Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
Farmall 706 Diesel with a TA won't shift into 3rd and 4th gears. Goes into 1st and 2nd and neutral ok.
5 Suggested Answers
  • 15 Answers
SOURCE: I have a 1967-706 Farmall IH splitting a transmission
you must remove the plate from the bottom of the transmission. Look for a shaft that goes from the rear through a gear. Remove snap ring from in front of gear and it should roll apart then. On reassembly be sure to change gasket and all o rings to prevent hydraulic suction leaks
Posted on Feb 09, 2010
  • 3 Answers
SOURCE: My 706 Farmall does not
linkage train has slack (worn) or spring could be broken that pulls the linkage into the slot and holds it there. for that you have to remove the floor plate then the trans cover. not too bad.
Posted on Aug 27, 2010
  • 18 Answers
SOURCE: I have 706 Farmall tractor
change hydraulic filter again and probibly the oil use ahigh quality hydraulic oil like Case-ih hytran fluid this oil has a high moisture retention factor be sure to drain all the cavitys 5 plugs total and let them drain completely before refilling
Posted on May 08, 2011
SOURCE: Is there a internet source
Try this LINK!
Posted on Aug 13, 2011
The Pacifica will not shift past 4th gear. It shifts normally through 1st, 2nd, 3rd, and 4th gear. Their is no high reeving RPS, no clunking, no lurching. It will just not shift past 4th gear.
is there an OD button that might have been pressed .if it has lots of miles on it it could be needing a flush job . last one I got done was around 100.00 at jiffy lube.
Nov 12, 2015 | 2005 Chrysler Pacifica
2000 yz250 shift to bottom (neutral) won't drop into 1st
check your shifting drum.may have left a pin out of the shifting drum.
Apr 01, 2014 | 2003 Yamaha YZ 250
Gear shifter cable
sounds like a stretched gear shift cable or the linkage on the tranny may need some adjusting i would start with the linkage first jack vehicle up and do a visual while some one goes through the gears make sure to use jack stands so that the power wheels are off the ground.....good luck
Nov 09, 2013 | Nissan 200SX Cars & Trucks
Selecting 3rd gear
Do you mean you can\'t find 3rd gear or it won\'t shift into 3rd gear? If you can\'t find 3rd gear, shift all the way down to neutral, then shift up 2 clicks. On my Suzuki Boulevard S-50 (VS-800) the shift order is 1st gear down, then up for neutral, 2nd, 3rd, 4th, and 5th. Your crotch rocket probably also has a 6th. If the problem is that it won\'t shift into 3rd, then you had best take it to the shop as it is not readily repairable without specialized tools and knowledge.
Oct 02, 2013 | 2003 Suzuki GSX-R 600
2003 Grand Am Automatic will shift normal from 1-2 but will not shift into 3 or 4.
Worn clutches or solenoid issues if it is an Alison style box.
Apr 02, 2017 | Pontiac Cars & Trucks
2001 chevy s10 automatic 150,000 miles suddenly lost 3rd and 4th gears
USE A SCANNER TO CONFIRM WHETHER HAS ANY SOLENOIDS HAD TO DO WITH.
Aug 29, 2012 | 2001 Chevrolet S-10
Have 1st 2nd and reverse, no drive 1988 model 2 wd
sounds like 3rd gear clutch is out (it might have blew out a lip seal or something)
pull the pan c if there is a lot of black on the bottom of pan (no 3rd = no 4th either) the 3rd gear clutches are engaged along with the 4th gear clutches to make overdrive
if the tcc cable is out of adjustment it mite shift at wot (wide open throttle) max rpm (5000-5500)
if it just 1,2, neutral its probly clutches
Mar 25, 2010 | Chevrolet Silverado 1500 Cars & Trucks
Only runs in 1st and 2nd gear and reverse.
This is a fault mode in which the transmission either loses electrical power or the PCM deactivates all of the electronics. The transmission will default to max line pressure. The driver will have Reverse and 3rd, with manual 2nd available by putting the gearshift in 2 or 1 (doesn't matter). 1st, 4th, and TCC lockup will not be available. It will not hurt the car to drive it like this for short periods, but use manual 2nd to get the car moving, and be aware that the trans will generate more heat than normal while operating in limp-home mode due to increased torque converter slippage during 2nd gear starts and no lockup in 3rd gear.
Trans shifts into gear harshly, car feels sluggish off the line
, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmission is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the under hood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Car goes into gear but feels very sluggish like the brakes are dragging, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time: ShiftB solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Dec 14, 2009 | 2006 Hummer H3
Transmission problem with a 1999 audi a4 quattr0 2.8l
you may not need a transmission replacement, just try replacing the sensor of the transmission, it may help
Jul 02, 2009 | 1999 Audi A4
Transmission won't shift to 2nd and 3rd gears goes from 1st to 4th.
Doesn't sound like a simple fix. I would suggest having it serviced.
May 05, 2009 | BMW 318 Cars & Trucks
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
146 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Tom Chichester
Rod Newman
Rod Newman
Level 1 Expert
Are you a Farmall Toy Expert? Answer questions, earn points and help others
