Question about TORK Variable Cycling Timer 8601
Calibrate clock - TORK Variable Cycling Timer 8601
Http://waterheatertimer.org/pdf/Tork-8000Series.pdf
Tork 8600 is variable cycle timer.
Each revolution of dial is 60 minutes, 30 minutes or 6 minutes depending on model.
60 minute timer has 2 models, 120V and 240V.
Other models are 120V.
If clock is not keeping time, then clock motor is bad.
I don't have a source for clock motor, and suspect that a new timer is purchased and then installed into existing box.
Link below sells 8601 60 minute 120Volt
http://www.weisd.com/store2/tork/torktimer1.php
To set times, the dial has tabs located around dial.
Tabs are tilted in or out
Tab out = NC terminal has power
Tab in = NO terminal has power
Posted on Nov 14, 2010
Edward Meyer 31 Day Grandfather Clock manual
I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
Jan 23, 2012 | Watches
My lbp5000 prints the colour image seperate from the black image, although it's supposed to be one image
The printer is need to Calibrate. Calibrate the printer from the menu in the taskbar down/right to the clock. Calibrate several times until printing is good.
Jan 08, 2011 | Canon LBP5000
I live in Florida. My atomic watch has worked perfectly until a week ago when the nightly automatic calibration with Fort Collins stopped. Have followed the instructions faithfully. I moved the watch to...
It could be a temporary, weather-related, problem, or it could be related to a number of other factors: new construction in your area, a new RF source (radio transmitter, cell tower, etc.) in your area, etc. Your watch contains a small radio receiver, and determining the exact cause for its failure to receive the WWVB signal is nearly impossible. About all you can do is try the watch at different locations in the home, and you may have to turn it to face in different directions. Mine, for instance, syncs best when hanging from a drawer and facing in an east-west direction.
Bill B
Apr 10, 2010 | La Crosse Radio Controlled Atomic Clock
Sony DCR-HC18e Touch screen stopped
The problem you have on your Handycam is the flex cable FP-835.
You have to open the camera and change the cable.
It´s very easy to change.
Sep 06, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Clock is losing time
This is a problem with either the a/c power or the Clock/Radio's internal timing crystal circuitry. The radio depends on the 60 cycle power source as the timing device. If this power is irregular or uneven in its delivery it can cause the timing circuits to lose or gain time. The Clock/Radio has a frequency tuned crystal that operates like the second hand on a clock. When the calibration for whatever reason is lost the crystal will not be able to perform the timing function correctly. The reason this does not happen in all Clock/Radios is that they usually have correction circuits. These circuits keep the crystal from drifting out of calibration during operation. Because of the low production cost of these Clock/Radios, the quality control is almost non existent. The components are variable and sometimes they do not stay within specifications. This problem is usually handled by quality control departments in the manufacturers facilities. They usually test a certain amount of the production run to make sure it meets specification. In higher priced electronics these test are on going during the production run. In lower cost electronics these tests for quality control are usually done before the production run. This is to choose the best and most reliable components for the price level of the product in production. What this means to you, is that the quality of the components and quality control of the production runs are based on cost efficiency to the manufacturer. This is the reason for these type of efficiency variables in the products. The customer support telephone number for Emerson is 1-800-898-9020 between the hours of 9am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information helps you under the problem and reason these problems can occur in the products. Thank you for using FixYa and have a nice day.
Feb 16, 2009 | Emerson Smartset Clock Radio
THE TEMPERATURE REQUIRES CALIBRATION
We're sorry to learn of your concern. The calibration is only on certain models with an electronic clock/timer. We recommend service for a proper diagnosis. If further assistance is needed, please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with the website you reached out to us on (fixya), brief description of your concern, your name, address, a phone number and best time to reach you along with your model and serial number.
Jan 15, 2018 | Whirlpool RF341BXKW Electric Kitchen Range
Wrong time
This is a problem with either the a/c power or the Clock/Radio's internal timing crystal circuitry. The radio depends on the 60 cycle power source as the timing device. If this power is irregular or uneven in its delivery it can cause the timing circuits to lose or gain time. The Clock/Radio has a frequency tuned crystal that operates like the second hand on a clock. When the calibration for whatever reason is lost the crystal will not be able to perform the timing function correctly. The reason this does not happen in all Clock/Radios is that they usually have correction circuits. These circuits keep the crystal from drifting out of calibration during operation. Because of the low production cost of these Clock/Radios, the quality control is almost non existent. The components are variable and sometimes they do not stay within specifications. This problem is usually handled by quality control departments in the manufacturers facilities. They usually test a certain amount of the production run to make sure it meets specification. In higher priced electronics these test are on going during the production run. In lower cost electronics these tests for quality control are usually done before the production run. This is to choose the best and most reliable components for the price level of the product in production. What this means to you, is that the quality of the components and quality control of the production runs are based on cost efficiency to the manufacturer. This is the reason for these type of efficiency variables in the products. The customer support telephone number for Emerson is 1-800-898-9020 between the hours of 9am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information helps you under the problem and reason these problems can occur in the products. Thank you for using FixYa and have a nice day.This is a problem with either the a/c power or the Clock/Radio's internal timing crystal circuitry. The radio depends on the 60 cycle power source as the timing device. If this power is irregular or uneven in its delivery it can cause the timing circuits to lose or gain time. The Clock/Radio has a frequency tuned crystal that operates like the second hand on a clock. When the calibration for whatever reason is lost the crystal will not be able to perform the timing function correctly. The reason this does not happen in all Clock/Radios is that they usually have correction circuits. These circuits keep the crystal from drifting out of calibration during operation. Because of the low production cost of these Clock/Radios, the quality control is almost non existent. The components are variable and sometimes they do not stay within specifications. This problem is usually handled by quality control departments in the manufacturers facilities. They usually test a certain amount of the production run to make sure it meets specification. In higher priced electronics these test are on going during the production run. In lower cost electronics these tests for quality control are usually done before the production run. This is to choose the best and most reliable components for the price level of the product in production. What this means to you, is that the quality of the components and quality control of the production runs are based on cost efficiency to the manufacturer. This is the reason for these type of efficiency variables in the products. The customer support telephone number for Emerson is 1-800-898-9020 between the hours of 9am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information helps you under the problem and reason these problems can occur in the products. Thank you for using FixYa and have a nice day.This is a problem with either the a/c power or the Clock/Radio's internal timing crystal circuitry. The radio depends on the 60 cycle power source as the timing device. If this power is irregular or uneven in its delivery it can cause the timing circuits to lose or gain time. The Clock/Radio has a frequency tuned crystal that operates like the second hand on a clock. When the calibration for whatever reason is lost the crystal will not be able to perform the timing function correctly. The reason this does not happen in all Clock/Radios is that they usually have correction circuits. These circuits keep the crystal from drifting out of calibration during operation. Because of the low production cost of these Clock/Radios, the quality control is almost non existent. The components are variable and sometimes they do not stay within specifications. This problem is usually handled by quality control departments in the manufacturers facilities. They usually test a certain amount of the production run to make sure it meets specification. In higher priced electronics these test are on going during the production run. In lower cost electronics these tests for quality control are usually done before the production run. This is to choose the best and most reliable components for the price level of the product in production. What this means to you, is that the quality of the components and quality control of the production runs are based on cost efficiency to the manufacturer. This is the reason for these type of efficiency variables in the products. The customer support telephone number for Emerson is 1-800-898-9020 between the hours of 9am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information helps you under the problem and reason these problems can occur in the products. Thank you for using FixYa and have a nice day.
Dec 13, 2008 | Emerson Smartset Clock Radio
My clock is four hours behind when it strikes on the hour. How can I correct this.
What type of clock is it...
Analogue / Digital
Does it have a calibration ?
What stops you from forwarding the clock by Four Hours ?
Aug 17, 2008 | Watches
Clock gains 5 minutes or more time over 30-45 days
Could be low-grade electronic components used, less than 1% tolerance values, or the crystal time-base, a precise clock-pulse generator, needs calibration.
Recommend to get it checked by electronics wizard.
Jan 31, 2018 | Aiwa FR-CD1500 Clock Radio
TORK  Variable Cycling Timer 8601 Logo
154 people viewed this question
Top TORK Hardware & Accessories Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
pawnpower
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
