Question about Craftsman Garden
My mower starts when cold but cuts out and dies when it warms up.
    President:
  • 1,206 Answers
Classical coil symptom check for spark when its hot if its lost you will need a new coil.
Posted on Nov 14, 2010
Farmall carb problem
Are you sure its carb related? I would check compression when unit is cold, then check compression when unit is warmed up (right after unit dies), check for variance and compare to spec. Also, I would have a spark tester inline and visually check this as unit dies. Does unit loose spark before engine dies? This procedure should help you narrow down the problem to make sure its carb related or not. Good luck and happy wrenching!
Nov 30, 2013 | Farmall Tractor M,super M,md,super Md...
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
I have a 2001 yard machine riding mower that cuts off when it gets warm and has no electric
Symptoms would lead me to the coil. They get hot, and die. If it doesn't re-start hot but will after cooling down then its a 99% coil issue
Also after it shuts down and u turn the key to try to start it back up is the starter engaging and trying to spin the motor or are you getting nothing.
If the starter isn't doing anything it could be the starter or relay between ignition switch and starter.
If the starter is engaging and the motor is trying to turn over it could a weak starter or it could be a build up of compression not letting the starter spin it over that a valve adjustment would help. The temp change from cold to hot is sometimes enough make the valves expand and not open enough to release compression for start up.
May 29, 2011 | Mtd 22" Yard Machine Push Mower
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
Aug 20, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Swisher Mower dying when cutting
I've had a 60" Swisher finish cut (13.5 hp) for about 7 years and have found that the valves have to be adjusted on a VERY regular basis. When they get out of adjustment you can hear the starter trying to spin the motor but can't. I'm almost positive this is your problem. Go to You Tube to see how to adjust the valves to .004. It's simple. Stan Wilhite
Aug 17, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
MOWER RUNS FIVE MINUTES THEN STOP AFTER IT WARMS UP
Check your automatic choke ... a cold mower needs more choke, and the auto-choke should release when the motor warms and runs smoothly. If the choke is sticking, the motor will die when it gets warmed up, then start again after it cools down.
Apr 12, 2009 | Mtd 22" Yard Machine Push Mower
MTD Yardman push mower runs fine for awhile then cuts off.
Try buying a new plug first but if it continues then I would say that there is debris in the carb.
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
41 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
