Question about Keurig B100 Coffee Maker
My Keurig makes a growling noise when the water is transfered to the heater.
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
Keurig giving system overheated error
That unit uses air pressure to move the water. When no water is transferred to the heater, the unit stops. This could be an issue with the water reservoir or the pump. Since you did not post the model number it is not possible to advise you further .
Feb 08, 2017 | Keurig Coffee Makers & Espresso Machines
I have an 08 Jeep Liberty.Whenever the traction control kicks in it makes a growling noise.Any ideas what this could be?
The "growling " noise that you're hearing is the ABS pump being activated. Anytime the Traction Control System is activated or detects wheel spin/slippage, the ABS module will activate the pump because of the wheel speed variations. It is nothing wrong with the vehicle unless the TCS or ABS lights come on and stay on.
Mar 03, 2015 | Jeep Cars & Trucks
When started, dishwasher making growling (hungry stomach) noise before filling with water
That would be your pump priming, however I would check the sump or filter in the bottom sometimes they get debris caught in them. Some have a filter others have a screen.
Jan 07, 2015 | Dishwashers
What is the growling noise coming from my 94 civic motor
Water pump or pulley most likely.
Always replace water pump and pulleys when you do the timing belt.
Also you may have overtightened the belt.
NOTE, Kevlar belts will make a "whirring" noise for a few thousand miles after replacement, but not a growling.
Dec 29, 2014 | Cars & Trucks
The machine worked great until it decided to just sit there and make growling noises. The descale light did not come on but I tried to descale it and it still just sits there and growls. We really miss...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 19, 2011 | Keurig B60 Coffee Maker
My Keurig small machine will only let a small amount of water thru and then the blue light comes back on. when I push the blue light ..it just growles
heatman101
Jan 05, 2011 | Keurig B100 Coffee Maker
I have similar problems to a number of others here do- the water does not always heat up, it stops dispensing the water, it makes a loud vibrating noise, the water sprays out in all directions and it is...
They replaced my entire unit when my heater stopped working and the unit would auto power off after trying to heat up the next batch of water. I would contact Keurig and see what they will do for you.
Contact info from their website.
Phone:
1-866-901-BREW (2739) Representatives are available 7:00 am to 12:00 midnight EST, 7 days a week Fax:
1.781.245.1869 Mail:
Keurig, Inc.
At Home Customer Service
55 Walkers Brook Drive
Reading, MA 01867
Feb 06, 2010 | Keurig B60 Coffee Maker
Fridgidare affinity washer will not spin, makes a growling noise
use a shop vac and attach it to the end of the drain hose remove all the water then you need to check the drain pump and see if there is anything blocking the pump.
Sep 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
The water does not enter the dishwasher
front left inside the dishwasher. see if the wheel of the rack is still on. Happened to me
Apr 05, 2009 | Bosch Dishwashers
Keurig B100 Coffee Maker Logo
1,670 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
