I am trying to remove the detergent drawer from my ignis awf 592 washer dryer but am unable to, can you help?
3 Suggested Answers
  • 10865 Answers
SOURCE: WE HAVE AN ignis awf
Hello. Yes go to this site http://laundry.manualsonline.com/manuals/mfg/inglis_home_appliances/inglis_home_appliances_washer_product_list.html
J.
Posted on Aug 23, 2010
SOURCE: ignis washer/dryer AWF 592 does
WONT PUMP OUT WASTE WATER
Posted on Jan 04, 2011
How do I remove a pedestal drawer on and electrolux dryer
Hello friend, thanks for your inquiry!
I have researched that information for you and was unable to locate steps on how to remove the drawer from your pedestal. I would suggest seeking assistance from a professional for proper removal of the drawer. Hopefully this helps. -Matt
Sep 28, 2014 | Electrolux Washer/Dryer Laundry Pedestal...
I have a Bosch Exxcel front loading washer dryer and can't remove the detergent drawer to clean it, plus all washing cycles take well in excess of 2 1/2 hours to complete. Annoying
Normal wash loads do not take over one hour, but you have to set them on clean any stain option and it will take 107 minutes to wash.
It sounds to me like your washer needs servicing by a trained Bosch serviceman, because it should not do this.
Jun 26, 2017 | Bosch Washing Machines
Where would I find a replacement detergent drawer for a Zanussi 1055W washer/dryer?
http://www.ebay.co.uk/itm/Zanussi-Washing-Machine-Washer-Dryer-WDA1055W-Soap-Tablet-Detergent-Drawer/162547763876?hash=item25d89a0aa4:g:fsAAAOSwuxFYzP3t
Nov 06, 2017 | Zanussi WDA1055W Front Load Washer / Dryer
We have an Ignis awf 595 washer dryer. The machine is now beyond economical repair due to the drum shearing off its bearings. What would cause this to happen.
It would be caused by a corroded and then seized up drum bearing from a water seal leak, detergent is very corrosive and very quickly ruins the drum bearings.
Feb 06, 2012 | Maytag Washing Machines
Have a Miele W320, during the rinse part of wash cycle, water pours from underneath the detergent drawer. What can I do to stop this happening?
Is the drawer gunged up? Are you using too much detergent?
Remove the drawer, and clean it with hot water and a brush.
Look into the empty drawer slot for any blockages and remove.
Replace drawer, try pouring hot water into the open drawer to try to dissolve and clear any blockages.
Consider using a dosing ball and adding detergent to the drum.
Feb 18, 2010 | Miele W320 Front Load Washer
Front loader LG washer drawer for detergent is stuck won't open
Remove the top of the washer by removing the 2 retaining screws (phillips head) from the back of the unit & sliding the washer top back about 2" & pulling up. You will see a white detergent dispenser box with several hoses coming off the back in the left front of the unit (this box contains the detergent drawer). The lid to this box is held on by 8 pressure snap clips. You only need to release the 4 snap clips (3 large, 1 small at the rear) on the right side of the box (nearest the washer drum). Pull up on the right side of the lid while pulling out on the detergent drawer. It should come out normally. Do not reassemble until you read below, then reverse the steps to put the washer back together.
The problem will be the "softener" lid (blue). It will not be sitting down in the drawer assembly & will catch on the lid of the white detergent dispenser box. Simply remove the blue lid to avoid future jambs. It only serves to identify the fabric softener recepticle & it keeps fabric softener from splashing around when water enters the system. You may need to remove the entire detergent drawer periodically to clean (push down on the blue thumb indent inside the drawer to release it from the housing).
Hope this keeps you from drilling through the lid & ruining a $23 part, like I did.
Mar 26, 2009 | LG WD-16115FD Front Load Washer
Candy washer dryer 1400 spin cmd 146
try taking the soap dispenser draw out a give it a thorough clean inside and on the underneath of the drawer, then clean inside the machine where the drawer fits into. Sometimes a build up of detergent/softener can cause this.
I hope this helps
Jan 19, 2009 | Candy CNW136 Front Load Washer/Dryer
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
My detergent/softener pull out drawer is stuck!!! need help please!
This problem has just started popping up for me as well.  I believe that the problem is in the dispenser assembly where the drawer slides into.  You will have to pull hard and possibly may break a part of the plastic drawer to open it.  The dispenser assembly looks like it is bowing in the middle and jamming up against the dispenser drawer.  If it jams up like that, you may need to replace both the drawer and dispenser assembly togther.
Jan 06, 2008 | LG WM-3677HW Front Load Washer / Dryer
Washing Machines Logo
146 people viewed this question
Top Washing Machines Experts
