Question about Seagate (9W2063500) 120 GB Hard Drive
When hd is plugged in, it installs device and drivers automatically. it never shows up under my computer but in the taskbar it shows safely remove hardware. power light shows orange but harddrive light never lights. plugged this baby in for the first time in several years. when i last plugged it in, it asked me to format harddrive even though it was already formatted and contained data. i gave up on it after that. now i can't even get it to show the drive at ALL.
  • 4,281 Answers
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Let me know if you need further assistance. Thanks for using FixYa
Posted on Nov 14, 2010
How Do I Safely Remove Hardware
First off, some of those icons will never be removed, as they are necessary to be there for verification purposes. Safely Remove Hardware is one of them. Any time you plug in a device such as a flash card or external hard drive, devices that read and write data, they show up in this block. Since Windows does delayed writes to save time,l if you simply unplug these devices without letting Windows close out the write cache may cause corrupted files. Right clicking on the Safely Remove Hardware icon will cause a listing of attached devices to be displayed. Clicking on the device you want to remove (unplug) will tell Windows to close out the file cache and dismount the device. Windows will do this and them notify you that the device is safe to remove.
Now, regarding all those other icons that appear,such as OneDrive, volume control, and others, if you don't want them showing up in the taskbar, you can right click on the "^" caret symbol that expands the taskbar, then choose SETTINGS. This will bring up the taskbar settings menu. Scroll down the page to where is says "Select which icons appear on the taskbar" and select that. You will see a long list of possible taskbar icons. Turn off the ones you don't want to see display on the taskbar. This does not remove them from the system, but they will no longer display on the taskbar,
Aug 15, 2016 | Computers & Internet
My external hard drive (BUFFALO HD-PE320U2) is not working. When I plug it on the computer "safely remove hardware button" display on taskbar but no partition display on My Computer. What will...
For that you need change some registry keys and delete upper and lower filter with below method. First make sure usb cable connected to harddrive is working fine. Try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Sep 07, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
Hp psc 1210 printer driver is not installed sucessfully in window 7 64 bit
When you connected the product to the computer with a USB cable, the Windows Update installation failed. Solution You can manually install the driver. Make sure you follow the steps in the order given to reset your printer, remove the product, restart your computer, and then manually install the driver. Step one: Turn the printer off and then on
  1. Disconnect the USB cable from the printer.
  2. Turn the printer off and then back on. Clear any blinking lights or error messages.
Step two: Remove the product from Devices and Printers
  1. Click the Windows icon (c01319360.gif ), and then click Devices and Printers .
  2. Right-click the product icon (c01813941.gif ) representing your HP product, and then click Remove device . Follow the on-screen instructions to complete the process. (If the product is not listed, skip to Step three: Restart your computer.)
  3. If multiple icons exist for the product, remove them all.
  1. Restart your computer. You might want to bookmark this page so that you can quickly return to it.
  2. Make sure your computer has a valid Internet connection by opening a web browser and surfing to an Internet site.
Step four: Manually install the driver
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon (c01319360.gif ), and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Click the Windows Update button and wait for the updates to complete.
  8. In the Install the printer driver window, under Manufacturer click HP , and then search for your driver under Printers . If the driver does not show up under HP, try looking under Hewlett Packard. NOTE: The print drivers are displayed by their series names, which means the last one or two numbers may show as zeroes. For instance, the HP Photosmart 8750 displays as HP Photosmart 8700, and the PSC 1210 displays as the PSC 1200 series.
  9. Once you find the appropriate driver, plug the USB cable back into the printer.
  10. The Installing Device Driver Software window should briefly display in the bottom right corner of the computer screen. Wait for it to disappear.
  11. Click the Cancel button on the Add Printer window.
  12. The newly installed printer now shows in the Devices and Printers window.
Jan 05, 2011 | HP PSC 1210 All-In-One InkJet Printer
I have WD 160GB external hard drive. when i plug in to the computer.it shows on the taskbar as USB storage device but without an assined letter . on my computer window shows nothing about the external hard...
Attach your external HD with some other computer, that will definitely appear normal, the problem is due to a virus in ur HD. Your computer's antivirus software stops it to appear. Back up your data on the other computer, format ur external HD, remove un-necessary files and run a virus scan to the files u copied from HD, Hope this will solve the problem, if not, let me know and tell me what would be the response on the other compuer
Sep 20, 2009 | Western Digital 160GB 7200RPM HDD WD1600BB...
Radeon HD 4650 = NO audio
uninstall the ati sound utility, these video cards have a built in high def audio chip for sound thru hdmi
Dec 07, 2008 | ATI Diamond Multimedia Stealth RADEON HD...
When i plug the flash drive into my computer, it does not show up under my computer, but the safely remove hardware icon shows up on my taskbar.
Try downloading the U3 driver, if you haven't already.
First plugin the sandisk to your usb port, and then check from Windows Explorer, does your sandisk cruzer detected? you'll get a new drive letter besides your local drive or named "removable disk".
If you do see it then just do format (you'll lose the U3), copy, store, overwrite it again and again as you like.
If you still need the U3 application, pls read this:
http://www.u3.com/support/default.aspx#CQ1
You possibly haven't installed the driver properly.
If a wizard that comes up as soon as you plug the device in, Just let it detect the device and then go to Control Panel, and System, and Device Manager, and double click on the device driver, or if it isn't there, double click on the unknown device with the yellow exclamation mark and hit the Driver tab, Install Driver, and choose the 'Let me choose the driver' option, and navigate to where you unzipped that driver you downloaded to, and click on the driver, wait for it to finish installing and reboot.
Let me know how you get on..
Good Luck!
Chris (ziraffa)
Dec 06, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Install flash drive
What type of operating system you are using? If it is a Windows XP's or vista it is a "Plug and Play" i.e automatically detects the type of device that's been attached and, if needed, automatically installs the appropriate drivers for it.
Windows "Plug and Play" plays very well with USB. Chances are installing your USB flash drive means simply plugging it in, and letting Windows do the rest. (It may ask you for your Windows installation CD to get drivers.) When done, you should find another drive letter on your machine that is the USB drive.
To be clear, you should definitely review any documentation that came with your USB device.
While flash drives and other "disk-like" devices tend to just work, manufacturers of other devices often have you install their software on your system before plugging the device in for the first time.
So just check the materials that came with your new peripheral.
Your taskbar should notified you that new hardware installed ". Click on that, select the device you wish to remove, and Windows will do things like flush the disk buffers and ensure that from the operating systems point of view it's safe to unplug it.
Jul 25, 2008 | Computers & Internet
Phillips Go Gear 6GB
The Phillips website has a solution for this:
Go to the FAQ for this mp3 player. It'll tell you to install the Device Manger which will repair the problem. I've done this, however, the Device Manager claims my mp3 Player is not connected.
Try this yourself, you might have better luck.
Oct 27, 2007 | Philips HDD1630 MP3 Player
Seagate (9W2063500) 120 GB Hard Drive Logo
61 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
