Question about Car Audio & Video
I have a 2007 Chevrolet Colorado with the Premium radio. Radio works fine, but when inserting CD, it pulls it in, but then stops with about 2 inches still protruding.....consistently. I can hit eject and it comes back out, but will not pull a CD in any further. I have unhooked the battery to reset it, but that hasn't helped. Any advice would be appreciated.
    President:
  • 749 Answers
This is a physical defect that would require to pull out the CD player - most likely.
Sometimes - but very rarely - it may be caused by another CD still in it, which you can see if you use a small screwdriver or something similar to raise the protection plates at the slot where you put in the CD and inspect inside.
SOmeties you may be even able to see what;s actually blocking it - CD or bent plastic - and using a longer screwdriver either push it gently in place or help it get out.
Most of the time, though, you end up having to take the CD player out and open it to restore the mechanical functionality.
Posted on Nov 14, 2010
Need to change 20 Amp fuse in Position 11 in fuse box of 2007 Dodge Ram 1500. It's a mini-fuse, but is encased in a plastic insert (almost normal fuse size). Insert pulls about 1/2 inch out and stops. Is...
yes there is a special puller usually located in your fuse panel it will look like little plastic scissors if not if your carefull needle nose pliers will work good luck
Dec 09, 2010 | Dodge Ram 1500 Cars & Trucks
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
Oct 03, 2010 | 2005 Chevrolet Trailblazer Ext
I have a 2005 chevy colorado and about 2 years ago the CD player stopped working (never got around to looking at it), it takes the CD but does not play and will not eject it unless i use something very...
The lights are not repairable.The cd problem can only be repaired by taking it to the dealership and what they do is an advanced exchange.This means they need to get the part number from your radio and order one for you and when it comes in they swap your for the new one and they program it.The new radio has to be programmed or it will not work.The radios come from out East from a factory certified repair dealer.The dealership that I worked at used United Radio.There are some others.But that is how it usually works.Hope this helps.Good luck.
Mar 31, 2010 | 2005 Chevrolet Colorado
How to remove the car stereo from 2007 Chevy Colorado
This is not hard but tricky because the trim plate around the radio has clips that hold the trim plate very tight.Use a plastic type flat tool or flat screw driver wraped with tape or a shop rag to avoid damage to the plastic trim and pry the trim panel around the radio loose. remove all elec connectors.Then remove the screws that hold the radio in place and remove all elec connectors.
Jan 30, 2010 | 2007 Chevrolet Colorado (Extended Cab) New...
Cd player for 2005 chevy colorado wont work but the radio works
THERE ARE RADIO EXCHANGE PLACES YOU CAN PULL YOURS OUT REAL EASY AND FOR LIKE $75-$100 YOU CAN EXCHAGE IT FOR A WORKING ONE THATS YOUR BEST BET? SOUNDS INTERNAL LIKE POWER SWITCH MELTED
Aug 24, 2009 | 2005 Chevrolet Colorado
2005 chevy colorado cd problem
Try resetting the radio, turn the radio off and disconnect the battery for 30 seconds. Make sure the RADIO IS OFF OR YOUR GOING TO BE ASKED TO ENTER THE RADIO CODE TO HAVE THE RADIO ACTIVE AGAIN. After the battery has be reconnected, turn on the radio and reset your clock and stations. Your CD plays should be working again too. Good luck and hope this helps.
Jun 15, 2009 | 2005 Chevrolet Colorado
Brake Lights are not working on 2007 Chevy Colorado
Both my rear brake lights went out at the same time. o7 chevy colorado. What are my options?
May 28, 2009 | 2005 Chevrolet Colorado
Colorado Instrument panel lighting
The bulbs plug into a printed circuit board, I suspect they have come loose, pull the cluster and see if they are loose or burned out.
Oct 26, 2008 | 2006 Chevrolet Colorado
CD Player Won't Take My CD's
Try to pull the 2 radio fuses in the inner fuse block for 10 min. If problem persists, it is internal to the radio.
Sep 05, 2008 | 2004 Saturn ION
2004 Chevy Colorado
i have a 2005 colorado it was in a accident the radio comes on but it does not pick up any chanel and thegas gauge does not work
Jun 02, 2008 | 2004 Chevrolet Colorado
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
