Question about HP LaserJet P3005n Printer
Hp 3005dn wont start up all the way
Hi i have a hp 3005 dn printer and its not printing ,i had a dimm error dimm 0 and dimm 1. if i restart it i will print for a while but then stops. right now it doesnt load all the way when i restart it it gets to 80mb and just stops doing anything,
Help and ty
Tom
  • 2 more comments
  • ncarlton Oct 27, 2008
    I am experiencing a similar problem. The printer (hp 3005n) is failing to print as if there was a connectivity error. Upon restart it will either: print all documents previously sent to print and work properly for a few hours, or freeze up during reboot. Just a moment ago I pulled a mem test failure (dimm 0) but that is the first error since the problem started (2-3 days).
  • tjohnson83 Nov 17, 2008
    I get a similar error.
    Ram error, Replace DIMM 0
  • Anonymous Dec 20, 2008
    I want to kick the thing! plus Hp doesn't provide print support on the weekend!
  • Samickplayer Apr 14, 2009
    Same problem. Don't know how to fix.
The unit has a bad formatter. The formatter generally comes with memory installed Part# Q7848-31004. Part is super easy to change 6 phillips head screws and 3 cables (ribbon, 6 pin, and 3 or 4 pin power) Remove formatter cover the remove formatter door by opening then lifting up, then unplug the 3 cables then remove the 6 screws. Install is reverse of removal.
Posted on Jan 13, 2009
When i on the printer then "standard top bin full
Just check at upside where paper iscoming out after print, there you can see the two black flips to monitor the paper out position, this flag sensor got dusty this error apprears, remove back cover, you can observe left side this sensor, just clean it..
Aug 25, 2011 | HP LaserJet P3005 Printer
Error 49.4C02 on my hp laser jet 2420 dn printer. Haw can I fix that?
Printer error 49.4c02 may occur due to corrupted print queue. Just clear the queue and restart the printer and the error may be fixed. This would seem to work for most cases. If none of them are corrupted, check to see if any of them are in an uncommon size. Larger printings tend to result in this error as well. Check if it's the cause by clearing the queue then printing normal-sized documents instead. The error may also be caused due to complicated fonts as they are harder to read, especially if they're in color or written in a pdf format. If this is the cause of the error you can either stop printing such documents and update the drivers or firmware. The drivers may contain bugs which cause the printers to act this way, so updating them will solve the problem. for more help......
http://www.fixya.com/support/t6031482-hp_laser
Sep 10, 2010 | HP LaserJet 2420dn Printer
I got a 49.4c02 servicer error on my hp color laserjet 3800 printer
49.XXXXX ERROR
alternates with
To continue turn off then on
A critical firmware error has occurred.
1. Turn the printer off and then on.
2. Try printing a job from a different
program. If the job prints, try printing a
different file from the original program. If
the message appears only with a certain
program or print job, contact the
software vendor for assistance.
3. If the message persists with different
programs and print jobs, disconnect all
of the printer cables that connect to the
network or the computer.
4. Turn the printer off.
5. Remove all memory DIMMs or thirdparty
DIMMs from the printer. (Do not
remove the firmware DIMM in the lower
slot J1).
6. Remove the printer EIO card.
7. Turn the printer on.
8. If the error does not persist, install each
DIMM and EIO device one at a time.
Turn the printer off and then on again
after installing each device.
9. Replace DIMMs and EIO devices as
necessary.
10. Reconnect all of the printer cables.
11. If the error persists, replace the firmware
DIMM.
12. Replace the formatter
Regards
walid sayed
Cairo,, Egypt
walid_sayed@hotmail.com
Apr 02, 2010 | HP Office Equipment & Supplies
Printer prints multiple copies
go printer setting & select single Copy option,
when u send the copy select only one page.ok
Mar 15, 2010 | Computers & Internet
How do i print boh side in HP Laserjet 3005 DN
when you get ready your document for print go to printer properties and look in the tabs or menus the DUPLEX option when find select and press OK and later press PRINT
Mar 11, 2010 | HP Office Equipment & Supplies
Hi Iwill be glad to assist you:
Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
  1. Press Cancel Job to continue.
  2. If the problem persists, turn the printer power off and then turn the printer power on.
  3. It might be necessary to replace the specified DIMM. Turn the printer power off, and then replace the DIMM that caused the error.
Nov 05, 2009 | HP Color LaserJet 3500 Printer
53.10 Error "Shut off printer and turn back on"
The error points to your memory see below. the .10 indicates internal ram. You may need a formatter bd.
53.XY.ZZ PRINTER ERROR To continue press cancel job Description There is a problem with the printer memory. The dual inline memory module (DIMM) that caused the error will not be used. Values of X and Y are as follows: X = DIMM type 0 = read-only memory (ROM) 1 = random-access memory (RAM) Y = device location 0 = internal memory (ROM or RAM) 1 to 4 = DIMM slots 1, 2, 3, or 4 ZZ = error number 0 = unsupported memory 1 = unrecognized memory 2 = unsupported memory size 3 = failed RAM test 4 = exceeded maximum RAM size 6= invalid DIMM speed Action
Jan 20, 2009 | HP LaserJet 4350dtn Printer
Error 49.420c
first try to upgrade the firmware
second try a cold reset
if this dont work change the formatter
Aug 06, 2008 | HP LaserJet P3005 Printer
HP LaserJet P3005n Printer Logo
1,865 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
