Question about Nintendo Wii Console
Hi, i am trying to hook up my Wii to the wireless router using the correct wireless key but nothing works still and the test comes back with the error code 52010. any guesses at all? i have used the different options e.g. WEP WPA2 etc etc but none work. system is working ok for computers etc though!
I 'm having the exact same issue!! did you ever get it solved?
Posted on Feb 02, 2011
What does error code 51330 mean?
The password or key for your wireless router that was entered is incorrect.
Make sure the password or key is entered into the Wii exactly as it appears in your router's settings. Keep in mind that security keys are case sensitive. A simple typo may be causing the problem.
Jan 06, 2015 | Nintendo Wii Video Game Consoles & Games
We had are wii hooked up on internet and lost connection now we cant get it to work
Unable to connect to your wireless network
Likely cause 1: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix 1: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Likely cause 2: It appears that the DNS servers that were provided to your Wii are incorrect or the Wii Console doesn't recognize the server.
How to fix 2: Go to your DNS settings under the Wireless Networks tab and manually set the DNS to 8.8.8.8 and 8.8.4.4 which are Google's DNS Servers.
Other suggestions:
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this:
    • Unplug both the modem and the router from the power outlet.
    • Wait a few minutes, and plug the modem back in.
    • Wait a couple of minutes for the modem to initialize, then plug in the router.
    • Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response
  • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
If you are still having problems, contact Nintendo and they will help you get to the root of your problem - Nintendo Wii Support
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Sep 16, 2011 | Nintendo Wii Console
I bought a wireless router and when I try to hook it up to the wii I do the test and it says error code 50300
Error code 50300 for the Wii signifies that your wireless settings are not correct. What you have to do is go into the Wii Internet setup, and make sure that the settings on your Wii are identical to the setup in the wireless router that you are trying to use. The most common problems include:
1) SSID, which is the name of the wireless network that you setup in the router.
2) The WEP or WPA key, which is the security password that you setup for either of the security protocols that the wireless networks use. You should definitely use the WPA security protocol as the WEP protocol was hacked some time ago.
3) Any manual settings you may have setup, such as whether you are using a fixed TCIP address or a dynamic one.
If you setup the router yourself then you should be able to check the settings on the Wii on your own to verify they are correct. If you had someone else setup the router, use the following link on the Nintendo website which will help you go through the Wii settings to ensure all is well:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=50300&system=Wii&locale=en_US
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 22, 2011 | Nintendo Wii Console
52030 error message when trying to hook to the internet
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
      (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
  5. Click on "Wireless Connection" and then "Search for an Access Point."
      (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
      (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
  9. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
        As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
    • The connection test was not successful - If the test was not successful, you will receive an error code.
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
Jan 23, 2011 | Nintendo Wii Console
Im kinda new to computers and all but im trying to hook my wii to the internet but i keep getting error code 52030 whats going on?i have a 2wire router
Error Code: 52030
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
1. Are you using WEP or WPA security on your router?
1. Log into the router using the default IP (consult your router's manual for assistance)
2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
7. If you are using WPA, the Wii console is compatible with the following types:
* WPA - PSK (TKIP)
* WPA - PSK (AES)
* WPA2 - PSK (AES)
2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
3. If the Mac address filter was disabled, then continue troubleshooting.
3.
If your connection was working previously, try power cycling your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. (Some routers may lose their connection to the Wii console while it is in Standby or turned off for a period of time. Check with your router manufacturer's website for the latest firmware, as there may be an update that will help prevent this issue from occurring in the future.)
4.
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
5.
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
1. On your PC, click "Start" and then "Run."
2. Type "CMD" into the field that appears to open a new window.
3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
This extract comes from Neoseeker. com.. Hope it helps.
Nov 09, 2010 | Nintendo Wii Console
We are trying to set up WII first time using
u have to make the code they don't provide one on the back of the router. Did the router come with a installation disk
Jul 10, 2010 | Video Game Consoles & Games
Can't get Wii connected to internet wirelessly
Error Code: 51331 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Jul 09, 2010 | Nintendo Wii Console
EROR CODE 52031 ON NINTENDO WII
Hi,If you’re using WEP or WPA for your router’s security, log into your router by typing its IP address in your internet browser and make sure your WEP or WPA key entered in the Wii matches the key in the wireless router. The WEP Key can only use characters 0-9 and A-F. If your router allows more than one WEP Key to be entered, make sure the key in slot #1 is the active key. The Wii can only use the key in slot 1.If you entered the correct key, then check to see if MAC filtering is enabled in the “access control, access list, or network filter” section of the wireless router. If MAC filtering is enabled, you will need to enter the Wii’s MAC address into the “allowed” list for MAC addresses.
If none of these were the problem and your connection used to work, try power cycling both the router and modem by unplugging both from the wall. Wait a couple of minutes before plugging the modem back in. Wait another couple of minutes for the modem to initialize, then plug the router back in and wait until the router initializes.
Ensure that your wireless router has the latest firmware installed. You will need to go the router manufacturer’s website to download the firmware.
If Wii Error Code 52031 is still a problem, try changing the broadcast channel of the wireless router to 1 or 11. This can help increase download speed.
You an also try manually entering the Wii’s internet settings. You will need to first get the network configurations from your PC.
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Good luck
Jun 10, 2010 | Video Game Consoles & Games
Im trying to connect my wireless router (netgear) to my nintend wii. first i go to internet settings, then i choose wireless, and then it does a test to see if it can git to the wii. after that it comes to...
Hi can you let me know what model netgear router you are using? it will be written on sticker underneath the netgear router. It sounds like you are doing everything correct aslong as the wep code you entered is right it should work. Do you have a working wireless connection on any computer or are they working with a cable plugged in? Once you post the model number.. i can let you know the correct steps to configure it for the wii.
Owen
Oct 10, 2009 | 2wire HomePortal® 1800HW Router...
I have a F5D9230-4 and a few months ago got a WII. I've tried to get the WII set up to go wireless thru my router to their website. It accepts everything but when it tries a connect test it fails and...
  1. Turn of wireless security in the router, see if you can get the Wii to work UNSECURE.
  2. If the Wii, connects with security turned off, then enable security on the router (WPA is recommended) and a 10 digit key (I use an onld phone number from my childhood)
  3. Go back to internet settings on the Wii, select the wireless configuration you were using, click advanced, and enter the WPA key.
  4. Test connection Wii should work
Jul 13, 2008 | Belkin Computers & Internet
Nintendo Wii Console Logo
20 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
