Question about Meade DS114AATE Telescope
Image is upside down - Meade DS114AATE Telescope
    Novelist:
    Champion:
  • 227 Answers
Telescopes present the image upside down. There is no up-down in space. You can buy a erect prism adapter for terrestrial use A prism can not be used for astronomy since it reduces contrast but fine for daytime (nature watching) use
Posted on Nov 15, 2010
Why when I look through my telescope it's upside down
The image in astronomical telescopes are naturally upside down. This can be corrected using an inverting eyepiece . The reason this is the case, is that normally when viewing astronomical objects it doesn't matter if the image is upside down, so to minimise the loss of light that is the more important issue, unnecessary optical surfaces are eliminated. Terrestrial telescopes do naturally have inverting eyepieces as people expect to see objects the right way up.
Getting and inverting eyepiece will be cheaper the changing telescopes! :) Your eyes see everything upside down too, but your brain turns the image the right way up. The image in cameras is also upside down at the image plane, but the electronics turn it the right way up for you.
Jan 02, 2015 | Optics
Why would the images be upside down
All astronomical telescopes show the image upside down. For terrestrial use, you need a erect image prism.
Jun 01, 2014 | Tasco Optics
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
How do I get the image to turn the right side up? When we first set it up the image was right side up for a few minutes and now it is upside down and we can't figure out how to get it to flip. The image is...
Dopn't worry about upside down. All astronomical telescopes show images upside down. There is no up or down in space.
You may have what is called an "erecting" prism diagonal that turns the image right side up. Just Google "erecting prism diagonal".
This may also help you.
http://www.cloudynights.com/item.php?item_id=810
Dec 27, 2009 | Edu-Science (10166) Telescope
Upside down images on my telescope. Bought used -no manuel. What to do?
In a refractor images are upside down as with most telescopes. You need an image erector to create a normal correct R and L and Up and Down image. It is a lens which goes in front of the eyepiece to give a correct image.
Jun 01, 2009 | Fieldvision 114mm Reflector (114 x 114mm)...
How do I correct an upside-down image?
Normal 0 Try this, while the computer is running, unplug the camera from the USB Port , wait a few seconds and then plug it back in. I have fixed several cmaeras that were upside down that had the same problem by doing this.
Worth a try.
Hope this helps. Bud
Mar 24, 2009 | Computers & Internet
Open Questions:
Is it a Webley or a Eley Colt .455? How to tell if the cylinder bore has been modified to accept Colt 45 or other ammunition. Obvious the barrel (8" smooth bore) and sights were replaced Please help an ole man out that happens to know "Nothing" about Colt Double Action Revolvers... At 66 I guess it's never to late to own a Colt! Is it a Webly or Eley .455 ? and How can I tell if it's been reworked to accept Colt 45 ammunition? As many details as I have are below. Any body know just what I have here? I think I have a 1914?? British .455 Colt New Service Revolver. Has some standard factory Colt proof marks along with British proof marks. Colt logo above the grips on the rear left side of frame, VP inside a triangle on the front left side of trigger guard, and a #3 on the rear of trigger guard same side. Has had the orig. barrel replaced with a stainless steel 8" smooth bore pinned barrel. British proof marks on 3 different places on the revolver. On the breech area, the rear of the cylinder, and inspection and acceptance markings On the left rear of the frame (just below the hammer). Broad arrow government acceptance mark on top. Under that is a Crown Under that is F9 E Bone grips that look like they are orig. also. A large #7 is stamped "under" the serial number at the crane too, and the grips are also marked with the #7 in pencil underneath on both grips. On the left side of the frame under the grips is stamped the capital letter "E", so I know originally it was chambered .455. Highly polished mirror like blue finish on the original frame. Has a lanyard swivel on the bottom of the frame and has "No markings, lettering or numbers on the frame"by the lanyard swivel. Any Help/Feedback is Greatly Appreciated Thanks in Advance!
Nov 19, 2017 | The Optics
See all Meade DS114AATE Telescope Questions
Meade DS114AATE Telescope Logo
55 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
