Question about Porter Cable C2002 150 Psi 6 Gal Compressor
When pressure gets to 150 psi and is supposed to turn off it keeps popping the safety.
  • jrmira Nov 14, 2010
    the compressor is supposed to get to 150 and shut off when it reaches 150 the pressure relief valves pops and pressure starts building again to 150 and pops off again. this cycle keeps repeating.Do you believe this is still the solution you have given me? thanks bob
  • 2,841 Answers
Let me make sure I understand this correctly. It is supposed to shut off at 150 psi but does not and keeps building pressure until the safety release valve pops and releases the pressure. If this is all true then the pressure switch is defective and needs replacing, You can get a pressure switch here. http://www.ereplacementparts.com/pressure-switch-p-225922.html?osCsid=dq4q5pdn6h1hvnnhnfohrpo500 It looks like this/ when pressure gets to 150 psi and is supposed to - clay58.png
The Pressure switch is # 111 and has a rubber hose attached to it. Make sure that hose in good before replacing the switch. clay58_1.png
Posted on Nov 14, 2010
My D55141 heavy duty 2gal (7.6L) 150 psi max builds pressure up to around 150 releases pop off valve then keeps running, what causes this problem?
The pressure switch is either out of adjustment or has failed. The compressor should shut off at a much lower pressure than the safety valve (~100 psi)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 20, 2014 | Air Tools & Compressors
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Aug 27, 2012 | Porter Cable Air Tools & Compressors
My Craftsman 33 gallons air compressor can only get up to 50 pis. When i first got it the psi go up to 150. I just bought a new pressure switch and it still the same. The motor run none stop and pressure...
hi,
one thing that would be worth checking is the pressure release valve which is usually located on the bottom of the unit. This valve is suppose to be used each time the unit is turned off. For obvious safety reasons you should release the pressure from the tank each time you are done using it. If this valve is leaking or was left open then you will not be able to achieve the desired full pressure. Just checking if this is tight may be your solution! Hope this helps!
Aug 29, 2011 | Craftsman 33 gal Air Compressor 6 hp...
T30 model 242 Safety relief valve pops off at 50-60 lbs pressure. Put on a new one and still the same problem. Don't know what to look for next. Normal cut out is at 150-175. Thanks
From want you are describing sounds like the high pressure valves are leaking in the HP Head. there are 2 safeties on this unit . If the safety that's lifting is between the low and high pressure cylinders it's hp valves leaking. If the tank safety is lifting at 50-60 psi It should be replaced. It is a 200 psi safety.
May 26, 2011 | Ingersoll Rand TS4N5 Ir Electric...
I have a Dewault D55141 air compressor that runs to 150 lbs of pressure and blows the valve and releases air. I bought it new about 2 yrs ago? What needs to be done with this problem? I noticed on this...
Hello;
150 is your cutout pressure. It's the factory setting and is not a problem. But, It appears you have a pop off (safety) that is set for 125 psi, So, If you want 150 psi, the pop off needs to be adjusted. If you want 125 the the cut out switch needs the adjusting. The setting. More than likely the 125 psi pop off valve is correct and the switch needs to be adjusted down below the pop off pressure. To sdjust the switch, remove the cover of the box the cord comes out of.Adjust using the screw(s). There should be one for cut in and another for cutout pressuressures. The cut in pressure should be 90 psi and the cutout should be at 125 psi.If the pop off valve blows off at 125, It needs either replace or adjusting. It's best to replace it.since the spring inside has lost tension. You will be constantly adjusting it otherwise. Good Luck -Ned_ Take caution not to get your tool or fingers into the electrical in the switch box.
Apr 15, 2011 | Dewalt & 2HP Hand Carry Heavy Duty...
Can I limit the pressure to 120 PSI, the upper recommended limit for my nail gun?
adjust your pressure switch on your compressor .remove the cap and turn the screw clockwise to increase and counterclockwise decrease.turn the screw counterclockwise a bit and release some air till the compressor start pumping.then just before to reach 120 psi turn counterclockwise to stop the compressor at 120.then release some air again till it cuts in again and look at what pressure it will stop.keep going that way till you get your 120 psi.cut in should be around 90 psi(30 psi differential)depending what kind of pump you have (if the pump can handle 150 psi )you can adjust it to cut in at 120 and cut off at 150 and install a pressure regulator adjusted to 115 to 120 and get a nice steady pressure going to your nail gun.(the best way to do it!!!)
Jan 17, 2011 | Air Tools & Compressors
My husky air compressor is suppose to shut off at at 125psi
Pressure switch may be stuck. May need to adjust pressure switch.
May 27, 2010 | Air Tools & Compressors
Air compressor's safety release valve pops open.
You need to replace the pop it valve with a preset on. they are cheap and readily available. You could adjust yours with a proper steup. But it may need new parts just replace it.
Nov 28, 2009 | Northstar Electric Stationary Air...
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
638 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
