Question about Maytag Dryers
My dryer keeps breaking belts this is 2 belts in less than 2 months what is causing this to happen
  • 413 Answers
Check the idler pulley, if not turning freely, the belt may have excessive friction against pulley wheel, overheating and failing. Or dryer drum seals may have failed causing excessive tension on belt.
Posted on Jun 18, 2008
Maytag LDE412 Drum Roller keeps breaking
perhaps your dryer vent pipe is plugged with lint and causing the inner parts to overheat .
Feb 15, 2016 | Maytag Dryers
Why does the belt keep breaking on my dryer model dvlr223ee2ww?
perhaps bad bearings either in the drum supports or the tensioner pulley .
Aug 30, 2015 | Dryers
Why does myMaytag de212 dryer keeps breaking belt
You must have installed the belt upside down. Remember the flat part must be to the drum not the ribs. Also assure you don't have a twist on the belt as it can invert during the running of the drum. Good Luck
Sep 19, 2014 | Maytag Dryers
Belts keep breaking after several repairs
make sure none of your pulleys are bent or loose and check the tention on the belt before opration cause while putting a strain on the motor with cause it the shift around a lil bit n if belt is to tight could possibly tear it
also check each pully the ensure they spin freely with no binding
Jul 12, 2012 | Cars & Trucks
My dryer is less than 2 years old and is only buzzing when I try to start it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 21, 2011 | Amana ALG331RAW Gas Dryer
Beko drvs73w dryer keeps breaking belts. Drum seems to jam at door end and motor contines to melt the belt.The bearings are good . The dryer is only 18 months old. Every time belt breaks when I investigate...
check your drum rollers/glides and your idler arm(it is suggested to change this with the belt), here is a website hope it helps,Tim:
http://www.partselect.com/dryer+inspect-pulley+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Mar 27, 2011 | Dryers
Hi, I have a Beko DRCT70W tumble dryer and the belt keeps breaking. I've replaced it twice in the last month, so I think there must be another fault with the dryer which is causing this. The drum...
hi folks the beko tumble dryers have a felt seal that runs along the front of the drum that wears through causing load on the drum, belt and motor causing the belt to melt and snap, replace the felt you will have no more issues, i got mine off of ebay pretty cheap
Feb 08, 2011 | Dryers
Hi, My model is WED5300SQ 6.5 CU FT S Whirlpool electric dryer. My belt keeps breaking. This is the third time within a 18 months. Are there any recalls or defects in this model? It's easy to replace;...
That belt ought not to break for 10 years. I use zoomspout oil because it is safe for dryers. Lube your rollers and idler and if your idler is a crappy one without the roller you needs to chunk that one.themobilian_1212.jpgthemobilian_1213.jpg
Check inside your blower for junk
I have a manual or 2 and some videos with more repair photos HERE
Jan 31, 2011 | Whirlpool WED5300S Electric Dryer
Belt Keeps Breaking
Maybe it cause a too tied belt.
Oct 03, 2006 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
389 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
