Question about Canon PowerShot A590 IS Digital Camera
The screen is showing that lense error.what is meant by this?and it's lens are not going inside the camera.
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Nov 14, 2010
Conon powershot A450 lens error
Try to use fresh batteries, and push the barrel in and out when it turns on to see if the 'binding' of the focusing gear can go away when you do this manipulation of the barrel.
If the error continues, maybe the camera needs service by Canonusa.com.
I could not, unfortunately, find a reference for an a450 on the website, though. Is that an older model?
Jul 29, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon 30d with tamron af 70-300mm di macro lense showing error 99
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable. Alternately, it can also be a card error or camera error.
First remove the lens, battery and card and leave the camera like that for about 30 min. After that, insert a fully charged battery and switch on the camera. If the error still shows up, it is a fault with the camera and has to be serviced.
If not, turn the camera off and insert the card. Format the card in the camera and depress the shutter button. If it shows an error, the card is faulty.
If not,
try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting.
If the error still shows up, you need to take the lens to an authorized service center.
Jul 12, 2010 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
When I turn on the camera, Lens error shows up on
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 27, 2009 | Nikon Coolpix S210 Digital Camera
Canon s1is "lens error, restart camera" appears on screen
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Dec 15, 2009 | Opteka (OPT-42XHD2-S1IS) for Canon...
Error 99 on EOS Canon 450D
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
Dec 04, 2009 | Canon EOS 450D Digital Camera
My daughter dropped her camera and and the lens is now jammed. turning it on and we see "Lens Error" on the back screen.
the error is inside the camera on its lens. it's lens can't move bec it was dislocated.you should go to the camera service center.they will be the one to open the camera & check on it.
Oct 20, 2009 | Nikon Cameras
Broken Lense
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
May 30, 2009 | Sanyo VPC-E760 Digital Camera
I Have a Canon powershot A410 and I cant get it to work anymore. The lense will not open and it beeps at me and then E18 shows up on the bottome left hand side of the screen. I can still down load all my...
The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service
Oct 21, 2008 | Canon Cameras
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
