Question about Honda Vehicle Parts & Accessories
Recharged car battery and now remote will not start but it open and closed the locks
  • 139 Answers
Sounds like it may be in valet mode. What brand and model security system do you have?
Most systems, require that the ignition be on and than you activate the valet switch that is installed in your vehicle. The switch can be a push button switch or a toggle switch.
Posted on Nov 16, 2010
When using remote to unlock or lock doors the motor keeps going for a couple of seconds and when driving it will stop and start
Door locks are opened an closed by an actuator not a motor ! It would help to know the make , model an year vehicle you have to see what controls the locks on your vehicle . A control module , relays etc.. Some car makers use a BCM - body control module, or some have DDM , PDM - a module inside the door . An you say when driving it will stop an start , what will stop an start ? The vehicle ? or do you mean the locks open an close on there own ?
May 16, 2016 | Cars & Trucks
I recharged the battery recently because the car didnt start. Got the battery on again and now the car makes a beeping sound every time. I try to start the car but nothing happens. Help please!
use remote to disable the alarm or close drivers door turn key in door lock lock and unlock car 3-5 times if you do not have an alarm remote to said car this will disable the alarm system
Jan 04, 2013 | Cars & Trucks
Having trouble with keyless remote control on 1993 lexus es300. Replace battery on remote- still not openning doors. Help Please!
Try reporgraming it
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Press any button on remote for a minimum of 1 second.
System should now lock and unlock doors once.
6. Close and open drivers door.
7. Press any button on remote for a minimum of 1 second. System should now lock and
unlock doors. Once to confirm programming, twice to indicate programming failed.
8. Repeat steps 5, 6 and 7 for additional remotes.
Jan 02, 2013 | Cars & Trucks
2003 330XI keyless entry. wont open or close.
The transponder is not effective any longer sometimes the battery of the remote is very low which needs to be replaced
Jan 17, 2018 | BMW 330xi Cars & Trucks
Compu start remote does not work after car battery died
The remote needs to be reprogrammed.
Procedure:-
Stand close to the car with the engine switched off and all doors locked up.
Hold down the open and close buttons on the remote fob for 10 minutes
After then press the open and close key simultaneously for 5 seconds.
That should do the trick.
Good luck.
Apr 28, 2010 | 1999 Saturn SL
97 toyota 4runner factory alarm not allowing to start
lock your doors and close it wait till alarm resets and then unlock door with key and this should take care of you problem
Jan 05, 2010 | 1997 Toyota 4Runner
The battery in my key fob for my 2004 Mitsubishi Diamante went flat. How do I reset it now that I have replaced the battery?
1-insert and remove key from ignition two times
2-close and open driver door two times
3-insert and remove key once from ign.
4-close and open drvr door twice
5-insert key into ign.,then close driver door
6-turn key to on (not start) then off, twice this is rewrite mode,have all remotes to reprogram it will clear any lost remotes.
7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
8-press lock/unlock together and hold for a second
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possession,you are done. To end mode open door or insert key into ignition.
You'll need to follow the steps with no more than a 1-2 second delay between each step.. hope it works
Aug 20, 2009 | Mitsubishi Diamante Cars & Trucks
Gas door how do i open it 2000 bmw 3231 remote is dead
The remote battery is not rechargeable but, it is replaceable. Most dealers and jewelry stores have
replacement batteries.
Apr 01, 2009 | 2000 BMW 3 Series
The Lexus car remote key control model ES300
try this:
2. Insert key into the ignition (DO NOT Turn) and Pull key out.
Mar 23, 2009 | 1997 Lexus ES 300
BMW remote control problem
I have a e60 525i that I just brought and it has the same problem, the owners manual suggests driving with the key in the ignition for a long time as the batteries are rechargable and may have gone flat, i have tried this and it doesnt seem to work
i also read something about getting water in the aerial about the rear window and that wrecks the receiever. My car isn;t under warranty so not looking forwarding to taking it to bmw
May 26, 2008 | 2007 BMW 525xi Sedan
Vehicle Parts & Accessories Logo
213 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
