Question about Coby MP-C7085 MP3 Player
Video how do u put it in msc mode?
In the menu there is a setting tab. In this tab is the sub caragory "usb mode" mhen clicked you can choose whether you want MSC or MTP!!!
Posted on Jun 19, 2008
Enter usb2.0 msd mode - pls help
Usb mode is in settings push center button choose between msc or mtp....
MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode.... make sure your usb 2.0 driver is installed....... Connect to the mother board.. MSC is best create a music1 folder and put music in there then there is no switching back and forth to mtp ms....MSC can sync the player and the expansion card
Dec 19, 2010 | SanDisk Sansa e260 MP3 Player
I lost my cd can i stiil put videos in my mp3? pls help
If your player has MSC mode it will be easy. Download this program "Any Video Converter" click the link. It is a free to use program. Convert your video to one that works on your player, most use MP4 video format, you may have to try different formats till you find the one that works. Save the converted video on the computer into a easy to find folder and just copy the finished video into your players video folder and you are good to go. If you do not MSC mode it gets a bet hard, you will have to use Windows Media Player or iTunes to sync to your player. But you can still use the Video converter program to convert them for use.
Nov 21, 2010 | Philips GOGEAR SA6045 MP3 Player
I need help trying to put videos on my mp4 player
If you added songs/ videos to the device in MSC mode, then switch to MTP mode, you will not be able to see the songs added in MSC mode and vice versa, though the space used on the player will still reflect their presence. Switching modes should make the files show up. For example, switching from MSC to MTP mode or vice versa. But you can not see the songs / videos copied during other mode, is that clear as mud? Go to this tip it explains all a bit better. > http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem<
Jan 02, 2010 | Audio Players & Recorders
I cannot access the music on my Samsa M230 via USB to PC. I would like to copy the music off the sansa and add new music, but windows media player doest show any music files on the m230 drive
There are 2 modes the player can connect to a computer:
1. MSC mode: the operating system, seeing the player as a removable disk on "My Computer"
2. MTP mode: added software, when an extra program is started the player is detected in this application software: e.g. Windows Media Player
When songs show up on the player but not on My Computer:
1. The player is in MSC mode and music has been put on the player with a program in MTP mode
or
2. The player is in MTP mode and music has been put on the player
using Windows Explorer in My Computer in MSC mode
In your case the solution should be:
Switch the player into MSC mode and look in Windows Explorer for
a driver letter with a capacity of about 512MB memory.
How to get the player in MSC mode:
Using the menu on the player:
From the main menu go to Settings Menu > USB and select MSC mode.
Using the hold switch on the player:
1. Turn device OFF.
2. Facing the hold switch slide it to the right so an orange color would show putting the device on Hold.
3. Connect the device to the PC.
Explore "My Computer", looking for the players content showing up as a drive letter (about 512 MB sized for the m230)
Click the drive letter, select your files and "copy + save" or "drag and drop" them to a location on the computer.
When needing more help, just post a comment.
Dec 30, 2009 | SanDisk Sansa m230 MP3 Player
Have sansa mp3 but no disc and want to set up with my comp is there anywhere online i can get software to do this
For the Sansa e200 series there's an overview link, listing all the important directions for the e250 2GB player.
Note: there are 2 e200 versions ( and a Rhapsody version), see:
http://kb.sandisk.com/app/answers/detail/a_id/4487/session/L3NpZC95ekVVVURRag%3D%3D/sno/0#e200
Firmware determines the player version and is not interchangeable.
Firmware check: On the player, from the Main Menu > Settings > Info, the firmware can be displayed.
The minimum system requirements for the "old" computer, see the manuals, should be:
Windows SP1 with Windows Media Player 10 running for the e200v1 and
Windows SP2 with WMP10 or higher for the e200v2.
I'm not sure if the old computer supports USB devices like an external harddrive or memory stick.
When it does it's worth a try getting the player connected to the old computer.
The player must be switched to MSC mode to get connected to the computer.
Note: before disconnecting in MSC mode, always safely remove hardware (icon in the right corner of the computer screen below)
When connected In MSC mode, the computer sees the player as a removable disk / memory stick. Transfers can be made using the "drag and drop" method for normally putting data onto a drive.
  • switching to MSC mode through the menu:
1. Select the Setting item in Main Menu.
2. Select the USB mode item.
You can select Auto Detect or MSC mode.
3. Select MSC mode.
The manual of the e200v2 series does not give / show this option.
When not having the MSC menu function above, go through next steps for connecting the e200v2 in MSC mode.
  • switching to MSC mode, using the player's buttons:
1. Turn device OFF.
2. Slide the hold switch to the direction of the headphone jack so an orange color would show putting the device on Hold.
3. Press and hold the (| <<) button while connecting the device to the PC.
I hope this information gives all the support you need.
Just post a comment when needing more help.
Dec 28, 2009 | SanDisk Sansa e250 MP3 Player
I downloaded a Sansa video converter and it keeps saying that my Sansa is not connected after i connect it. Can i have some assistance please?
do u have windows or mac system? if mac,
Although MAC OS is NOT a supported operating system, the Sansa player can still be recognized if the Sansa player is only plugged in MSC mode.
MAC computers do NOT support MTP
A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized.
MAC computers supports Sansa players in MSC mode
Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
See answer ID 207 for instructions on how to put your Sansa player in MSC mode.
See answer ID 1141 for instructions on transferring music to your Sansa player using iTunes on a MAC computer.
Aug 01, 2009 | SanDisk Sansa e260 MP3 Player
Change MP3 from USB to MSC mode
Usb mode is in settings push center button choose between msc or mtp.... MSC will allow you to see the expansion card mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installed
Jun 27, 2009 | SanDisk Sansa e260 MP3 Player
Not let me put video on it
try switching it to MSC (usb mode) and change folder options to view hidden files and convert the video to quicktime movie and move it
Mar 09, 2008 | SanDisk Sansa e200 MP3 Player
How to delete a file completely from the player?
The videos are transferred in MSC mode, if the device is not in MSC mode, then the files are not viewable. Check the mode, the navigate to the device in My Computer. Open the device and then look for the Videos folder. Best of Luck.
Sep 05, 2007 | SanDisk Sansa e250 MP3 Player
Sansa Scandisk e205 refresh Database failed help plz!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
okay, heres wut u can try. try to switch the USB mode from MTP to MSC (in settings, go to USB Mode and switch from MTP to MSC.) And then in the MSC mode connect it to the PC. I dunno bout ur sansa, but my did a Database Reboot, and the computor could see the player. Then u can switch it back to the MTP mode (czu its much mroe comfortable). Although i think the 0.5 gigs are lost forever (i lost 1.5 gigs,)atleast now u can dwonlaod songs on ur player.
Sep 28, 2006 | SanDisk Sansa e250 MP3 Player
Coby MP-C7085 MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
