Question about Garden
Won't start. I don't think the spark plug is firing. What should the gap be?
    President:
  • 1,206 Answers
I dont think plug gap is your problem .the machine only gets used once a year but yet it has gas in it all year round and that gas does go bad with time, so i would suggest you replace all the gas, if its a 2 stroke you need to mix it with 2 stroke oil the spark plug just needs drying use a cigarette lighter to burn off the wetness at the tip if plug is two seasons old you might as well replace it cost maybe 3 dollars and you eliminate guess work
Posted on Nov 14, 2010
I have a CS-4400 Echo chainsaw that wont start. I don't think it is firing
1st thing let's check the spark.remove the plug leave it connected to the wire and ground the side of the plug to the engine. and have someone pull the started rope. watch the gap area of the plug for spark. make sure the plug is gap to factory specs, and hold it by the rubber booth. and the on switch is in the run position. good luck Tom
Mar 09, 2015 | Echo Garden
1990 Cadillac Seville won't start. Is it the electronic control module?
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This For spark plug problem, click the help links provided below: ---
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
Car cranks, has spark but will not start?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to gap spark plug ? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How does the spark plug wire go on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
Feb 19, 2012 | 1990 Cadillac SeVille
Saw will not run or start...set ignition module gap, disconnected kill switch wire because there was no spark...Put in new spark plug, got spark..Primed for gas and set choke as per instructions...Would...
Often the cause is a failed fuel pump diaphram. Rebuild the carb... kits about $20. The diaphram works from engine vacuum pulses. Also the little flap type check valves go bad... the ethanol in gas doesn't help this problem...
Sep 03, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
No codes rough idel fills like running on 4 cly exhaust smells good feul pressure new plugs coils firing hard start
You could have a bad spark plug wire, not allowing all your cylinders to fire. make sure the spark plugs are gapped correctlly, they don't always come pre-gapped,check your timing, and your firing order, if just one sparkplug wire is out of place it can make your car sound like its falling apart. good luck!
Aug 19, 2011 | 2002 Jeep Grand Cherokee
My car will not start and i recently changed the spark plugs but did not gap them the person told me i didnt need to so im asking you hat is the proper gap cause i think i need to gap them and replace the...
You always have to at least check spark plug gap
In 47 years, I have never seen a set of plugs that were not
knocked around & the ground electrode bent, on at least
a couple of them
You can clean a rotor & cap & get 3 years out of them,
no need to replace until they get too corroded
Wires last 15 years no problem
Don't get caught up in all the hype & tune-up non sense
The gap is on the radiator support label
The coil has to be tested,you don't throw parts at a problem
If it doesn't start, it has nothing to do with rotor,cap,plugs or wires
You could throw away 2 plugs & it would start on 6
Jul 04, 2011 | 1992 GMC Suburban
Engine missing wont fire properly, i think its the spark plugs how do i change them ?
CHANGE SPARK PLUGS.YOU NEED SPARK PLUG 3/8 SOCKET.YOU NEED SHORT AND LONG 3/8 EXTENSIONS.YOU NEED SPARK PLUG BOOT PULLER AND A SPARK PLUG GAUGE SET THE SPARK PLUG GAP.NOW CHANGE 1 SPARK PLUG AT A TIME SO YOU MIX THEM UP GET FIRING ORDER MIX UP CAR BACK FIRE WONT CRANK.ALSO CHANGE PLUG WIRES ALSO.
Nov 10, 2010 | 1994 Honda Civic
Replaced sparkplugs and sparkplug wires, now runs rough. I checked connections all tight. check firing orger, looks right. run good till I touched it. Help.
Check the firing order with the firing order diagram that I have uploaded, and if that does not solve the problem then remove the spark plugs and be certain that there is an even spark plug gap between all of the spark plugs, (see the emission label under the hood for the correct spark plug gap) and be certain that there is not any split-fire or multi-fire spark plugs installed in the engine, because those plugs will not work with an OBD-II system, and a random mis-fire is the least that they will cause if installed in an OBD-II controlled vehicle.
Aug 18, 2010 | 2001 Ford Taurus
1997 Honda vf750c turning over but not starting
In order for it to start, you need to find out if it got spark and fuel. If you thinks it fuel, you could try a small shot of starting fuild into the air filter box. If it fires and then dies out it definitly lacking fuel. If it does fire up with starting fluid, you need to check spark. Remove one of the plug wires and install a spark plug on it. Gorund the plug to engine by resting it on a metal part. Locate the plug as to be able to see the gap on the plug. Crank engine over and check for spark at the gap. If no spark check kill switch. Ed
Jun 10, 2009 | 1997 Honda VF 750 C Magna
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
