BROKE THE CABLE
I BROKE THE CONNECTION GOING INTO THE TV, I TOOK THE BACK OFF TO FIND A LITTLE BOX THAT THE CABLE LEADS INTO, HOW DO I FIX THAT?
    Scholar:
  • 104 Answers
Radio Shack MIGHT have the part. That little box was the connector assembly and is soldered on to the circuit board. You will need to unsolder the broken connector and solder in the new one. Either that or duct tape and be careful?!
Posted on Jun 20, 2008
Cable connection broke off bake of unit
if i was u id take to expert as i have had same problem once found cable was incased inside box very had to open so took to repair shop didnt cost alot
Nov 27, 2012 | Panasonic TH-42PX60U Television
The cable plug broke off the back of TV. I took off the back of TV and I'm not sure what to do.
If this model has a/v inputs you could use them and if you're on cable (direct cable not cable box) you could use a vcr to change channels - or you could remove the tuner and resolder the "cable plug" (RF connector) if it didn't crack the tuner circuit board when it came off.
Oct 16, 2009 | Zenith A25A11D 25" TV
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Cable connecter broke off?
It would probably cost more to have someone fix it than just replace it.If you or someone you know can use a solder iron you might get lucky and resolder conections, but most times its too hard to get at the circuit board to affect repairs and the connector usually gets mangled so bad it won't fit right anymore. Or you can try to avoid using this connection and use a different input. But you would need either a cable/satellite box or vcr (with the same kind of connection that broke on TV) and change the input used on the tv to the new connection such as 3 wire AV connection (with the yellow,red and white wires)
Apr 26, 2009 | Sharp 25H-M60 TV
Cable connection broke on back of tv
YOu will need a box that will convert your coaxial signal (cable) into a another using either Composite (RCA wires) or component (Yr,Yb, Yg) outputs. Your local radio shack should be able to accommodate you
Apr 01, 2009 | Philips 32PF9986 32 in. HDTV-Ready LCD...
Mitsubishi television
Good Day;
If you have a "BOX" use the video inputs. This way it will by pass the broken connectors. Yellow, red & white. if not try: 1-800-553-7278 or FAX; 1-800-825-6655. Good Luck, big IRISH.
Sep 17, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Loose cable connection plug
tv back cabinet to second hole to fixing cable hooked
Aug 23, 2008 | RCA F27442 27" TV
it can be repaired.otherwise replace tuner
Nov 25, 2007 | Sanyo DS25390 TV
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
