Question about Garden
Sperry dm-350a operating manual - Garden
5 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: checking batteries AA D cel with a sperry DM 350A digital multimeter
dc .... no lower then the voltage range of the highest voltage of the battery.
Posted on Sep 14, 2008
  • 30 Answers
I assume a "DM-350a" is some kind of a digital multimeter. I Googled and found it might be a "A.W. Sperry DM350A 5 Function 17 Range Digital Multimeter" and looking at the ranges available on that meter, you can't really thest the battery "under load" the only reasonable way to test small batteries. the DC current only goes up to 200 milli amperes. A "C" or "D" size flashlight battery puts out 1 to 4 amps depending on conditions. That's 5 to 20 times the current readable by that meter. The volts on one of those batteries is probably 1.6 volts to 1.3 volts etc. If you live in the United States, I'd say go to Radio Shack and spend $5 to $15 and buy a battery tester like "Enercell Analog 9-Range Battery Checker, $14.99, Model 22-156, catalog # 22-156"
Then you and anyone in your family can read the instructions and test 8 or 9 different type batteries. Battery types: 1.5V button-cells, "AAA"/"N"/"AA"/"C"/"D", 6V, 9V, 12V, 15V and 22.5V..
This is not supposed to be an advertizement, and I have no interest in RadioShack,... but it's supposed to be instructional.
Small price, Good instruction to anyone who can read, and if anyone forgets, they can re-read. Testing a lot of batteries in a sitting goes very fast with these.
Differently, with the sperry, or any voltmeter, you'd have to select a resistor small enough to draw the current, and large enough not to overheat or burn, connect it and measure the loaded voltage drop, compare the voltage and current of the loaded battery, and compare it to that of a new battery, and a battery you might consider too weak for your application.. Voltage equals amps times resistance, and power equals amps squared times resistance... Really, buy a battery tester.
Regards --- GooseBay_Camper
Posted on Sep 28, 2009
SOURCE: I just brought a sperry dm-350A to test the
Just got mine from home depot. Stick the black wire into the COM port and the red wire in the V port on the right. The red wire is the positive and the black is the ground. Touch the red tip to the positive and the black one to a ground. Turn the dial clockwise to the right and you are measuring your voltage(i left it on 200).
Posted on Jan 31, 2010
SOURCE: Does the Sperry DM-350A test
yes. But you have to change the LEADS down below. One must connect into the Omega connection at the bottom (looks like an upside down horseshoe). And the meter setting is where the arrow (?) symbol is. Touch the two leads together and it should "zero out". Now you're ready to check continuity.
Posted on Dec 11, 2010
Testimonial: "That was helpful. Thanks."
Changed battery on Sperry DM-5300 and now it will not power up
Try it again, with a new, tested battery.
You likely installed a "dud" (or put it in backwards?)
Jan 23, 2015 | Televison & Video
Volt meter
If you've never used a volmeter,Google it.There is a lot of info for free.
Jun 13, 2012 | Televison & Video
I need the operators manuel for the Uniden BC 350a. The serial number is 85034009
  • Hello and thank you for the opportunity to assist you. You here is a link to the manual requested [ Uniden BC 350a ] http://www.usascan.com/pdf/BC350A.pdf This is not a link to a site where you have to search around this is a link right to the manual.
  • That's a very nice choice in scanners. If you have any other questions please feel free to contact me here. If you are satisfied with my service then please do leave a comment so that others know of my quality work. I also apologize for the slight delay. For some reason this came through before I got online for the day.
  • Hope this helps.
Regards,Tony
Oct 31, 2011 | Uniden BC350C Base Scanner
Does the Sperry DM-350A test for continuity? I can't seem to find a setting that works.
Dec 03, 2010 | Measuring Tools & Sensors
Don't know how to use my Sperry outlet tester
http://www.sperryinstruments.com/documents/products/hst-401.pdf
Dec 15, 2009 | Sperry Instruments HST401 Voltage...
Checking batteries
Sep 26, 2009 | Sperry Instruments HST401 Voltage...
I just brought a sperry dm-350A to test the switches on my dryer I thought they would come with instructions on how to use it but it didn't. Is there a place where I can go and learn what the symbols...
Jul 11, 2009 | Measuring Tools & Sensors
Need an a.w. sperry dsa-7610a manual
It only came with a sheet of paper, operating instructions on each side.
I can scan and email you a copy - if you want one, please email your address to
ofgdad at yahoo.com (change the at to @)
Old Fat Guy
Apr 27, 2009 | Sperry Instruments HST401 Voltage...
Checking batteries AA D cel with a sperry DM 350A digital multimeter
Sep 06, 2008 | Measuring Tools & Sensors
Measuring mA with a DMM
The most obvious solution to your problem is that you may have the meter simply connected backwards. To make life easy, Groovetubes sells a thing called a bias probe that makes biasing tube amps a breeze.
Dec 27, 2007 | KEF Audio Cresta 2 Speaker
Garden Logo
240 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
