Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
Utilities Disk for WinFast K7S741MG motherboard
Hi where can I download the disk utilities for this board?
regards.
John
  • 385 Answers
Click on this link and it will take you to the support page for foxconn motherboards. There will be 2 options: Search by product model and search by download type. Type in K7S741MG-6L in the keyword space. Then where it says select type, select under Motherboard, I-drivers and click search.
To the bottom will display the drivers for this particular motherboard.
Hope this solves your driver problems.
Lolita
Posted on Jun 18, 2008
    President:
  • 1,314 Answers
All the downloadable files for your motherboard can be found here:
http://www.foxconnchannel.com/support/downloads.aspx
Under type select "motherboards"
Under series select "Socket 462"
Under model, select k7s7....
All the downloads for your motherboard will appear.
Will my motherboard handle ddr2 ram and if so how much?
Dear sir,
Board has DDR1 slot which is entirely different from DDR 2 slot , it will not support , you can find DDR1 ram for ur board from supplier of used/ obslete PC parts .
Regards
Raj
Feb 10, 2011 | Foxconn WinFast K7S741MG Motherboard for...
About disk boot failure
Hi!
Disk boot failure means that your BIOS can't find the master boot record of your computer which resides in the hard disk or a floppy disk.
This indication means that your hard disk drive is not detected by your BIOS or their is no operating system installed with it.
Have a nice day!
Jun 02, 2010 | Foxconn WinFast K7S741MG Motherboard for...
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
I have a Winfast K7S, 741M01C, series motherboard
Hello Friend,
The max RAM that you can use with this motherboard which has 2 RAM slots is 2GB.
Best Regards,
Oct 30, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Vga driver
I found the site to suggested to you.
Foxconn Site
Link
Direct Driver Download
Link >>> VGA Board Driver
Link >>> AGP Driver
Just Click and follow the link
Or you can download it from sis website, coz this motherboard uses the SiS 760GX motherboard chipset drivers, which you can download directly from SiS:
http://www.sis.com/download/
Jun 03, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Quero upgrate de memoria da winfast k7s741mg qual
Esta placa es compatible con memoria Ram DDR 266/333/400 , y los modulos no pueden ser mas de 512Mb cada, en cuanto la placa no suprota doble densidad.
Aqui el manual en Ingles: Easy Installation Guide
May 06, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Adding harddrive
hi my name is wesley. you need to make sure the hard disk you put in is set to slave otherwise it clashes with your other hard disk and will not boot. you will see a jumper on the hard disk you can set to slave instructions is on the hard disk you just have to change witch two pins the jumper is on.
Jul 08, 2008 | Foxconn WinFast K7S741MG Motherboard for...
WinFast utility CD
I just did a fairly thorough survey of the web concerning that motherboard and came up with virtually nothing. Both the Winfast.com and Leadtek.com seem to be in collusion right now covering many similar motherboards as if they may have bought the original company Foxconn, however your particular model was not among those listed on either of the two sites that did cover the other Foxconn motherboards.
I'm sure someone somewhere has those on a CD or on a HD but it might be a long wait. I wish you good luck
Feb 27, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Audio driver for k7s741mg_6l
http://www.biostar-usa.com/cpusupportA.asp
this is the link and solution si here.
tip:
if you need a driver check inside
the board and look who's the manufacture.
it could be amibios.phoenix.etc.
Feb 10, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
1,771 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
