Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The water level overflows, the water will not shhut off when tub is full
  • 3 Answers
Need to change the water level switch
Posted on Nov 14, 2010
Maytag washer overflows
Remove and clean the water level tube that connects to the tub at one end and to the water level switch at the other end. Probably it is full of gunk.
May 28, 2017 | Maytag Washing Machines
My maytag washer is overflowing and won't go into
Hello there and welcome to fixya
This is a fairly common problems on these and other machines
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Please feel; free to post me back any comments on repair help or testing and removal ian installation if needed ill be glad to help you ok
Best regards Mike
Apr 09, 2012 | Maytag Washing Machines
WATER LEAKING FROM TOP WHEN START SPINNING,MY WASHER IS MAV 7600AWW,I CHANGED THE SEAL AND STIL LEAKING
Does this happen on any water level setting, or just on full load? If the machine is overfilling, the centrifugal force at the start of the spin cycle will throw the water up the sides high enough to overflow the top of the tub.
If the machine is overfilling just a little as I suggest, then the water level switch may be out of calibration or the water level hose may be partially clogged at the tub end. A quick fix in the latter case would be to disconnect the hose from the level switch and blow compressed air through it - it's a lot easier to get into the control panel than the side of the tub. A leaky hose would have a similar effect.
Feb 04, 2011 | Maytag MAV7600 Top Load Washer
Why would the water not shut off after its full?
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jan 05, 2011 | Washing Machines
MAH3000AWW FILLS WITH WATER ON WASH CYCLE BUT DOES NOT SHUT THE WATER OFF WHEN IT GETS FULL AND THEN LEAKS ON THE FLOOR. IT IS ONLY THE HOT WATER.
Here is a link to the water inlet valve.Here is a link to the water pressure switch.
Dec 31, 2010 | Maytag Washing Machines
Cold water does not shut off when washer fills - will over flow - hot water will shut off when washer is full ...
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jan 03, 2010 | Kenmore Washing Machines
Washer overflows after taking it apart
You may have missed something when putting it together. Take it apart again then check and properly install the following:
  1. Water inlet valve. It may not be able to shut completely when the electricity has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
Aug 23, 2009 | Kenmore Washing Machines
It overflows water because it doesn't spin it out on the spin cycle
Water-inlet valve
Water-level switch
Aug 21, 2009 | Washing Machines
Kenmore 80 series overflow
The water level switch senses the water level in the wash tub. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch. Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If the Tube is full of any water, remove it from the switch and replace it with a new one. Make sure that the new is correctly fitted to the switch.
The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle. If the tube replacement dose not improve the fill performance, and it continues to overfill, replace the timer.
Aug 04, 2009 | Washing Machines
Tub overflow
Remove the hose from the water level switch and blow air through it.
The water level switch air hose has a clog in it.
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
