Question about Altec Lansing 5100 Computer Speakers
Altec Lansing 5100 Speakers - How Do I connect them?
I have a set of Altec Lansing 5100 speakers. I have connected each speaker and I am left with a yellow lead, a black lead and a green lead. I am puzzled and would like to know if anyone can advise me how I connect these to the back of my computer or provide a diagram to help me?
Many thanks.
Clive.
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
sandiiii
  • 17 Answers
SOURCE: Lost set up disc
go to the website of the company and just simply type the model no. u will get all the details and u can download a cd content too.....
Posted on Dec 03, 2007
SOURCE: Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
Posted on Jun 22, 2008
SOURCE: Compaq Presario v2000 ALTEC LANSING speakers not working
There is not driver problem. I can hear sound using headphones and no yellow exclamation next to the "Sounds, Video and Game Controllers".
Posted on Sep 24, 2008
edwinmeyer
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
No sound out of my Altec Lansing ADA 745. Computer Sound card is fine.
If other speakers are working, then 745 is defective or the volume switch is set to mute. Please check that, repair it if required.
Aug 27, 2012 | Altec Lansing Technologies Audio Players &...
Can I connect my Altec Lansing ADA745 4.1 speaker system to an Acer AS5745-7247 laptop?
Yes. Altec Lansing ADA745 4 Speakers can be connected to a laptop.
Make the connections as follows
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Altec Lansing ADA745 4 Speakers
No sound after i buy new PC ( speaker altec lansing atp3) should i install altec driver ?
check the port to which u have connected ur speakers. And also install proper driver
Aug 20, 2009 | Altec Lansing ATP 3W Computer Speakers
Just hooked up speakers. I am getting pings from computer but no
maybe you have a codec problem ...try open the video with VLC player ..ori install AC3 Filter
Dec 29, 2008 | Altec Lansing Multimedia Computer Speakers
Speakers for Altec Lansing 5100 system on and off
this is due to small mismatch on ur dell desktop with speakers, so remove it and try again
Aug 16, 2008 | Altec Lansing 5100 Computer Speakers
Vs4121 altec lansing left speaker wire ripped.
Black should be ground and red is usually the actual audio cable. If you connect them wrong the should not short. They will just sound weird until you connect them properly.
Hope this Helps
Thanks for reading!
May 02, 2008 | Altec Lansing VS4121 Computer Speakers
Altec Lansing 5100 Computer Speakers Logo
103 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
