Question about Inverter KEB COMBIVERT F5
When inverter fitting, some parameter are set please name these parameter
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • Inverter Expert
  • 120 Answers
What F5 inverter are you asking about? There are many different control stages and each has different default parameter settings.
Posted on Jan 14, 2014
Sir i have keb f5 inverter i need default parameter i am trying to external run but i do not have parameter.
There are over 1500 parameters in the inverter. These have been setup by the manufacture of the machine so that the machine functions the way it was intended to in a safe trouble free manner.
Before one defaults the inverter you should always use the COMBIVIS software to obtain a complete upload of all the parameter values. This way you can always get back to the settings before the inverter was set to default.
Also with the COMBIVIS software you can access all the parameters in the inverter. With the software the Fr parameters are where you would find how to reset the inverter to default values.
Dec 11, 2013 | Inverter KEB COMBIVERT F5
Hi, We have KEB F5 inverter on our machine model
If you are connected to the inverter with COMBIVIS, go to parameter FR.01 and enter a value of -4. This will set all parameters back to factory default.
You may be having an issue with the inverters software verison. As long as the inverters are the same part number, you should be able to download the parameters without any issue. There may be some unknown parameters but you should be able to hit ignore and keep on downloading.
Oct 26, 2013 | Inverter KEB COMBIVERT F5
Hi, I have KEB 07.f5.c1b-3b0a inverter. I just got
Via Combivis, write a value of -4 to Fr.01. This will set all parameters back to the factory default values.
Then download your backup parameter file.
Sep 24, 2013 | Inverter KEB COMBIVERT F5
Internal program error
There are many differences between the F5-C control and the F5-B control, but basic functionality is the same. Just looking at the control terminal strip will show you some of them.
You also have two physically different sized inverters. The C control is in the G housing and the B control is in the E housing.
Sep 04, 2013 | Inverter KEB COMBIVERT F5
I use KEB 18.F5.CBG340A (22,0 kW) "Compact"inverter , to run this inverter whose parameter must be set from cp mode and application mode
The CP mode parameters are a small list of parameters that are mapped from the application parameters. Not knowing what you are trying to do with the inverter, it is very difficult to tell you what needs to be programmed.
90% of the machines that us the KEB inverters use the application parameters to gain the full functionality of the inverter.
The machine manufacture whom built the machine that the inverter is installed in should be able to provide you with parameter settings.
There are instruction manuals on the KEB site.
www.keb.de
www.kebamerica.com
I fit a new keb f5 inverter which parameter set to run motor
Pretty general question. If it is a replacement inverter, best source would be to upload parameter values from original inverter with the COMBIVIS software.
Otherwise I would suggest downloading the manual from the KEB web site.
Aug 24, 2013 | Inverter KEB COMBIVERT F5
How to set keb f5 compact to work with analog input wich parameters must be set and what is position on x2 that start the inverter
Please see link below for instruction manual.
F5 G/C/B manual
Basic default functionality of the inverter out of the box is to run via analog input.
Jun 07, 2011 | Inverter KEB COMBIVERT F5
Hello I'm use keb f5 inverter. I have to return to the factory parameters. How I'm do it?
It is strongly suggested to contact the OEM of the machine that this inverter is being used on to obtain the actual parameter settings that are required.
Oct 11, 2010 | Inverter KEB COMBIVERT F5
My name is rall i have a siemens micromaster ac drive .37kw single phase and it working with one siemens plc s7 ,plc send analoge signal (4-20ma) to it for running but it dosent run. but in local mode its...
jst chk out the connection of the plc and find that the resistence of 500 ohms linked with 10v which converts 10v to 4-20ma is working if it is then it will work or check the drive's connection n parameters of P1300 & communication parameters
Dec 13, 2009 | Inverter Siemens Micromaster 440
Inverter KEB COMBIVERT F5 Logo
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
