I pressed the fn f11 key and now my monitor has gone on standby i cant seem to get a signal back to the monitor pressing the fn f11 key doesnt seem to get it back to normal
My samsung q320 will not detect my projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Jan 12, 2013 | Samsung Q32032P PC Notebook
I connected RGB from toshiba m45-s169 to tv. Had a signal but now cant get it back. Tried updating video driver. Help?
You can switch to an external monitor, TV or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Oct 23, 2012 | Toshiba Satellite M45-S169 Notebook
F buttons description
F1 - Security System
Press and hold the "Fn" key on the lower left-hand corner of your Toshiba keyboard.
Press the "F1" key to activate the security system.
Your laptop's screen will go blank so others can't see what you are working on or accessing.
Sponsored Links
Computer Repairs (Melb)
No Fix, No Fee. Same Day or Free. We Come To You - 1300 723 628
www.thepcdoctor.com.au/melbourne
Press any key or touch the touchpad to exit the security mode.
F2 - Power Save Mode
Press and hold the "Fn" key.
5
Press the "F2" key to activate the Power Save mode and make changes to how your laptop handles operating on battery or AC power.
6
Press "Fn" and the "F2" key again to exit the power save mode.
F3 - Standby Mode
7
8
Press the "F3" key to place your laptop in Standby mode.
The Standby dialog box will appear.
9
Verify you want to enter Standby mode. Press the power button on your Toshiba laptop to exit Standby mode.
F4 - Hibernation Mode
10
11
Press the "F4" key to activate the Hibernation mode and save whatever documents and files that are open to your hard drive.
12
Verify you want to enter Hibernation mode. Press the power button on your Toshiba laptop to exit Hibernation mode.
F5 - Active Display Device/F6 and F7 - Toshiba LCD Screen Brightness
13
14
Press the "F5" key to change your laptop's active display device from the laptop screen to an external monitor.
15
Click on the display configuration you want: displaying on both the laptop and external monitor; only on the laptop; only on the external monitor; or a specific screen resolution.
16
Press and hold "Fn" and "F5" to accept the new display settings. Press and hold "Fn" and "F5" again to return to your laptop's display only.
17
18
Press the "F6" key to decrease your laptop's screen brightness. Press the "F7" key to increase the brightness.
F8 - Wireless Connection/Bluetooth
19
20
Press the "F8" key to select the wireless Internet or Bluetooth connection you want to use.
21
Press and hold "Fn" and "F8" to make your selection. Release the keys to confirm your selection.
F9 - Touchpad Control
22
23
Press the "F9" key to enable your laptop's touchpad.
24
Press and hold "Fn" and "F9" again to disable the touchpad.
F10 and F11 - Numeric Keypad/F12 - Scroll Lock
25
26
Press the "F10" key to enable your Toshiba laptop's numeric keypad.
27
Press and hold "Fn" and "F11" to enable the cursor control keys on the numeric keypad.
28
Press and hold the "Fn" and "F10" or "F11" key to disable the numeric keypad or cursor control keys.
29
30
Press the "F12" key to lock your cursor on a specific line of text. Press and hold "Fn" and "F12" to turn scroll lock off.
hope this helps
Sep 25, 2012 | Toshiba Satellite A100-S8111TD Notebook
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
My shift key does not works. My cap lock does
Try pressing " Fn + Capslock" at the same time. this will realease your shift and release numlock. if that doesnt work try Fn + F11 I cant remember the exact placement of the keys off the top I i do remember is was a Function button combination with the Caplock key to get it back to normal.
Aug 30, 2010 | Lenovo Tablets & eReaders
I need an explanation as to the secondary function of the keys on my NB305. Mainly the top row of 'F' keys, but the remainder of the keyboard as well. What do all these little symbols on the keys mean?
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
Jun 15, 2010 | Toshiba 310CDT Keyboard
NC10: Can't type without holding function key down
I set up my girlfriends this morning, to turn off Num Lock, you need to have the machine on and select Fn + F11.
That'll turn it off and you'll have the bliss of typing normally again!!
Jan 06, 2009 | Samsung NC10-14GW Notebook
Which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
What settings do I need to change to connect my Acer Aspire 5670 laptop to my LCD TV using the S-video connection?
dont have to change any...connect s-video lead and press fn + the f key that has an icon of monitor on it (little square box)
for instance mine is f2 so I would press fn +f2 (not fn then f2 ,,fn and f2 together)
for most hp the f key is f4...
so you press togethher once and you have signal to tv ..press again you have signal on tv and pc press again and its back to pc only
Jul 28, 2008 | Acer Aspire 5670 Notebook
Dual or mirror monitors
Their is a button located on the 1-9 keys, it looks like a little monitor. Maybe 2 monitors.
Hold down your FN key (Function) and press that button, that will turn on the svga connector. Also if you press it again it should keep both monitors on, and again will switch back to only the LCD.
Oct 11, 2007 | Samsung V25 XVC 2800 Notebook
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
