Question about Acer Aspire 5315 Notebook
Hi i got a acer aspire 5315 but somone made a bios password on it now and i need to boot from cd how do i reset bios password
    Genius:
  • 1,542 Answers
Hi
This is not an easy problem to get around
You could if you could get to the cosmos battery reset the jumpers but this is usually very difficult to get to in laptops if you google it you may find out where it is
I have heard it said tho not tried it my self that if you put in your repair disk and keep pressing f12 on startup it will let you in or give you options ???????????? not sure about that one
If you can get into the bios by pressing the delete tab on startup then you may just may be able to disable the password in there than save think the tab to save and exit is f10 but im not sure but be very carefull not to play around in there with settings that you dont understand
or you will have major problems
Or you could google free bios password removal tools there are also some out there that are trial for so many days you could use one of these and then delete it afterwards
good luck
Posted on Nov 14, 2010
Forgotten BIOS password for Acer Aspire 5315
Contact Acer for a one-time BIOS password. OR try to do a fresh install with Windows7 install DVD.
Apr 06, 2013 | Acer Aspire Computers & Internet
Where is the bios/cmos battery located on a aceraspire 5315-2698? I cant get past the password screen.
The battery in Acer Aspire 5315 is very visible has a blue ring of plastic or rubber around it. follow the leads which are very short and short the circuit. no risk of damage to systemboard)
1. Try to remove cover
2. Find battery on the far right hand of the board
3. Take a small flat screwdriver and contact the two leads from the battery
4. Power it on and power it off to reset the BIOS
5. This should work for passwords
6. Moreover, it resets to default configuration
Please share the results.
Regards,
Anirban Mazumdar
Mar 16, 2011 | Acer Aspire 5315 Notebook
Acer 5315-2698 bios backdoor password
You didn't mention what BIOS you have..(re: pheonix or ami or Award) so you can try "BIOS" or "CMOS" or "ACER" or "PASSWORD" or you can remove the CMOS batttery for a few minutes
Dec 29, 2010 | Acer Aspire 5315 Notebook
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
May 24, 2010 | Acer Aspire 5315-2713 Notebook
Acer 5315 with bios password not known and need to reset or remove
hi the only way you can reset the password in the bios is to remove the on-bored battery for 20 seconds, this will reset the bios back to factory settings...hope this helps
Mar 25, 2010 | Acer Aspire 5100 Notebook
Solution for reset password
1. to reset password in acer aspire 5315 simply take a _small_ flathead screwdriver.. contact the two points leaving the battery, power on, power off and the password is cleared.
save the thread below for all your future solutions its all about ur laptop only. http://www.techsupportforum.com/hardware-support/laptop-support/200354-bios-recovery-acer-aspire-5315-a.html
Kindly do rate my solution.
Jun 26, 2009 | Acer Aspire 5315 Notebook
Acer 5315 will not start up windows
check the BIOS setup screen, when you get the ACER screen press F2 or F10 or the DEL or END or ESC key one of those will get you into the bIOS SETUP. Once there revise the boot order, make sure the CD is first to boot then HDD. Also review to see if the BIOS recosgnized the HDD. the symptom you are describing may be a bad HDD.
Jun 02, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315-2698 want to restore to like ner . restall from
If it has a hard drive password, you must remove it before you will be able to restore your OS.
Mar 15, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 wont boot up
for password, you need to reset your bios. check your bios and enter the password given below:
for AMI BIOS Passwords:
A.M.I.
AAAMMMIII
AMI?SW
AMI_SW
AMI
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD
for AWARD BIOS
01322222
589589
589721
595595
598598
ALFAROME
ALLy
aLLy
aLLY
ALLY
aPAf
_award
award
AWARD_SW
AWARD?SW
AWARD SW
AWARD PW
AWKWARD
awkward
BIOSTAR
CONCAT
CONDO
Condo
d8on
djonet
HLT
for Phoenix
BIOS
CMOS
phoenix
PHOENIX
Other Manufacturer BIOS Password
Biostar - Biostar
Compaq - Compaq
Dell - Dell
Enox - xo11nE
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
VOBIS & IBM - merlin
hope this helps!
Nov 12, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315
download ultimate boot disk you can reset the password with this program
Jun 10, 2008 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5315 Notebook Logo
143 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
