Question about Sportsart 6300 Treadmill
Hi i m having sportsart 1288 and display is showing error 1 , i have cleaned the motor carbons and speed sensors and also changed the mosfet(gw20nb60hd) and two functinal ic. but same problem is appearing on display
3 Suggested Answers
SOURCE: my sportsart 6150 treadmill gives an error code 1
I would say that it could possibly be a speed densor fault as error one means loss of speed signal!! If the mat moves first then error one shows i would change sensor before changing anything else, if the mat does not move it could be a lower control board fault.
Posted on Feb 22, 2010
ercupa190
  • 12223 Answers
SOURCE: Started making a burning smell, then a cracking noise from inside the motor/unit and stopped. Treadmill now shows error 1
LUBE THE deck belt very well this happen because the schedule lmaintenance. Maybe the deck belt is worn and need replace it
2( LUBE the rollers bearing too. very importante.
3( test the input voltage motor, if there are the motor need repair.
4( test the output voltage board, for input voltage motor, if there are NOT, the board is faulty.
God bless you
Posted on Oct 04, 2012
Sportsart 1050l gives error 1
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
Aug 01, 2014 | Sportsart Exercise & Fitness
What is E-1 error in Sportsart Tradmills
Jun 23, 2014 | Sportsart Treadmill Doctor Walking Belt...
E01 sports treadmill
This link is to the service manual. You will find error code definitions and troubleshooting flowcharts.
Apr 12, 2014 | Sportsart Exercise & Fitness
Sportsart 1080 treadmill error 01
Mar 17, 2014 | Proform Power 1080
My treadmill showing E1 error code
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Tes the s. sensor for open or faulty. Clean it + tight the connector very well and try again. see the diagram for adjust.
God bless you
Feb 04, 2013 | Quantum Exercise & Fitness
Error #e-1
Error 1 come up when the drive motor is not moving. Unplug unit then remove motor shroud then plug unit back in and you will see a circuit board with multiple lights. On Lower portion of the board you should be able to see a amber LED this is your speed sensor light . To test the speed sensor just manually rotate motor fly wheel ( where Drive Belt is visible) and you should be able to see the amber light flickering that means speed sensor is good. Next thing to do is unplug unit and check the motor they sometime get stuck in their chamber so be gentle pulling them out and blow out the excess carbon material out of motor wear a mask when doing the black dust can be much then re assert motor brushes and it should take care of problem. If they are worn (less than 3/8 in. in length) then call Sports Art @1-866-709-1750 the people their are good to work with and any further question they will be able to answer.
Feb 27, 2010 | Sportsart 6300 Treadmill
SPORTSART 6300 SHOWING E 1
Feb 11, 2010 | Sportsart 6300 Treadmill
My sportsart 6150 treadmill gives an error code 1 when the speed button is pushed. motor moves slightly but then gives error code 1. thanks.
Jan 23, 2010 | Exercise & Fitness
Hello I own a sportsart 6320 treadmill and I do not have a manual. It is reading err 1 and I do not know how to fix this problem could you help me please and thanks
Error 1 come up when the drive motor is not moving. Unplug unit then remove motor shroud then plug unit back in and you will see a circuit board with multiple lights. On Lower portion of the board you should be able to see a amber LED this is your speed sensor light . To test the speed sensor just manually rotate motor fly wheel ( where Drive Belt is visible) and you should be able to see the amber light flickering that means speed sensor is good. Next thing to do is unplug unit and check the motor brushes they sometime get stuck in their chamber so be gentle pulling them out and blow out the excess carbon material out of motor wear a mask when doing the black dust can be much then reassert motor brushes and it should take care of problem. If they are worn (less than 3/8 in. in length) then callSports Art @1-866-709-1750 the people their are good to work with and any further question they will be able to answer.
Dec 17, 2009 | Startrac Fitness Products Star Trac 3900...
My treadmill is showing E1 on monitor of machine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Thanks.
Jun 23, 2009 | Sportsart 6300 Treadmill
Sportsart 6300 Treadmill Logo
162 people viewed this question
Top Sportsart Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Steven's...
Steven's...
L Pfaff
L Pfaff
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
