Question about Oregon Scientific RM983A Radio Controlled Alarm Clock with Thermometer
I have a KLIK Radio Controlled Thermo Clock, the battery ran out and I have replaced it with a new one, but the clock will not start up. Is there somewere I can obtain a manual for this sort of clock
SOURCE: Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Posted on Apr 13, 2009
SOURCE: Instructions to 'science museum' radio controlled alarm clock
press the alarm button (so the alarm time is on the screen) then the + button. do the same to deactivate the alarm.
it took me forever to work this out after losing my instructions, feel a bit of an idiot now it seems so simple
Posted on Mar 10, 2010
  • 71 Answers
SOURCE: global atomic radio controlled clock
It should automatically reset to the correct time. Try taking the model number and Google for an answer. Hope this helps.
Posted on Mar 16, 2010
SOURCE: Radio controlled clock model 6302000 - cannot
I have the same clock and had the same problem. My clock was a demo and had no instructions with it. Here is the solution:
1. Pull out the battery and wait 10 seconds then replace the battery. The satellite symbol should start flashing after a few seconds.
2. Put the clock outside or in a window sill till it updates. This could take a couple of minutes.
3. Press the Mode button once to enter programming mode.
4. Press the Adjust button as many times as needed to toggle through the time zones.
5. Press the Mode button once to exit programming mode.
Posted on Oct 08, 2010
SOURCE: i have a radio controlled clock they told me it
Hi Follow this link for a copy of the clock instructions http://www.precisiontimekeepingshop.com/WebRoot/Store3/Shops/es119696_es124040752439/4A01/ADE9/E32C/D6DB/8872/50ED/8971/B0A9/PREC0007_0020_Instructions_0020_copy.pdf
Posted on Oct 31, 2010
Needs new battery and will not adjust to new time
If it needs a new battery, replace it! With a new battery this clock should set it's own time. If it doesn't, there is a problem with the circuit and the clock will either need to be replaced or repaired.
Feb 17, 2014 | La Crosse Radio Controlled Atomic Clock
Clock runs only when horizontal
A bit of wd40 or similar in the working gears, they get a bit of something in there and clog, in kitchens they get fat deposits..
Mar 04, 2018 | La Crosse Radio Controlled Atomic Clock
Lacrosse radio controlled
If new batteries doesn't fix the problem, replace the clock
Dec 07, 2013 | La Crosse Radio Controlled Atomic Clock
I have a Shontek radio controlled clock. It ran fine for a couple of years, then the battery died. I install a new "Durcell" battery and it went through the motions of setting itself but was a...
Your radio should have come with a receiver of some sort for the radio signals to set itself. I had this same issue with my clock when the battery in the receiver died ... try replacing this too. It took me forever to figure out what it was because I had forgotten that it had its own radio receiver ... then once I remembered it existed, I had to find it, but replacing the battery fixed the problem. Hope that helps :-)
May 26, 2011 | Audio Players & Recorders
How do i replace the battery in a radio controlled clock?
look at the back part of the radio controlled clock then theres a label which indicates the symbol of the battery unscrew it if it is screwed but if not just simply slide the cover of it..then you can easily pull out the battery,,then buy to your nearest store because it is commonly sell,buy the same type of battery..after it just simply replace the battery to where you detached the previous defective battery..then put back in place the cover of it..then thats it your clock will resume to its normal functions.
Mar 09, 2011 | Seth Thomas Radio Controlled Wall Clock -...
My Klik radio controlled clock did not reset from British Summer time to GMT last night. How do I fix it?
Had exactly the same problem. Moved the clock to another room where I guess the signal was stronger and it started to set the correct time in about 2 minutes. Voila!!
Oct 31, 2010 | Vacuums
Apr 02, 2010 | NexxTech Travel Alarm Clock (63-8042)
Hands started spinning and won't stop. I replaced battery - still spinning
Remove the battery and replace with a new one. Just because.
Depress the tab on the back of the clock mechanism firmly (it pushes in a button beneath it) 22 times. While you're pressing the tab, the hands will begin to rotate. They will stop at 12 , 4 or 8 o'clock.
Place the clock in a window where it will be able to receive the radio signal.
Next morning the clock should have re-set to U.S. Pacific time. Press the on the clock mechanism that corresponds to your time zone and you should now have the correct time again.
May 24, 2009 | La Crosse Radio Controlled Atomic Clock
La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Oct 17, 2007 | La Crosse Radio Controlled Atomic Clock
SHARP ATOMIC WALL CLOCK RESET
I have a sharp 12 inch atomic clock...cant get it to reset and dont have instructions...please help
Oct 13, 2007 | Audio Players & Recorders
Oregon Scientific RM983A Radio Controlled Alarm Clock with Thermometer Logo
1,298 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Gyula Lacz
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
