ends with wires is the internal speaker. Most boards use one set of pins where you hook everything up. The MSI K8N Neo4-F uses two separate motherboard pins, Front Panel Connectors: JFP1 & JFP2 as shown on the top page 2-19. Now that you know what color is positive & which is negative things should work out just fine.
Downloaded manual from MSI link: http://global.msi.com.tw/index.php?func=downloadfile&dno=4117&type=manual
If you run into any other troubles, just post & we'll go from there.
Good luck weeman105!
Mike
Sep 13, 2008 | MSI K8N Neo4-F Motherboard
MS-6378 ver 2 Motherboard fitted to my Time Computer
here it is your manual man
http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
I have a MSI too..great boards man..great boards..
fixya:)
bye
Feb 07, 2008 | MSI MS-6378 Motherboard
IBM (02R4087) Motherboard Logo
519 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
