Question about SYMA Toys industrial New Syma S107 Mini Indoor Gyro
The lower blades are not turning as fast. so the helicopter is no taking off. Need help how to fix this.
How to fix the lower blades of ModelArt 3.5 channel RC Helicopter
One of the other gears in the blade have probably been broken if the blade has been held or stuck when trying to fly. Might need to replace gear.
May 07, 2014 | Toys
The lower blades of my ev.01 helicopter are not working, how do i fix this?
Sophie, you will find that the very tiny gear at the bottom of the rearmost motor has either chewed up or come adrift. I have the same fault exactly and am trying to locate a new gear. If anyone can help locate one the please email j r siddle at hot mail dot co uk (I am sure you can work out the addy)
Dec 29, 2012 | Toys
My S107G Metal Series will not take off just sits and spins how can i fix
If there are two blades that turn in opposite directions, perhaps the blades are reversed. If that is the case then they are pushing the helicopter down instead of up.
Sep 09, 2012 | SYMA Toys industrial New Syma S107 Mini...
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
My bottom propellers won't turn. What could be the trouble? Only flew this a few times.
Same happened to me. I've found out that the white gear at the end of the right motor, that conects to the wheel and makes the blades spin, has been worn out by the harder plastic of the wheel itslef. So now they are no more in contact and thus the lower blades wont sping. I temporarily solved it pulling the white gear a bit lower but it lasted only for a couple flights more :-(
Jan 06, 2011 | Shuttle 9094 Emax Remote Control...
I have had both the Soo6G and the AH-64s009 for one week. I have followed the charging and flight direction to a tee. I have had no big crashes and the ones I have had have been on carpet. Now out of no...
on the soo6g there is a button on the control panel that takes it from training flight to full power flight the button is lower right as you look at it
as for the ah-64 i had the same problem i think it might be a common fault also i was told that the power causes a vortex and needs forward thrust to go higher !
Dec 18, 2010 | xheli Syma S006G Alloy Shark RC Remote...
Hi my helicopter is 9053 , my helicopter working but dont rise , meanwhile it s charging is full , please help me for how to rise many thanks
if the blades are turning and it wont rise check the top blade turn with you hand and hold the lower gear if it spins its loose the clue inside dont hold the turn blades.
solution: get a small drill bit not to big and a drill at the middle of the shaft by the black part make a hole down to the metal shaft and a littel bit into the shaft know get a small screw that woul fir the hold you just made and in to the shaft and it will hold and wala its fixed
Jun 09, 2010 | xheli 9053 Outdoor Volitation Metal...
John Lewis mini helicopter gear wheels dropped
Yes, I had exactly the same problem, the lower blades can actually move a little on the shaft, if the helicopter takes a big knock then they move up so much that the shaft drops so that the gears no longer engage.
To fix it just squeeze the lower blades towards the gear, I did this by putting a finger on each side of the lower blade next to the shaft and my thumbs against the lower gear so you are squeezing along the shaft. The lower blade will then move down, however if it moves too much it will jam against the main body of the helicopter so you will need to pull it back appart a little so the bottom blades move freely.
Jan 01, 2010 | Toys
My john lewis mini helicopter auto stability control not flying
I had a similar problem with mine, check if the central shaft on which the blades turn hasn't become lose and is no longer engaging the gears on the underside of the helicopter.
If the whole shaft can move up and down then this probably means it has come loose, you can solve this by squeezing the lower set of blades towards the bottom gear with your fingers. You should feel the bottom blades move slightly down, if you push them too far they will stick against the main body so you might need to pull them up slightly.
Dec 30, 2009 | Toys
Helicopter is unbalanced
Hi. This is called "talk" its when the helicopter starts spinning instead of the blades, remote control helicopters and real ones.To stop this from happening you need to make sure the tail Rotor is going correctly OR probely the best thing to do would be take it back to the shop and get a hole new one.
Aug 15, 2009 | Sky I Blade Mini IR Helicopter W/ Remote...
SYMA Toys industrial New Syma S107 Mini Indoor Gyro Logo
127 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
