Female end of antenna connection is broken off inside the card. can this be replaced? if so what will be the cost.
  • 8,617 Answers
Whats the model number of your set? I would have to know that in order to even begin to help you out with your problem
Posted on Jun 18, 2008
Where can you purchase a replacement antenna for
I just replaced my broken antenna for my CFD-S350 by calling Sony Parts and Support at (239) 768-7691. Cost only $7.99 and that included the $2.00 shipping charge.
Jun 03, 2010 | Sony CFD-S350 Radio/Cassette/CD Boombox
My radio antennae does not work. I hear a
the cable inside that moves the antennae is broken. on many models you can just replace the antennae with cable instead of the entire unit whick will be a lower cost. ask at the volvo dealer.
May 15, 2010 | 1995 Volvo 850
No reception
your antenna connection inside the unit is broken on the circuit board,i had one of these and repaired it numerous times by taking the unit apart and resoldering the connection at the board,also their antennas don't last long as far as the antenna plug end is concerned
Apr 30, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
On the Magnavox ZV427MG9 A, there is not an antenna in and out connection slot; how does this unit work without that?
My TWC connection is a female onto a male. The Magnavox Model
ZV427MG9 A does not allow the cable connection to screw on to it's terminal. Is there an adaptor with a female connector on one end and a male adaptor on the opposite end.
Nov 11, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Is there an antenna inside the hp note book dv 8113 cl. I am having trouble picking up wireless services and and my other hp zv6000 is picking them up just fine side by side the reason I ask I had my other...
These laptops are hit and miss wirelessly to tell the truth. Take the wireless card out and make sure the antenna is attached to the card properly. You will see the two wires. Often times one fo these connections is broken. If so reattaching the antenna will solve the weak connections.
Nov 08, 2009 | HP Pavilion dv8000z Notebook
Female end of USB broken inside external hard drive
try opening it up, screw loose the connection with your usb (the whole component) and then directly plug it into your computer with the plug that goes into harddrive:)
Apr 03, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
2000 Ranger seat belt female end will not except male end
LOOK INSIDE THE FEMALE RECIVER AND MAKE SURE THERE IS NOTHING IN THERE. EVEN SOMETHING SMALL CAN MAKE IT SO THE RECIEVER WONT CLICK INTO PLACE
Nov 27, 2008 | 2000 Ford Ranger SuperCab
Sirius Antenna
There are several ways to tackle this problem, most of which would involve getting to the back of the radio, but before you do, make sure you have an "antenna extension cable". Then plug in the 'extension cable to the radio/sirius unit' leaving the other end to 'hang out' where you can then get access to the 'extension' cable. Then you can plug in the existing antenna when you're not using the camper or plug in new antenna that gets clear view of the satellite. Depending on your location and general direction of travel you may be able to use a 'home unit ' antenna on your dash as I do and it works very well. In my truck I often use a home antenna also, although I also have the large unit that bolts to the (tractor) truck mirror assembly.
The other solution is to find a CB repair place (often at truck stops) that is familiar with repairing, satelite antenna wire and pucks. Have them split the wire and place a male and female plug to accomodate the extisting antenna and the new antenna. This service will cost you about $30-50.00 They should find the parts needed at a satellite radio store that sells marine/business/home antennae systems. The parts are not all that common - or the CB fellow may connect male/female connectors that are unique to your truck situation - then any connectors will work but only on that truck of yours. -- Frank
Sep 15, 2008 | Audio Players & Recorders
Radio cable length from rear aerial
no - the factory cable is a one piece cable to the radio- what you can do is to cut off the end that went to the original antenna replace it with a female antenna end and just plug the new antenna into it (easiest way)
Mar 24, 2008 | Car Audio & Video
Televison & Video Logo
Top Televison & Video Experts
