Question about Hunter 52" Ceiling Fan With Light And Remote Control
When we turn on the light, the light blinks on and off really fast like a strobe light. I have checked and all the connections are correct and secure.
  • 3,640 Answers
There is a watt governor on inside for lights. remove this governor and wire direct for lights. this should fix problem. have a good day !!
Posted on Dec 12, 2010
  • Claude
    Claude Apr 30, 2015
    And what about ligt control??????
    Sergeant:
    Scholar:
  • Hunter Expert
  • 96 Answers
I would suggest buying a new fan at the price of the replacement part for your existing Hunter Fan. Ceiling Fan Direction have fans at lesser price compare to other online retailers.
http://www.ceilingfandirection.com/
CeilingFanDirection
Posted on Nov 27, 2015
    Genius:
  • Hunter Master
  • 1,617 Answers
Put the correct wattage of bulbs in the socket.
Posted on Apr 30, 2015
Drivers side turn signal blinking fast other side normal, bulb change didn't help
Even after bulb change, do all lamps work? Bad ground can be shown by weak or dim bulb sometimes and this can cause fast flashing. All bulbs which flash must be working and of normal brightness which is sometimes hard to tell when they blink really fast.
Feb 27, 2015 | 2006 Lincoln Town Car
What's the correct way to use the strobe light to set turntable speed?
The turntable may have a pattern on the edge of the turntable. If not you need a turntable strobe disk that you place on the turntable like a record. The pattern on the disk or on the edge of the turntable will be marked for 50 Hz or 60 Hz frequency.
The strobe marks on the disk or on the turntable are for 33 RPM and 45 RPM and for both 50 & 60 Hz mains frequency.
To adjust the turntable for the correct RPM, turn on the strobe light and the turntable set it to 33 RPM and shine the strobe light on these marks and adjust the speed setting until the 33 RPM marks appear steady and not moving. You may want to check it for 45 RPM as well.
Make sure you use the correct mains frequency marks ie. the 50 or 60 Hz that your electricity system uses.
Feb 25, 2011 | Audio Players & Recorders
When I turn on My RCA L40fhd41 40" television, the LCD screen constantly blinks on and off like a strobe light. The power light stays on constantly, but the screen continues to blink
Dec 12, 2010 | RCA L40FHD41 40. in HDTV
My right turn signal blinks really fast & the same running light on the front is brighter than the left turn signal
One light is brighter because the turn signal light wire is switched with the running light wire. The wires are color coded should be an easy fix. As for the fast blink, if you have put led lights on the signals you will have to also add a diodes to correct the fast blink.
Jun 24, 2010 | 2004 Honda VTX 1300
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
Blinks Fast, and Light Stays On.
check the relay and blown out bulbs will cause the lights to blink fast or some to stay on. one bad bulb will cause the problems.
Jul 14, 2009 | 2002 Chevrolet Cavalier Coupe
Microlight doesn't operate as described
I KNOW HOW TO SOLVE IT. HOLD IT DOWN FOR LIKE 17~20 seconds
and after that u turn it off so everytime u press it, it will change as it suppose to work. i just solved the problem i had too :D
Oct 04, 2008 | Inova MICROLIGHT
Dryers Logo
29,567 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
