Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Why does 1997 500 indy asilate on take off is it the clutch
  • 46 Answers
YES IT COULD BE A CLUTCH, JACK SHAFT OR DRIVE SHAFT BEARINGS. ALSO SHECK YOUR CHAIN AND TRACK TENSION
Posted on Jan 06, 2011
When my 2001 indy 500 idles i have a knock
idle knocks indicate worn pistons or worn gudgeon ( wrist pin) bushes
check the ignition timing as it may be too far advanced for idle causing piston slap
Sep 09, 2017 | Polaris ATV
I have a 97 polaris indy 600 it starts and drives great but when u come to a stop i press the gas but it just wont go u got to kind of push it to get it going
The belt needs the tension adjusted or the clutch is going out. More than likely you just need to adjust the belt.
Jan 23, 2014 | Winter Sports
Free unlock code telstra indy
hay fuckwit.., the title link says unlock for a telstra indy..!!! where the **** does it state anywhere in this mumble jumble of **** the UNLOCK CODE FOR TELSTRA INDY, you ********..!!! its people like you that think you know ******* everything, but in fact waste peoples ******* time with you misleading ******* ********..!!! next time you want to think your a ******* ingenious **** smoker.., at least give information on the phone you are actually stating in the ******* title link.....******* ********...!!!
Dec 15, 2011 | Alcatel Cell Phones
I need wire harness with light sockets for both rear turn signals
autozone or oriley autopart store sells thse parts pretty cheap about 5 bucks each. look in the headlight asile.
Aug 26, 2011 | 1991 Honda Accord
Have 96 indy 500 want to know what would cause the sled to run fine when track is suspended off ground. but when track is on ground bogs doe s not want to move? would bad cog bearing cause this? or could...
IT COULD BE A NUMEBER OF THINGS, I WOULD CHECK YOUR DIVE SHAFT AND JACK SHAFT BEARINGS, THAN YOUR CLUTCHES FOR WORN PARTS. IF THAT IS OK CHECK YOUR CHAIN AND SPROKETS. THAN DO A COMPRESSION TEST ON YOUR ENGINE.
Feb 17, 2010 | Polaris New Genuine Polaris Snowmobile...
How do i remove the drive clutch on an indy sport touring 440 1996
you need a clutch puller, Take out the center bolt and the clutch puller will thread into the same hole,as you tighten it up it pulls the clutch off; Good luck
Jan 26, 2010 | Polaris New Genuine Polaris Snowmobile...
I've got a 95 Polaris 500 Indy and when I get on the the gas it seems the power delivery is either slipping, clacking or not engaging correctly... once engaged it runs fine but the clacking sound is still...
Check for loose belt,1 to 1 1/2 inch belt deflection by pushing down.Could be worn bolt bushings that hold the weights on primary drive clutch,easily checked by looking at the weights to see if there sitting slanted.Check secondary clutch to see if it moves side to side,if to much movement it will clunk and rattle.Sounds as if one of your primary weights is not properly lined up or bushing wiped out.Is there alot of powder/dust around inside of clutch?
Jan 09, 2010 | Polaris ATV
Am asil from india.....my system has got a problem now-a-days.it automatically switch off the system and restart simply....monitor light will blink...and the system will be in off state with two fans...
Hi asil,
Please check whether the fans inside the CPU is correctly working... If it gets stopped the system will automatically ges shut down... Check whether there any wire is stopping the fan...
Apr 21, 2009 | IBM Computers & Internet
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
143 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
