Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Hi, on a 1015 wurlitzer (play it again 45rpm), how do I replace the front plastic side trim? and where can I purchase one? Thanks Jerry
    Champion:
  • Wurlitzer Expert
  • 211 Answers
Remove 'chrome' bands with screws in at the back. It lifts out of the front. Available from Jukeboxes Direct Sheffield UK
Posted on Jan 09, 2011
How do I replace the column GE tubes on a 1015 Wurlitzer?
HI,
Here i have added picture of Wurlitzer 1015 rear side picture. from this picture you can identify which side you have to remove to see the tubes. In th picture you can see the tubes. two out put tubes. one rectifier and two pre amp tubes(black).
Wurlitzer 1015
Jul 24, 2012 | Wurlitzer Jukebox 1015 One More Time...
I have purchased a new straight replacement bubble tube for my one mor time 1015,any idea how to fit it,seems rather difficult without removing the rotating light,does it come out?
I presume you have solved this by now. You go in from the front. Remove the three metal bands by screws in the back of the door. The front plastic comes out like a tyre, sits in a groove each side. Squeeze and pull.
Feb 18, 2012 | Wurlitzer Jukebox 1015 One More Time...
I purchased a used Wurlitzer 1015, question When selecting number 51 is a code number 82 and does not play can you explain me this, what the problem is thanks
The number of Cds in the carousel can be set on the Credit unit to stop it playing fresh air if for example you only have 50 Cds and not a whole 100. Sounds like yours is set to 50 so won't play anything over 50.
I 'think' this is what you do.
On the computer credit unit...
Service Switch ON...Press LT button.
Press 5 on the keyboard once.
Enter 0000
Service Switch off.
Press LT or turn machine off/on.
Aug 03, 2011 | Wurlitzer Jukebox 1015 One More Time...
The cover over my left oil tube is cracked, can I get a replacement ? How & where ?
I would check out the Victory Glass website at www.victoryglass.com they have a range of trims for the One More Time plastic trims, you will need to find out what manufacturer made your jukebox i.e. Wurlitzer, Rowe Ami, Rock Ola or the earlier Antique Apperatus, Sound Leisure (parts available in the UK from Sound Leisure at Leeds).
Regards
Alan Hood
ami-man
UK
Oct 01, 2010 | Wurlitzer Jukebox 1015 One More Time...
Free Play
I have the manual in stock. I can describe to you over the phone how to place it in free play mode. Please email tech@wurlitzer-ohio.com.
Jul 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
The jukebox powers up but the buttons wont work
Is this a CD player or 45RPM? Is the display lighted? What is the display showing? The answers to these questions will help narrow down the problem. For additional assistance please email Rod Stebelton, tech@wurlitzer-ohio.com.
Nov 14, 2009 | Wurlitzer Jukebox 1015 One More Time...
3400 series werlitzer 1970 jukebox
Look in the back. If you 'pop' a pin on the selector ring (press at the bottom of the small springs) so it pops up and the machine then plays o.k. then it is probably a bad contact in your keyboard leaf switches. Run a stiff piece of paper or card between the contacts to clean them.
If it doesn't play, then you have more complicated problems.
Mar 28, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 OMT Disc spins, then stops....
Spoke with "Doctor Jukebox" from Folsom, CA about a similar problem I had. You can find him on craigslist.
I did NOT have the "2222" display issue.
Root cause: The laser isn't "seeing" the CD and interprets inability to see as being the end of the track, therefore, puts the CD back into the carousel.
Solutions:
1) Clean the lens. Be careful to use an appropriate lens cleaning solution. The lens is made of plastic and may cloud up if a harsh solution is used. Use a Q-tip dipped into the cleaning solution and gently clean the lens using a side-to-side motion, not a front-to-back motion. Wait for a bit until the lens is completely dry, then try playing a CD. (note: this fixed the problem for me)
If that doesn't work...
2) Replace the laser module. It's easy to remove with a torx. Be gentle when disconnecting and reconnecting the ribbon cable and/or other connections so you don't bend the leads. Laser modules cost a few hundred dollars, so try Solution 1) above before replacing the module.
Mar 15, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
127 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
