Question about Kenmore Refrigerators
I have model #106.9751713 Kenmore top freezer. I has developed a loud shake when the compressor is turning off. I am assuming it is the compressor I hear when the fridge "comes on" What's up? Is my compressor going? If so is that an easy fix?
  • 183 Answers
SOURCE: freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Posted on Aug 21, 2007
peyton32034
  • 410 Answers
SOURCE: Loud banging noise and water leaking
first of all the noise is the internal compressor motor hitting the steel shell on shut down. in my experience this is annoying and not really a huge concern as far as the compressor dying any time soon. now your drain problem. i would recomend the wire or heat probe that whirlpool recomends. when your freezer defrosts the water that drips off of the coil can and will flash2.gif freeze in the drain area causing it to freeze up a peice of 10 or 12 guage solid copper wire run into the drain and wrapped around your def heater will transfer enough heat into the drain hole to prevent it from freezing up.
fwiw: whirlpool in my opinion is probably one of the best appliances on the market
Posted on Dec 16, 2007
  • 33 Answers
SOURCE: Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Posted on Jan 01, 2008
SOURCE: fridge compressor hot. inside of
how to install refrigerator compressor
Posted on Jul 04, 2008
localwonder
  • 6784 Answers
SOURCE: KENMORE SIDE BY SIDE COMPRESSOR KICKS OFF
HI. i would recommend to check the relay first, then the compressor last to confirm total failure. If both devices test out ok, this will lead to a failed main power control board.
THE RELAY
The compressor relay starts the compressor. A fault relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator. The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. On some units. the relay may not be covered at all.(each model may vary). Beneath the terminal cover(if equipped), you will find the compressor relay, and the overload protector as well. The electrical terminals of the compressor motor are located here also. Remove the compressor relay by pulling it straight off from the compressor, gently. Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing. Test the relay with a ohm(multimeter), for continuity. Set the meter to the ohms setting X1. With the relay upside down, place the probes into the terminals labeled "S" and "M"(the labeling may vary on each modle). The meter should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up). With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The meter should now display an ohm reading of infinity (or the tester should not light up). Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L". The meter should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity. With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M". The meter should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms. Now, if the relay fails these described tests, it should be replaced asap.
COMPRESSOR TEST PROCEDURE
The compressor is accessed from the lower rear of the refrigerator. Generally the same proximity of the relay. The compressor motor can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. The main testing points will be the actual terminal post that hold the relay, gently pull the relay of the terminal box on the side of the compressor, and use the relay holding probes for testing. Once the relay is removed, Place one probe on any terminal and then touch the other probe to each of the other two terminals. The multimeter should display a reading of zero ohms. Be sure to set your meter to 1X before beginning. Now move the first probe to a different terminal and test the other two terminals with the other probe. Finally, move the first probe to the last terminal and test each of the other terminals with the other probe. Every test should have continuity with the multimeter displaying zero ohms. If the compressor motor does not pass all of these tests, the compressor will require professional service. Now test the compressor for ground. With the multimeter still set to X1, touch one probe to bare metal on the compressor housing (it may be necessary to scratch away a little paint to expose the metal). Touch the other probe to each of the three terminals in turn. None of the terminals should have continuity; the multimeter should display a reading of infinity. If any of the grounding tests show continuity, the compressor will require professional service.
NOTE_ If both components test out ok, the culprit will be a faulty main control board.
Posted on Dec 03, 2009
Testimonial: "good advise. exactly what i asked for. thanks"
Loud banging every half hour or so. Loud rumbling as well. Usually the loud rumble starts once the door has been opened
Sounds like a broken mount for your compressor.
You'll need to look in the back of the unit and possibly remove a cover to access it
Being a Kenmore you should be able find most any part you may need by entering the model # at this site
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
Jun 01, 2011 | Kenmore Top Freezer Refrigerator
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Jun 22, 2009 | Kenmore 64802 Top Freezer Refrigerator
Appliance gives loud shudder periodically
The compressor rides on springs inside the compressor housing. Sometimes it can jump when it cuts on or off, no big deal.
Apr 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refridgerater shuts off with a bang
When you look at the compressor of a refrigerator, what you see is actually just an outer case. The compressor is inside that case, supported on four springs. If you give a compressor a shake (even a new one) you will hear the inner compressor part knock on the outer case. Sometimes, if a spring brakes or gets weak, when the compressor stops running, the momentum will then cause it to strike the outer case, causing a loud knock or two. Most refrigerators will work fine for many years if this condition occurs. It is a bit annoying, but the only fix would be to replace the compressor, which is generally prohibitively expensive if the unit is no longer in warranty. Please don't bother rating this solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Mar 15, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Kenmore elite refrigerator/freezer loud banging
it is compressor shutting off,not much you can do to fix it.you can try changing the snubbers that hold it in place but most likely you will still hear it clunk.
Mar 07, 2009 | Kenmore Refrigerators
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Noisy [like loud motor running] almost all the time--for about a week
when you state "it's the compressor running all the time", does this mean it hardly shuts off? if so need more freon
May 27, 2007 | KitchenAid KTRS22EM Top Freezer...
Refrigerators Logo
245 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
