Question about Kenmore Washing Machines
.how do you remove the water temp knob from this
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082873810/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts. Look at the section on the console.
Next see the following for how to release the console for access to the knobs / switches.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6b1f4b747e3f6a996f7dbf25034cd5f4
Also see the following Whirlpool / Kenmore Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Nov 14, 2010
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
How do you replace the timer in a Kenmore Washer Model 22622?
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=41610396bdeaf9d724c8d6b9910df259
Basic Whirlpool / Kenmore washers may use one of two different timers. See the following Whirlpool / Kenmore Service Manual
Assuming that you have the metal timer, You'll need to remove the timer knob. The easiest way is to hold the metal shaft that passes through the timer with a thin needle nosed pliers while un-screwing the knob.
Once the knob is off, it's a simple matter to unplug the connectors and remove the bolts holding the timer to the console.
Oct 21, 2010 | Kenmore 22622 Top Load Washer
Our kenmore 80 series (110.27812692) pooped out on us,... the motor and water pump needed replaced, so we bought a used kenmore 70 series (110.82872820) from a friend,... it works fine, but the control...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer(s):
Enter the model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Check the part numbers for both machines in the "Console" section.
Also see the following Whirl[pool Service manual for top load, direct drive washers.
Whirlpool top load, washers use one of two different timers. Depending on the timer the knob comes off differently.
For most, by holding the back of the timer shaft with a thin needle nosed pliers, the knob unscrews.
Sep 13, 2010 | Kenmore Washing Machines
Removeing timer switch knob
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
Jun 08, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite three-speed model 23014100 cycle control knob does not engage. How do you remove the knob?
First, see the Sears parts list for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23014100&pathTaken=partSearch
Then see the following for how to access the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=b73e90a0c05767e7bc74d80a72133966
Then see the Whirlpool / Kenmore Service Manual for these washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Beginning on page 20, you'll see that there are two types of timers and two ways to remove the knob.
Ours is a metal version and we found that you have to hold the back part of the metal shaft with a thin needle nose pliers in order to unscrew the knob.
Mar 30, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 600 with atc. water temp change
to change water temp when a cycle has started, pull the knob and reset the water temp, then move the dial to the desired setting. push knob in. resolved by trial and error!
Nov 05, 2009 | Maytag MAV5920E Top Load Washer
Removal of timer control knob on model 11025842400
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.25842400
Look at the control panel diagram and you should get a good idea of how the timer mounts.
With the basic top load, direct drive washer you should only need to remove the two screws located under the Trim End Caps to get access to the timer.
Sep 30, 2009 | Kenmore Washing Machines
Washer Doesnt Change Cycles
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This appears to be a timer / timer motor problem.
I'd alto look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
Sep 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore stackable water level
replace the water pressure switch it is non ajustable for insurance purposes
Apr 06, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
117 people viewed this question
Sal De
fordexpert
Robert Rankin
