Question about Canon imageRUNNER 2200
How do you set it up to be a fax machine?
The panel says 'fax'. How do you make it work as a fax machine? Do you need additional parts? Does it work well as a fax machine or are there problems? My fax machine is broken and if this will work and I can eliminate one piece of equipment in my space that would be great!
  • casepsb Jun 18, 2008
    Thanks for the info. I looked on the internet and it's closer to $1,000 for the part. For that kind of money guess I'll buy another fax machine.
The fax function for this machine is an option. Canon Super G3 Fax Board - J1
Price can be around $600.00 to $700.00
Hope that helps...
Posted on Jun 18, 2008
We have a Canon 810 Fax Machine. How can we change the fax header?
change unit name
press additional functions button
then use the arrow - + buttons to select
tx/rx settings press ok
tx/rx common set.
tx settings
unit name
http://downloads.canon.com/cpr/pdf/Manuals/lc_800_series_basic_operation_guide.pdf
page 333 or section 12
Oct 28, 2016 | Canon Laser Class 810 Plain Paper Fax
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
How to print FAX transaction report on Canon LC 9500
First you have to lift the panels under the speed dial numbers to expose all of the additional features and setting buttons, Press the REPORT button, then the SET button. This will give you a daily log.
Jul 22, 2010 | Canon LaserClass 9000L Plain Paper Fax
Inquiring how to print a transaction report for a Canon model 9000L fax machine.
Lift the panel(s) surrounding the speed dial buttons to expose the additional features and settings buttons. Click the REPORT button, then the SET button.
Jun 09, 2010 | Canon LaserClass 9000L Plain Paper Fax
Unable to receive faxes. Able to send and cartridge printing OK
There can be a few things wrong lets take it step by step
1)Receive mode,your receive mode must be set correctly.If you don't have a tel connected to it, you cant use it as a Manual receive mode,it must be set on Fax only.If there is a telephone connected to it and it is set on manual mode make sure your Incomming ring is set to ON,you will find it under additional functions,RX settings,Incomming ring.
2)Make sure you have enough memory to receive a Fax.Go additional function,dataregistration,TX settings,Erase failed TX,set it to on.
3)Make sure there is enough toner and paper for the machine.
4)Tone or Pulse Dialing,depents in witch country you are make sure it is set correctly Tone or Pulse.You will find it under user settings.
5)There can be a problem at the you local exchange,you can send faxes but the exchange can be faulty and you would be able to receive faxes.
6)And then there can be a problem with you fax machine' NCU PCB board,there is to gas arresters one for send and the other for receive.If one of them are faulty you will have to replace the NCU.The gas arresters is not available as a part.
Dec 09, 2009 | Canon FAX-L360 Plain Paper Laser
Brother 2920 ~ I can not receive faxes
Call your fax machine from a regular phone to see if it rings / answers.
Mar 12, 2009 | Brother FAX-2920 Plain Paper Laser
FAX back
Do you mean to get the paper document back out of the machine? If it doesn't feed out automatically, it may need to be repaired.
If you mean that you want confirmation that a fax was sent, you can turn on the TX (Transmit) REPORT. This will print out the first page of a fax sent successfully.
1. Press the Additional Functions button.
2. Use the arrows to select FAX SETTINGS. Press the Set button.
3. Use the arrows to select REPORT SETTINGS. Press Set.
4. Use the arrows to select TX REPORT. Press Set.
5. Use the arrows to select OUTPUT YES. Press Set.
6. Press the Stop/Reset button.
The machine will automatically print an Activity Report after every 20 faxes (sent or received). If you want an Activity Report at any time:
1. Press the Function button.
2. Press Report button (number 03 on the left side of the keypad)
3. Use the arrows to select ACTIVITY REPORT.
4. Press the Set button.
Apr 17, 2008 | Canon PC-1080F Plain Paper Laser Fax
Richo Aficio 5000L Fax - Fax Operation not working !!!!!!!
First, determine whether the telephone line is working properly. Remove the telephone line from the machine and replace with a test handset. Try calling the fax number and see if you get fax tones on the handset. If not, there is a problem with line switching. If you do get fax tones, then the machine is at fault. Now plug the line cord into the machine, check that it is in the correct input jack, as there may be unmarked jacks open on this machine. Check the display and see that it is ready.Is the machine trying to communicate with another fax number? If so, change the service station fax number to a machine that is close by.(User Tools 2 then immediately 1998 start within 3 secs. then 13 and change the number.) Try to send or receive a fax and observe there is or not 3 sheets of data sent to the machine you just programmed as the service machine.So then, is the machine configured with 1 or 2 modems? Determine that the problem happens with both modems. If so, the modem is not suspect. Now let me stress this, that if you are not a qualified Ricoh technician, do not attempt any further checks yourself.
Next, do a complete level 3 reset. Remember that the machine may be configured with a feature upgrade card which may contain 999 additional speed dial numbers. Do not remove this card yet. However, repeat the receive checks with the memory card removed. If there is no Feature upgrade card or a fax on demand card in the left hand slot, then check the contents of system switch 16. If this is set to 1. If so, then the machine will not work unless a ic or data copy tool is present in the slot. Repeat the tests. Power off and remove the memory card and the feature upgrade card. Power on. Set System switch 16 to 0 and repeat the tests.
Theres more tests, but I don't have the space to go through them all, the manual is 300 pages.
Jan 24, 2008 | Office Equipment & Supplies
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
FAX NUMBER/NAME.
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
the machine’s memory.
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Canon imageRUNNER 2200 Logo
107 people viewed this question
old marine
old marine
