Question about KitchenAid Refrigerators
Frost free freezer is full of frost - KitchenAid Refrigerators
  • rickreale Nov 17, 2010
    Hi Bob, Can I fix or replace the ADC. If so where is it and how difficult would it be for me, an average homeowner. Thanks, rick
    Guru:
  • 1,524 Answers
You have a problem with the Adaptive Defrost Control commonly known as the ADC or control board.
http://appliancedigest.com/index.php?/files/file/368-whirlpool-refrigerator-r-80-adc-independent-temperature-service-manual/
Kitchen Aid is made by Whirlpool.
Posted on Nov 14, 2010
  • Robert Moller
    Robert Moller Nov 17, 2010
    Call Bi Coastal Appliance Parts @ 1-800-673-1262 cost around $165. Better then $650+labor
    Open the download and you can see. Not to hard to install.
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
How to fix a hotpoint frost free fridge freezer
I would call a repairman . possibly the fan has worked loose on the motor shaft
Oct 08, 2015 | Total Micro HDP80CF72-PAN 80Gb Notebook...
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost free freezer is suddenly full of frost
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 24, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
How is freezer part of refreg best loaded? Full or partful?
Full is best but don't block airflow for the frost free function. The air must circulate. Once a full freezer gets to temperature, it doesn't have to run as often, since the frozen goods hold the temperature better than air would.
Oct 17, 2009 | Freezers
Frost build up in a frost free freezer
It could be the door gasket. It could also be that the fridge needs a good defrosting. (especially if it is an older fridge)
When I bought my house I had the same problem with the fridge that came with the house. I assumed the previous owner had been defrosting it regularly, which he had not.
Eventually I decided to try a full defrost, and my fridge now works like new.
Mar 20, 2009 | Kenmore Freezers
Frige freezer
if you have frost in the freezer it either has an air leak on the gasket or the defrost system has failed and you need to call an honest appliance repair person,don't call sears$$$$$$$$$,check all around the gasket first,mike
Sep 07, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
44 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
