Question about Garden
The previous owner installed a concrete block chimney for a woodstove in the basement. He did not tie in the chimney at the top and there is some movement. I want to secure to the house now and next summer have it properly repaired. Any suggestions
    Genius:
  • 1,015 Answers
If you are talking about side to side or horizontal movement. A easy temporary fix would be if you can get to it in attic is to use 1 1/2 inch angle iron. Cut four pieces three inches longer than outside dimensions of chimney. Take peices for front and back so that bottom side of angle sets flat against chimney.Lay two other pieces on top of of first two so that top edge of angle lays flat against chimney. Mark and drill 5/16 inch holes so that outside corners can be bolted together. I would use 1/4 x 1 1/2 inch hex bolts and nuts to fasten angle iron together. I should have said that the thickness of the angle iron could be 1/8 or 1/4 inch. Position support bracket so that you can use pieces of angle iron or strap iron from bracket to top or side of rafters or trusses. Drill holes in bracket end so you can use corner bolts and measure and cut to length as needed to reach nearest rafter. Drill 2 3/16 holes on end to be secured to rafter and nail with 16D nails. Secure all four sides and you should be good for now. Hope this helps. Thanks
Posted on Nov 14, 2010
Why creosote buildup in woodstove firebox but not in chimney
sounds like not enough draft pulling smoke out fast enough. as far as creosote on the glass, this is normal. you can buy the glass cleaner at Canadian tire, just spray on and wipe of a few seconds later, works great
Sep 22, 2014 | Pool & Spa
Build a pizza oven in the back yard
Hi.
All you need is bricks and cement.
Use perforated bricks or regular 65mm bricks for the support. A light oven may be built on an U shaped support (you will need to make some structural considerations about the weight). Moreover the U shaped support on top requires an armed concrete slab adequate to support the chamber. If you are not sure about structural performance, build a solid support block of bricks.
Make sure that the support is adequate for the weight of the heavy chamber. If the oven is big, then lay basic foundations or build the oven straight on the ground.
For the chamber you must use refractory bricks (fire bricks). You have different choices of design. A common shaped that do not require armed concrete parts is the igloo style chamber. Leave space for the chimney on top of the chamber.
Mar 24, 2013 | Ovens
Woodstove smokes into the house
I've never used a ceramic chimney, or seen one for that matter. I know that the dual walled vent pipe works better when warn/hot. Can't explain it real well but the inner pipe gets hot while venting the heat and smoke. And between the inner and outer wall is cooler air, which is drawn down towards the wood burner. Creates a suction by the exhaust out of the center pipe. Mine smokes up the house when I leave the doors open and when it's a low flame inside. I'm sure you've checked on the manufacturers' specs for venting but, if you don't already know, look into the thermal dynamics of a dual walled vent pipe. And also a ceramic as you have. Has to be something with your stove install or vent pipe. Hope this couch advise helps!
Apr 04, 2017 | Heating & Cooling
Sirocco eco 3 gas fire. Flames burning ignition cable
Yellow flames is lack of air blocked burner ,blocked injector , low gas pressure .
I would put a smoke pellet up the chimney to see if you have a pull on the chimney to see if it is not blocked , or if you have down draught what sort of pot are you thinking of putting on the top ?
Jun 11, 2012 | Grilling
Installing a bathtub on concrete floor
Other than chopping out more concrete.elevating the tub is probably your only other solution. I would think 2" would be adequate.
Hope this helps.
Bob
Feb 08, 2012 | Crane & Co Crane Plumbing 2430W Whirlpool...
I boughta vermont castings model # 2610 cast iron radiance franklin stove it came w/pipes .............is it a direct vent or a b vent..reason why i am asking is he gave me a "t" pipe w/ screen...
It the opening on the stove is on top of the stove, it's a 'B' vent. If the opening is in the back of the stove it's a "Direct Vent". However, some models have a connection on the back that's facing up,. A 90 degree elbow can be used to convert it to a horizontal run to enter an existing chimney, but then it must elbow up to connect to the pipe that is required to line the chimney. You should not just stop the pipe above the damper. It needs to run all the way to the top of the chimney, then have flashing seal the chimney's clay liner and a termination cap on the top.
here is a link to the Owners Manual/Installation Instructions for a Model 2600. It installs the same way as the 2610. http://homeappliance.manualsonline.com/mdownloads/62b85343-a800-4898-85a1-3d6d3c524259.pdf
Hope this helps you sort things out and do a proper installation.
Apr 18, 2011 | Heating & Cooling
Is there a way to vent a basement bathroom without cutting into the cement foundation
What is in the room above the basement bathroom?
And how large is the diameter of the vent pipe you need to run?
Do you have a maximum number of elbows, and runs of feet maximum you can't exceed?
Is the Frame wall above the foundation, accessible by going up thru the ceiling of the bathroom, and the elbowing over and into the outrside frame wall at that point?-- and then up a ways, and then out thru the outside wall?
Another possibility would be: How far to a window, or vent already in the basement?-- Could you run the piping there, and then out?
How thick is the concrete wall?-- Is it reinforced Concrete-- or just Masonry Block wall? A block wall is not as hard to get thru--
I know I asked a lot of questions-- but maybe it helps you think thru your options?
Le4t me know if I can help further.
Mack B
Jan 29, 2011 | Fantech Fans Exhaust Fan In-Line
I have a 3 year old ge smartwater gas water heater. in our ontario winters, the gravity vented unit spills exhaust into the basement because the pipe and chimney get too cold after the heater is off for...
Id try raising the chimney until you can get the smoke from a piece of paper to get sucked up under the draft hood. I believe theres a different problem then a cold pipe.raising the chim.might not be the answer.
Jan 17, 2011 | General Electric GE SmartWater Household...
I just got a Whitfield Quest pellet stove from a friend. Do I need a fresh air pipe if I use it in my house/ basement? Also where can I get a repair/owners manual. Thanks Kurt Willem
Some people plump in fresh air but you can also punch out the fresh air in take out on the back of the stove and recirculate the air within your home.I would think twice about installing it in your basement . Basements have a tenancy to create a negative pressure, which means that it can become very difficult to create and up draft through the chimney , which causes the smoke to seep out of the stove into your home. The only way I have found to over come this is to run a torch in the stove for 5 mins before starting a fire, this creates an up draft which eliminates the problem.
Aug 19, 2009 | Napoleon Auburn Pellet Stove Heater
My chimney is falling down and I want to replace it with a standard galvanized pipe. Is a 6" pipe good enough to run from basement to above roof?
No
the chimney needs to be big enough to carry away combustion products, if the brick chimney has a 10inch square to carry the smoke (100sqin) 28.3sqin for a 6inch round chimney wont do it
needs to withstand combustion heat, mild steel gal wont.
building codes specify what you can use in your region and diameter / house size rules
Selkirk style chimneys sell and are so priced for the reason
Jul 10, 2008 | Heating & Cooling
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
