Question about Kenmore 95320 / 95321 / 95322 / 95324 / 95329 Electric Kitchen Range
The lock light is flashing and it's making a noise. I can't get it to stop. I can't use the oven. How do I fix That
My Frigidaire electric range/oven started making mechanical clicking or ticking sounds all of a sudden and a "locked" light keeps flashing weakly and the going out. When I open the oven door the...
Hi mike_glenn,
Ok, do the following:
1) Press and hold the "Clear/Off" button on the oven until you hear a beep and the word "OFF" disappears from the display. The word "Lock" will remain in the display until the door lock is disengaged, which could take up to 10 to 15 seconds.
-or-
2) Find the main circuit breaker for your oven. Turn it off for fifteen minutes, then flip it back on. This should allow the door latch to open.
I hope this helps
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 03, 2011 | Frigidaire Kitchen Ranges
Self clean is locked but door still open
oven won't heat, "door locked" always flashing if I push"off/cancel there is a crackeling noise and "F9" fashes for a while then stops, Display flashes "door locked" but door will open but will not heat and now always flashes "door locked"
Dec 18, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Lock light is blinking / oven light on
i would unplug it or turn the breaker off to the unit for at least 5 minutes see if this resets it or the code goes away, if not then usuallly the lock flashing relates to a bad lock assembly,, also if there is any control locks make sure those havent been accidently puches hope this helps
Jan 31, 2010 | Frigidaire Kitchen Ranges
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
Cancelled self-clean, F9 code came up, door lock light flashing, can't use oven
HI,
your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Hope this is of use to you ;)
Phil
Oct 25, 2008 | Kitchen Ranges
Frigidaire FGB557 CESI
try disconnecting the power for 30 seconds see if it resets if it doesnt then you will have to replace the control bd how old is it
Jun 20, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven door LOCK light on decided to run the cleaning light still is on for lock and there is a tick tock noise oven will not set to bake door will open if you lift up on the handle been acting up for...
fixya.com did not help at all.
After numerous phone calls to a variety of help places, I finally got in touch with a woman at a repair shop that told me to turn off the circut breaker in the basement for the stove. Well at least the oven stopped making noises. Then she asked me to call a number and get a warrentee. I did have an extended warrentee and tomorrow (Wed.) a repair man will come and fix my range.
I won't be using fixya.com again and I won't be using 1800-GE CARES for my appliance needs. I need to speak to a person and get the problems taken care of.
Apr 11, 2008 | GE Kitchen Ranges
Fridgidaire smooth top oven lock model FEF369CGSD
Actually my son fixed it. The button on the face frame when the door is open, isn't just for the interior light. My son held it in and the oven latch slowly moved back to the open position. Thanks anyway
Feb 09, 2008 | Maytag MER5775Q Electric Kitchen Range
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Kenmore 95320 / 95321 / 95322 / 95324 / 95329 Electric Kitchen Range Logo
19 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
