Kenmore model 11044832200 ( ourchased 4/26/03); recently ran a very large load and after done clothes wet. Tried spin only cycle - drum won't spin. removed most of clothes and tried a drain/spin cycle....nothing. Removed all wet clothes and put in afew in a new wash cycle; won't spin. Drum spins freely by hand. Water appears to be draining OK, seems to be internal to washer. Advice please?? Hank
  • Henry Gellert Nov 15, 2010
    My issue is NOT with draining but the drum spinning....you didn't address the issue presented!
    I removed the back of the washer and found the drum drive belt have come off the motor pulley. Compressing the drum that is supported by (2) shock absorbers facilitated reinstalling the belt ( just rotated it back on the large drum drive pulley while depressing the shocks).
    As far as your advice on cleaning the filter you can avoid water going everywhere when you unscrew the clean out access ( and it will ) by removing the single screw holding down the pump assembly thus allowing you to position a funnel completely under the front of the clean out - no water spilled.....now that I fixed this myself , provided clarification on the single bit of non-essential advice you provided and offered your clients insight on what to look for when confronted with my original posted symptoms will you NOT charge me the fee? Seems only fair!
    President:
  • 1,891 Answers
Have you cked the belt on back and is still on the drive . or ot may be broken. washer will fill and drain and prosser thinks tis going . . so i would ck the drive . mm hopw this helps m ,m feed back pls .. ,
Posted on Nov 16, 2010
  • 218 Answers
Remove the bottom front panel 2-3 screws at the very bottom. Observe inside for tech manual this will give you troubleshooting instructions. I would start with cleaning the pump filter screen then follow instructions for troubleshooting if problem persists.
http://www.fixya.com/support/r4507357-clean_pump_filter_screen_kenmore_he2_
http://c.searspartsdirect.com/lis_png/PLDM/P0211045-00001.png
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Washer-Parts/Model-11044832200/0583/0153200?pathTaken=
Posted on Nov 14, 2010
  • Ken Hutson
    Ken Hutson Nov 15, 2010
    Sorry for the misunderstanding further advice now that I have more information would be to thoroughly inspect the rear drum pulley to make sure it is not warped or bent do this by turning slowly by hand and observing the gap between drum and pulley almost any amount of movement side to side would require replacing the bent pulley.Then check the inner drum for excess movement due to possible rear drum bearing failure by pushing up from the inside to see if you have excess movement due to the high speed that you machine use in final spin there should be little or no up and down movement. Belts do not just fall off there is usually a reason and if not corrected it will continue to happen in the future.
    The most likely cause for not spinning is a typically a clogged screen even though yours appeared to be draining that does not mean that it drained completely it can appear to be drained but still have a significant amount of water in the bottom of tub. You had said not spinning I should have asked if it was turn or moving at all in any cycle I was only providing the best advice I could on the limited information provided. Following the tech-sheet would have lead to solving the problem. If I can be of further assistance please let me know.
    Thank you and have a great day.
During the spin cycle it spins correctly until the last 2-3 minutes and then it just fluffs clothes
Some machines used a variable speed slow down process to avoid clothing damage, this removes the items from the outside of the drum where if the clothing was left for a length of time after the cycle has finished it could damage the fibres, this way the clothing is also easier to remove from the machine and promotes airflow over the items
Jun 14, 2016 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
Jan 12, 2009 | Kenmore 43142 Front Load Washer
Soaking wet clothes
Burly Bob,
Is this the same model as listed by the previous poster? If so, does the washer ATTEMPT to go into the spin cycle? That is, does the timer advance to spin cycle properly, and can you hear the transmission or drive motor engage?
May 31, 2008 | Kenmore 22422 Top Load Washer
Kenmore 44092/spin cycle
It turns out that there was a sock stuck within the pump in the washing machine. I removed the back cover and removed all the excess water, because once the sock was removed, the water was free to escape. I just removed the hose that connects to the pump and felt the sock, and was able to remove it. Once I hooked everything back up, the washing machine ran great.
Apr 17, 2008 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
