Question about Zanussi TD4112W Electric Dryer
Zanussi TD4112W Electric Dryer The yellow button to run the dryer at a lower temperature for synthetics was broken when the unit was relocated. It is now pressed and cannot be unpressed. The dryer now only runs at the lower temperature so cottons need to be dried for twice as long. Can anyone suggest how to access the button internally and 'unpressed'. We can then cover it with a card so that it is never used again. Thanks
    Problem Solver:
  • 4 Answers
Got to take lid off take off main power board thats only access
Posted on Nov 14, 2010
I keep asking but dont get answers help please
There is a video here on how to replace a belt on a dryer. I have done this before and most dryers are the same. You have to take them apart. It is not a real easy job. Hope this helps. Scroll down to the bottom of page to see video.
http://www.espares.co.uk/part/tumble-dryers/zanussi/td4112w/p/1088/332/0/553236/501196/tumble-dryer-drive-belt.html
Dec 02, 2011 | Zanussi TD4112W Electric Dryer
I have a Zanussi TD4112W dryer and it works fine apart from the fact that only half of the element heats, I have checked there thermostats and they seem fine 2/3 ohm at cold and o/c at high temp. Also the...
sounds like you know what you are looking for, here is a website that may help you, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 30, 2010 | Zanussi TD4112W Electric Dryer
I have a zanussi td4112w. My washing takes nearly double of time to dry as it used to. What should i do?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 17, 2010 | Zanussi TD4112W Electric Dryer
My dryer wont spin.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2010 | Zanussi TD4112W Electric Dryer
Td4112 which way does belt fit around drive and
check the drive it should have grooves on it. that means that the belt grooves should go around the drive and facing the drum. When you see the belt on the drum you should not see the grooves on the belt
Dec 31, 2009 | Zanussi TD4112W Electric Dryer
Zanussi Tumble Dryer - TD 4112 -Door Catch Assembly/Repair The plastic catch broke and I have bought a replacement however I can't work out how to put the pin, spring and catch back together. Any help...
Jason, I have the same problem... the catch on my Zanussi dryer has broken. I've ordered a spare part... and remembered how I took the thing apart.
I'd have to show you... it can't be put into words. LOL
Hopefully by now you've figured it out. (Just seen the date you posted this).
~ Franka ~
Aug 31, 2009 | Zanussi TD4112W Electric Dryer
Zanussi td4112w drum stopped spinning
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 19, 2009 | Zanussi TD4112W Electric Dryer
Reset button
your heating element may have burned out
Jun 17, 2009 | Zanussi TD4112W Electric Dryer
Zanussi TD 4112 W Not warming up
I've taken the back cover offf the dryer and found a burnt connection to the heating element. Will try and repair.
Oct 14, 2008 | Zanussi TD4112W Electric Dryer
Zanussi TD4112W Electric Dryer Logo
94 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
