Question about Maytag PYE2300AY Electric Dryer
My maytag performance dryer model pye2300ayw will start drying and then it stops, I have to wait for it to cool down before I can start it again. Would it be the thermostat or some other problem?
    Problem Solver:
  • 4 Answers
Thermostat
Posted on Nov 14, 2010
Does a kenmoore 80 series have glides
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-PYE2300AYW/3048/0151200?pathTaken=&prst=0&shdMod=PYE2300AYW
go here and you can see the parts in your dryer,if the model isn't a maytag pye2300ay then just put your model number in there and it will show you,kenmore doesn't make anything,you go by the model number if it starts with 110. it's a whirlpool,if say 417. it's frigidaire made but the maytag model you sent has rollers and i would say if you have a kenmore 80 series it has rollers,you can buy a kit that comes with the rollers,belt and belt pulley
Nov 14, 2013 | Maytag PYE2300AY Electric Dryer
I have a Maytag Performa model #PYE2300AYW dryer. The issue I'm having is the dryer stopping all together midway through the drying cycle. You can get it to start back up by pushing down on the selector...
Yes, you can have a few different issues going on with your dryer and it may be hard to pin down. 1. You may have a intermittent door switch. I've seen this many times. 2. You may also have a motor that is tripping it's overload. 3. You also may have a timer issue. This may be difficult to fix on your own so you may want to call a pro. If it was me, I'd check the door switch or replace it. If it's not that, you may want to consider a new dryer due to the high repair cost. Hope this helps,
Jul 31, 2010 | Maytag PYE2300AY Electric Dryer
Maytag dryer model PYE2300AYW dryer runs gets hot stops. when I try to turn it back on it makes a noise and won't start back up. What could be wrong?
It sounds like your motor is bad. you could take the dryer apart and clean off the lint on the motor and see if that helps but it sounds like i said the motor is faulty.
Mar 24, 2010 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
Dryer stopped running with 30 minutes left and will not restart. Maytag Performa PYE2300AYW
Reset the circuit breaker for the dryer. Allow the motor to cool, It has over temperature protection that will shut down the motor.
The belt that turns the drum may have broken. I am not sure about this model, but most dryers have a limit switch on the base of the dryer next to the motor that shuts down the dryer when the belt brakes.
Dec 15, 2009 | Washing Machines
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
Maytag Dryer quit working mid cycle
sounds like the timer,the only thermal fuse i know of is to protect from overheating which cools and resets itself
May 10, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
149 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
