Error 0502 My paper feeder does not grasp paper and feed it. I hear clicking and a struggle, but then it stops right after the cartriges come to rest and should at that point be ready to print.
  • 1 more comment
  • Sherry Moe
    Sherry Moe Jun 18, 2008
    I can't get my paper to feed. Right when it makes the noise to do the actual printing it jams and stops. I was told to "check the roller and feeder", I looked up in there. I don't see anything unusual.
    I don't think this website is going to help me. I need more of a mechanical answer. I need to take it to a service place.
    I need my money back, please? I just got desperate and I still am, but this isn't going to work.
    Sherry
    smoe1@comcast.net
  • Sherry Moe
    Sherry Moe Jun 19, 2008
    What I have here is something mechanical. a mechanical clamping action. It clamps but it just won't feed. I tried all the technical solutions in a chat sessionm with hp and we came to the conclusion that it needs to be serviced or else replaced with a new one.
    I really just want to get my money back for the service offered here. I appreciate it, but it doesn't help and I need that money to buy a new printer with.
    Thank you
    smoe1@comcast.net
  • Anonymous Aug 19, 2008
    Problems are the same with the squeezing and crimping of the paper and I do not know what to do about the paper output slot.
    Guru:
  • 1,894 Answers
It wil be better if u say us the model number and make
Posted on Jun 19, 2008
  • dewan nafees ahmed Jun 19, 2008
    About 90percent of your feeder problem is the feeder clamps at the end
    feeder. The problem is that you have something jammed under the clamp
    causing a shift in the way the paper is feeding in.
    To check this, simply feed the paper reverse,lift the clamps and clear the jamm.
    Guru:
  • 859 Answers
Take it to a shop, your right, this needs hands on not guessing.
Regards,
Worldvet
Posted on Jun 18, 2008
  • Glenn Rogers
    Glenn Rogers Jun 19, 2008
    If there is any chance you are in a dry climate, your rollers have shrunk from dehydration, yeah sounds weird but I fix more printers here in Nevada because of this. Take a wide flat brush and paste clear water in the rollers as you turn the printer on and off. I bet the rollers turn during this power on cycle. Do this several times until you've really drenched the rollers.
    BTW, do this with the printer over a copy of a newspaper in case any dry ink links out.
    Let the surface of the rollers sort of dry out and try to feed paper again. If it does feed now, that was your problem and you'll want to feed paper until the rollers have cleaned themselves off and the paper no longer has ink trails on it.
    Regards,
    Worldvet
    Sergeant:
  • 243 Answers
Your motor may be jammed and needs replacement. do the pricing and see if repair is possible or replacement is more cost effective.
    Master:
  • 638 Answers
Adapter problem it says. not able to send proper command to the feeder due to improper supply
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
  • 148 Answers
I recommend, before taking anything apart, to simply turn off your printer, then slide the cartriges all the way to the left, and gently wipe the encoding strip running right behind the cartrige carrier. it will look like a translucent piece of plastic strip with lines on it. Wipe it down with a soft cloth gently, then slide the cartriges all the way to the right, and repeat this process. also clean and lightly lube the guide rail for the cartridges.
When you are done, simply close the cover, power back up, and see if it will print a test page for you.
Hope that helps...
    Brigadier General:
  • 3,614 Answers
Check for the paper feeder and the printer roller..
    Genius:
  • 3,422 Answers
Can you please give the make and model no.
  • Priya darshan Jun 18, 2008
    Re-position the Encoder Strip on your all in one Printer
    To re-position the encoder strip, perform the following steps:
    1. Remove the power cord from the unit.
    2.
    Lift the lid of the unit, just below the scanner portion of the
    All-In-One, to expose the inside of the unit where the printer
    cartridges are located.
    3. Gently slide the ink cartridge carrier to the middle of the printer.
    4. Gently move the top part of the printer belt to the right.
    5.
    Using an index finger, gently push encoder strip down and then back up
    to get it back into the slot located on the back of the ink cartridge
    carrier.
    NOTE
    NOTE: There is a small slot that the encoder
    strip fits into, which is going to be located on the back of the ink
    cartridge carrier.
    6. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
    7. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
    8. Once the encoder strip has been re-seated, close the lid to the unit.
    9. Re-connect the power supply to the All-In-One.
    10. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 0502 code will not appear.
    See attached pictures, one for an out or place encoder strip, the other for a well placed strip.
    Other
    faults that can bring up this error is a carriage rail that needs
    cleaning and oiling (so you might want to do that while your inside the
    thing), and also obstructions to the paper ways. Try removing paper
    jams, and put the printer upside down to shake loose anything that
    might jam the mechanism.
    this one is of an in position strip
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
The paper isnt going through
If the paper feed rollers are not clean, they may slip and cause paper feeding problems.
The problem may be alleviated by performing paper feed roller cleaning.
1. Open the Printers folder.
- For Windows XP Home Edition Click/Select "Start," "Control Panel," "Printers and Other Hardware," and "Printers and Faxes."
- For Windows XP Professional Edition Click "Start" and "Printers and Faxes."
- For Windows 2000/Me/98 Click/Select "Start," and "Settings," then "Printers."
2. Right-click the icon of the printer for paper feed roller cleaning, and select Properties from the displayed list.
3. Click the Maintenance tab and click Roller Cleaning. 4. Remove all sheets of paper from the auto sheet feeder, and click OK. 5. Confirm the message to be displayed, and click OK.
Do not try other operations until printer's operation completes.
6. When the printer's operation is completed, follow the confirmation message to load three new sheets of A4 or letter-sized plain paper in the auto sheet feeder
7. Click OK.
8. Confirm the message to be displayed, and click OK.
Do not try other operations until all the three sheets are ejected.
Memo: The printer prints nothing on those sheets.
9. When all the three sheets of the paper are ejected, paper feed roller cleaning is completed.
10. Click OK.
Performing Roller Cleaning is completed.
Nov 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Paper feed doesn't seem to work.
The problem is paper feeder mecahnics. Check pick rubber roller at the mecahnics and lubrication, or replace paper feeder.
May 30, 2009 | Canon Pixma MP500 All-In-One InkJet...
Automatic document feeder does not work-- does not pick up paper
Here, you will find information on feed issues with the ADF. If you still have problems, you can find information on the "clear jam" error here.
If the above fails, you can find information on paper pickup issues and also how to perform a partial reset here.
Hope this helps. Please remember to rate this information.
Thanks
May 27, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
I have just purchased ink cartridge 830 black for canon ip 1800 but the lights are blinking orange please tell me why this is happening
I received this response from canon.com. Hope it helps you.
If the paper feed rollers become dirty, they may not be able to properly
feed paper due to the feed roller's slippage. If paper does not feed
correctly, perform the following to clean the paper feed rollers:
1. Open the Printer properties.
For Windows Vista
a. Click / Select 'Start' from the bottom left of the Windows screen,
'Control Panel', 'Hardware and Sound', and then click on 'Printers'.
Note: If you are in 'Classic' view, Click 'Printers' directly from the
'Control Panel'.
b. Click your right mouse button on the listing for your printer, and
then select 'Preferences' from the menu that appears.
'Control Panel,' 'Printers and Other Hardware,' and 'Printers and
Faxes.'
a. Click 'Start' from the bottom left of the Windows screen, and
'Printers and Faxes.'
For Windows 2000
and 'Settings,' then 'Printers.'
then select 'Properties' from the menu that appears.
2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
3. Remove all sheets of paper from the auto sheet feeder.
4. Confirm the following message, and click 'OK'.
Note: Clicking 'OK' will activate the paper feed rollers 30 times. This
activation will take about 90 seconds. Do not perform other operations
until this operation has finished.
5. Confirm the following message, and click 'OK'.
6. After the continuous paper feeding operations in step 5 have
finished, load three sheets of plain paper and click 'OK'.
7. Confirm the following message, and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
8. Click 'OK'.
If the issue continues to persist, try fanning the paper before
reseating in the automatic sheet feeder.
Follow these steps to fan the paper in the Auto Sheet Feeder(ASF):
1. Remove all documents from the ASF.
2. Check for any obstructions.
3. Fan out the sheets of paper so that they do not stick together.
4. Align the edges of the paper.
5. Insert the document stack, face up, into the ASF until you hear a
beep.
6. Adjust the document guides to the width of the document.
If fanning the paper does not help resolve the issue then the iP1800
printer will require service.
special toll-free number for email customers with
unresolved issues and speak to a technician* by dialing 1-866-261-9362,
Monday - Friday 10:00 a.m. - 10:00 p.m.
Dec 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
CANON FAX JX200
remove the cartridge and see if it goes away, if does then you probably have a defective cartridge are are not inserting it correctly.
Thank You,
Mikey
Apr 04, 2008 | Canon FAX-JX200
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
427 people viewed this question
jasbo
jasbo
