My washing machine has come up with a CFL code on the led display what dose this mean. many thanks
    Problem Solver:
  • 4 Answers
What part of the cycle did it do this sorry you need to be more accurate
Posted on Nov 14, 2010
What dose it mean AE6 error code in Samsung wash machine
SAMSUNG WASHER FAULT CODES: AE or AE6
SAMSUNG WASHER ERROR DEFINITION = communication errors sub and main PBAs - main and inverter PBAs
AE and AE6 represent communication errors between the sub and main PBAs or the main and inverter PBAs.
HOW TO REPAIR/CLEAR ERROR?: If either of these errors is displayed, troubleshooting is needed or service is required.
http://removeandreplace.com/2016/06/15/samsung-washer-quick-troubleshooting-guide-error-code-definitions/
Feb 17, 2017 | Samsung Washing Machines
Tip
Decoding Fisher & Paykel Electronic Washing Machine Fault Codes
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stand as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4, 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13 which is a pump fault.
Once the code is determined, search the web for the meaning and indicate it when requesting for an online assistance to facilitate a quick and precise response.
on Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
My fisher & paykel smart drive excellence 7.5 washing machine squirts water in a few times and then stops and beeps and displays 3 lights red orange and (short wash) green as well as low and med speed...
Although slightly unclear these are the only possible error combinations for the leds on the machine as you look at it with red always on the end right hand side.
(11) 1011 (Green - nil - Orange - Red) - pressure problems perhaps a blockage in the tube to bowl.
(13) 1101 (Green-Orange-nil-Red) - pump is faulty
(15) 1111 (all lights on) - display module is faulty
I do not recall that the leds across the spin speed actually means something.
Good luck
Jun 06, 2011 | Fisher and Paykel Washing Machines
Machine will not work and displays "CL" in the LED display.
The "CL" code is not an error code it means Child Lock. Try pressing the buttons together for a few seconds. This is the child lock display.
Or press for over 5 seconds. Another option is press till the light goes off.
Mar 26, 2011 | Washing Machines
Spin Led stays on and beeper beeps
this spin light that is on is a fault code no:1 which means the electronic motor control has a memory problem solution replace motor control module ... hope this helps..:0)
May 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
EFO displayed on my machine while running and beeped.
EFO is not a Kenmore Error Code.
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2009 | Kenmore 44102 Front Load Washer
Indesit wie157 washing machine. led displays error code "door", ive bought a new interlock and replaced it but it still wont work, what is wrong? thanks paula
Make sure the door is positively latched in.,some times a weak or broken door spring or striker is the cause of the problem, if you are satisfied these are o/k, then it is probably a control board problem, and you will probably have to call an engineer.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Indesit W 123 Front Load Washer
Wont spin
Try new brushes in motor you must clean armature.The brushes are worn.
Dec 28, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
