Question about Refrigerators
There is no water coming into the unit, yet about twice a week the bottom of the refrigerator is all wet. Where is the water coming from and how do I stop it?
  • btrsweet1 Nov 16, 2010
    I checked the bottom of the refrigerator for a drain pan and hole, but I did not find anything. Could there be a water line running down the back of the refrigerator?
    Guru:
  • 773 Answers
Refrigerators have a defrost mode. this keeps the freezer section from icing up. there are 3 reasons you have water on the floor.
  1. The evaporator pan is not in place or missing, and the water is dripping out of the pan or not getting collected by the pan.
  2. the fridge is not level. The water is dripping out of the pan.
  3. even though the fridge is defrosting, there may be ice clogging the drain tube. this is usually confirmed by water in the bottom of the inside of the fridge as well.
water from the thawing of ice is supposed to flow down a drain tube at the back of the freezer assembly. It then is supposed to be collected in the evaporator pan where the heat from the condenser evaporates it. If there is a problem like ice frozen in the drain tube, which happens some times, the water finds its way else where and ends up on the floor or in the bottom of the inside of the fridge. If the evaporator pan is not in place or not level because the fridge is not level, then the water will run out of the pan onto the floor because its some what tipped. If it is missing then the water goes straight to the floor.
Check to make sure pan is there, free from debris and is level and seated correctly. If this is the case, and there is water inside the bottom of the fridge you need to unplug the fridge and let it completely thaw.
This should solve the problem.
Posted on Nov 17, 2010
  • 2,299 Answers
There is a drain plug in the bottom of the refrigerator that is plugged up. This drains into a pan under the fridge. The water will evaporate before it fills the pan. The water is coming from condensation when the defrost cycle runs.
Posted on Nov 15, 2010
My refrigerator/ freezer doesn't seem to be too cool. Cleaned bottom coils and left unplugged for 24 hrs. Turned back on and it worked fine for a week. Now it is not cooling again. Any ideas why?
Hello Chris Conrad,
Worked fine for a week... is actually a pretty good sign...
MOST likely means the cooling is OK...
FROST-FREE (defrost)... should become your focus
TYPICALLY... (assuming you have that type of UNIT).
after the week... is it clogged with frost / ice (cool in the freezer area but not the refrigerator... (a week is a little less than average to become non-functional in the refrigerator (cheap little refrigerator thermometers come in really handy here... (but still cool in the freezer area where all the REAL cooling is done))).
Can you see frost/ice blocking any air slots in the FREEZER AREA??
Is water being put in the (I assume) "defrost pan" daily...?
Easy to check... put a strip of typing paper folded over the edge of the (water tray) defrost pan...
Still clean, straight & dry tomorrow = defrost circuit failure
(again.... assuming it is a "frost-free").
Yes (clean & straight) means I am wrong: paper
will look rumpled & ugly (possibly wet).
Then...
You have a HUGE AIR INTRUSION problem you need to fix first... (door alignments, gaskets, etc.) then get sophisticated about makes, model numbers... & how soon it takes to get ICE-BOUND.
You can comment me back... or get out the original
refrigerator documents... (typically) looking for:
- Defrost timer or control board
- Defrost thermostat
- Defrost HEATING ELEMENT
OR
Search on line to parts/spares + appliance+ (your model number).
Good luck...
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
Apr 27, 2016 | Refrigerators
I have a Jenn-Air JFC2290v water appears on the floor front right corner, sometimes front left corner as well. I have moved the unit and have not found any water under it. This has been on going for...
I bought the same JFC2290 model and it says "Auto defrost". Mine is only 10 months old and it starts having exactly same problem already. Water leaks and I have to clean my hardwood floor twice a week. I will never own Jen junk again!
Nov 09, 2011 | Jenn-Air JFC2290VEP (21.8 cu. ft.) Bottom...
There is water under my drawers with ice build up. I clean it up and 2 weeks later it wet again. Help
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
May 15, 2011 | Amana ABB1927DE Bottom Freezer...
The freezer fills with water and overflows about once a week.The food is partially frozen and the ice is clear and wet. The fridge is cold and no problems but the freezer doesn't fully freeze and water...
your evaporator coil in the rear area behind the freezer back panel is frozen over with ice and the coil can no longer deliver cold air due to ice blocking the air flow from the evaporator fan,remove this rear panel,defrost it with a hair dryer,check the defrost heating coil for continuity,they go bad regularly,if not the heater coil under the evaporator coil,it may be the defrost timer in the refrigerator section of the unit that powers the defrost coil that needs replacement
Jul 25, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
The cheese/cold cut drawer area develops a sheet of ice under the door over a period of a few weeks. I have to remove the drawer and de ice the area. Sometimes the inside of the drawer itself is wet or...
hello. remove the lower front grate, at the floor level and clean the dust from under the unit. Also, check the interior bottom of the fridge and clean the "floor" being sure that the small drain hole is free of any debris. This will allow the water produced when the unit self-defrosts to travel through the fridge to the evaporation plate below and not stop in the cheese drawer. J.
Jun 11, 2010 | Jenn-Air JFC2089HE French Door...
Water dispenser does not work
the volve for the water is might be bad need to be clean or replace the volve to the ice unit is with the water but they seperate units...
Dec 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dripping from underneath
The water is most likely coming from the condensation that's drained out of the refrigerator during the automatic defrost cycle.
Be sure the bottom fan is running and clean out the condensation tray. Warm air pulled across the condenser coils is supposed to evaporate the condensate water. If the fan is not running when the refrigerator cycles on, replace it. This would also result in the refrigerator running excessively without cycling off.
While you're working under the unit, be sure to clean off the coils too.
Good luck. Hope this was helpful.
Nov 20, 2009 | Computers & Internet
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Puddle
no mater what the issue is the machine is under manufacture warranty for 1 year, call for factory service
Apr 12, 2008 | KitchenAid KSRP25FN Side by Side...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
