Question about Cameras
B IS THE FAHER OF A BUT A IS NOT SON OF A. WHAT IS THE RELATION BETWEEN B &A?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
I assume you mean "B is the father of A but A is not the son of B."
One solution is that A is a daughter of B.
Posted on Nov 14, 2010
Look at this graph: y x Is this relation a function?
It is a relation. A subset of relations are called function. To be a function, each x value must correspond to one and only one y value. If there are more than one y value for any x value, it is not a function, but still a relation. Some people use the vertical line test to see whether a relation is a function. If you hold a ruler vertically over the relation and it hits two or more points, it is not a function.
Good luck,
Paul
Apr 13, 2017 | Homework
O2 sensor bank 1 sensor 2 location 307 1.4 2004
Notes in relation to bank numbers
•Bank 1 always refers to the group of cylinders which includes No.1 cylinder.
•The majority of small engine European vehicles will only have Bank 1 sensors fitted (i.e. 1 x Front & 1 x Rear).
•An inline 6-cylinder engine may have cylinders 1, 2 & 3 referred to as Bank 1 & cylinders 4,5 & 6 referred to as Bank 2.
•V configured engines would normally have Bank 1 & Bank 2 sensors, with again Bank 1 referring to the group of cylinders which contains No. 1 cylinder.
Notes in relation to sensor numbers
•Sensor 1 always refers to the front / regulating (Upstream / Pre-cat / Upper) sensor.
•Sensor 2 always refers to the rear / diagnostic (Downstream / Post-cat / Lower) sensor.
N.B. Some larger capacity vehicles may have 2 rear / diagnostic (Downstream / Post-cat / Lower) sensors on the same bank, which may be referred to by EOBD codes as sensor 2 & sensor 3. Sensor 2 would relate to the rear sensor closest to, or in the catalyst, with sensor 3 relating to the rear sensor furthest from the catalyst.
Notes in relation to position
In some catalogue entries, a sensor will be listed as fitting in left or right position. This is always taken from the point of view of sitting in the vehicle (i.e. For UK RHD vehicles Right = Offside, Left = Nearside).
Correct identification of the relevant oxygen sensor is more important than ever as many vehicles now may have devices such as temperature, pressure and NOx sensors fitted to the exhaust system in addition to the oxygen sensors.
Sep 29, 2016 | Cars & Trucks
Deactivate facebook
It can be a virus or someone getting access to his account.
Cheers,
Tom
Aug 29, 2014 | Computers & Internet
If a=b then a equivalent b
Is there a question?
If you mean that a can be replaced by b anywhere a is used yes.
A Relation, let us call it R, in a set A is said to be an equivalence relation if the following three properties are verified for all element a, b, and c in the set.
1.The relation is reflexive: aRa
2. The relation is symmetric: If aRb, then bRa
3. The relation is transitive: If aRb and bRc then aRc
The simplest example of such an equivalence relation is the equality.
Jun 24, 2011 | Office Equipment & Supplies
I need to know what the power is on a cr800 2x Poweracoustik amp when it is bridged...
  • You double the watts to the speaker for the channels bridged. This also depends on the Ohms of the speakers being used. The lower the Ohms of the speakers used in relation to the Ohms of the amp also increases the watt output of the amp.
Regards, Tony
May 22, 2011 | Power Acoustik Car Audio & Video
There is a noticeable ringing sound only when I strum any note on the E string , any other string sounds fine.
If the ringing only occurs with a specific range of notes it may be something rattling in the amp loose or speaker enclosure.
It could also be feedback occurring at certain frequencies - does the ringing stop if you turn the volume down a bit or stand in a different position in relation to the amp?
Could be a problem with your guitar? Maybe the pick up height needs adjusting in relation to the E string or is it the string buzzing against a fret - indicating a need for adjusting the bridge height or trussrod settings?
Feb 27, 2011 | Fender Rumble 75 75watt Bass Guitar Combo...
Lights flash on the unit at night making it hard to sleep!
The power button does nothing in relation to this!!! Press the x-bass/demo button at the bottom of the remote. That should fix the blinking lights! :)
Feb 26, 2009 | Sharp XL-DK225 Shelf System
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
