Question about Western Digital (WD3200JS) 320 GB Hard Drive
Brand new hard drive and wd3200bjkt and the computer does not recognize it, I was told to change some settings in the bios and a certain combination will make it work, tried several and nothing happened.....
    Sergeant:
  • 191 Answers
Reset bios settings.be carefull.and
check all connections.
Support me by signup HERE
Posted on Nov 14, 2010
Are there any recommended bios settings that are different from the default settings?
If the laptop randomly runs extremely slow - it's almost certainly due to a background process using up the computer's resources. Run Process Explorer to find out -which- process this is.
I know you said you've already eliminated this as the cause - but I believe you missed it due to the random nature of this problem.
No BIOS setting will resolve this problem.
Aug 15, 2014 | Dell Latitude E6520 Laptop Computer 500 GB...
Installing Operating System on New Blank Hard Drive
Did you partition the hard drive ? Make sure that it is compatible .Some HP computers will only allow you to use certain products and you can not upgrade\downgrade or change an operating system .Try going online on another computer and see if the devices in your netbook can be changed or upgraded. HP is big for "Thank you for your business & your stuck with it the way it is " I wish you luck .
Feb 06, 2014 | Intel Hp Mini 1000/1035...
Wont recognize hard drive
If you recently bought it from a store or online it might just be a bad hard drive which happens. If your bios wont recognize it then it might just be an error with the bios firmware which can be updated from the manufaturers site.
Jun 11, 2013 | Computers & Internet
My dard disc wont detict
When installing a new hard drive, a PC may not recognize the hard drive. Incorrect cable installations, jumper settings and BIOS settings may cause the computer to be unable to detect your hard drive. Due to the vast differences in hard drive types (IDE versus SATA) and brands, motherboard brands and types, and BIOS types and configurations, please download or acquire your motherboard and hard drive manufacturers' documentation prior to acquiring a hard drive. Make sure that the type of hard drive you plan to purchase is compatible with the motherboard.
Shut down the computer. Unplug all cables and peripheral devices. Clip the anti-static wrist bracelet to a metal object, and attach the bracelet to your wrist. Remove the computer's side panel. (Cases vary. Some will require a small Phillips screwdriver for removal and others feature screwless designs. Please see your case manual if you are unsure.) Locate the newly installed hard drive. Check that two cables are running from the hard drive to the motherboard and to the power supply. If you see only one cable or if either of the cables are not securely seated, plug in the appropriate connector(s). Leave the case's side panel off for now. Reconnect the power cable, monitor cable, and keyboard and mouse connections. Restart the computer. Enter your BIOS immediately. (Your BIOS usually alerts you to the key required to adjust settings. If your screen does not show this information or if you are unsure, consult your motherboard manual.) If it is an IDE hard drive, enter the IDE settings. The BIOS should show the hard drive. Configure it as primary or secondary, according to your computer's configuration. (If you have only one drive, set this to primary. Otherwise, set as secondary.) Save your settings, and exit the BIOS. Once you are certain that the the PC is recognizing the hard drive, replace the side panel. Detect a SATA Hard Disk If you have connected a SATA (serial ATA) hard drive to your computer but are not able to access the files on it, then your system may not be detecting the drive correctly. On either a PC or Mac computer, you can manually detect and mount a hard drive that is locally connected. Once properly detected, the drive will become available for file transfer.
Plug the SATA hard drive firmly into your PC computer and ensure that the drive is powered on. Open the Start menu and click on the "Control Panel" icon. Open the "Administrative Tools" folder and double-click on the "Computer Management" icon. Go to the "Disk Management" tool on the left side of the control panel window. This brings up a list of all drives currently connected to your computer. Right-click on the SATA drive that you want your computer to detect and choose "Change Drive Letter and Paths." Click on the "Add" button and then select the drive letter that you want to be assigned to the SATA hard drive. Click "OK" to save the settings and detect the SATA drive. b> Mac Instructions b> Plug the SATA hard drive firmly into your Mac computer and ensure that the drive is powered on. Open a new Finder window and navigate to the "Utilities" folder, which is located in the "Applications" section of the Mac hard drive. Double-click on the "Disk Utility" icon. Highlight the SATA hard drive that you want your computer to detect from the list of connected drives on the left side of the window. Click on the "Mount" button at the top of the window to have the system manually detect the SATA drive. Hope this helps.
Dec 29, 2012 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
Currently have a samsung floppy drive device manager shows its installed but not showing in computer bios changed to make as default boot device system doesn't recognize it have a PANASONIC product...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to either swap floppy drive or boot up floppy seek both could be disabled press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
May 07, 2011 | Panasonic (JU-256A216P) (JU256) External...
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
My computer cannot find new hard drive disk . my hdd is western 80 ide
Make sure that the IDE channel you are using is turned on in the BIOS. In the optipled line, you press either delete or F2 to enter the bios when the computer is first powered on. If you're adding a HDD, the bios must be set to look for the hard drive. If you're replacing the hard drive, let the BIOS recognize the drive - save the changes and then reboot.
Jan 22, 2010 | Dell OptiPlex GX260 PC Desktop
USB ports on my laptop and others wont recognize my 320GB Passpor
ok
go to your computer bios setup .
U can go to bios with "del" or F@ oe any key for enter in bios setup then go to usb configuration then set high speed and legacy 2.0 enabled then save alls ettings .
May 03, 2009 | Seagate Snow Translucent...
Hard drive failed - replaced 60GB with 250 GB M35X can't format
Does your BIOS recognize the new hard drive?
Are you reinstalling from a Toshiba recovery disk or an operating system disk?
Additionally, there is a setting in the BIOS to turn on or off ACPI function for the hard drive. Find this in the BIOS, change it, and try reinstalling again.
When it works, be sure to change it back after installation.
Good luck.
tony
Jan 30, 2009 | Toshiba Satellite M35X-S109 Notebook
Hard Drive Replacement on Notebook
your computer might not able to support this capacity i suggest calling the manufacturer for Hardware compatibility, if it does not recognize, then the bios might not be able to recognize this big capacity, updating to higher version of bios might help but sometimes not, it all depends on your motherboard config.
Sep 17, 2008 | BenQ Joybook 5100U Notebook
Western Digital (WD3200JS) 320 GB Hard Drive Logo
53 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
