1996 Ford Bronco Logo
Posted on Jun 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1996 Ford Bronco door lock actuator
I want to know how to install a door lock actuator. Supposedly there is a clip back in the door which the actuator clips to. Is there an easy way to put one in?
  • Anonymous Mar 29, 2014
    Back door actuator is frozen
Anonymous
Level 3:
  • Master 1,010 Answers
  • Posted on Jun 23, 2008
Anonymous
Master
Level 3:
Answers
1010
Questions
6
Helped
630812
Points
2385
These directions might sound a little goofy. I'm trying to orient your location with front and rear rather then left and right because it depends on which door you are working on. Front is towards front of rig and rear, oh I think you get it.
1. Close window on door. 2. Using a flat screw driver pop off trim under inside door handle. I think there is a groove in the plastic to which the screw driver can be inserted. Remove screw. 3. Using same screw driver pop off trim panel with door lock and window control switches. Start lifting from end located at panel closest to the front of the rig. The panel towards the back end has a pivot point which holds the back of the panel into the arm rest. Dis-connect the two switches from the trim panel. 4. Again, using flat screw driver, pop off the trim pannel located at the upper door/window frame nearest the back of the rig. Remove screw. 5. Lift up the door panel to remove. Be careful the light bulb is attached to the door panel. Rotate light socket 90 degrees and remove. 6. From the rear of the door pull back the platic stick-on barrier. Don't remove the whole thing just pull it leaving about half of it towards the front of the door stuck on. 7. Remove the one 11mm bolt, located towards the bottom of door, which holds the rearwindow guide. Don't remove the two 11mm bolts which hold the horizontal brace. Nothing else needs to be removed, leave all rods and attachments in place. They all attach the the door latch and are not of any further concern.
8. Now the easy part. The actuators and door latches are separate components. The actuator slides onto the door latch via two metal guides located on the door latch. The actuator is held into place with a plastic locking tab. The locking tab is part of the actuator housing. 9. This tab has to be pushed in to release actuator from latch. 10. Find on ouside of door - rear where the latch fingers? (I don't know what else to call them) are located in the notched door frame. At the bottom of the notch is a very narrow opening, just a ****. This **** allows access to the locking tab on the actuator. 11. Orient the screw driver in the end of the **** closest to the interior. Working on a right door, looking at the locking fingers, facing the front of the rig, your screw driver would be inserted at the left side of the ****. Pushing a flat screw driver into the **** will push the locking tab allowing the actuator to slide off the door latch. 12. A flat screw driver or other small pry tool can be inserted between the actuator and the door lock to help slide the actuator off the metal guides. The pry unit can be inserted where the rod from the interior manual door lock stem is attached. Mine had a yellow snap/flip keeper. 13. The actuator slides off from the interior towards the outside door panel. 14. Simple put pressure onto the locking tab with one screw driver and gently pry with the other one and the actuator should slide right off.
15. I picked up an actuator at a u-pull it wrecking yard for five bucks and it worked fine. Dealer wanted $90.00 and auto parts wanted $127.00. When I pulled my actuator from the wrecked rig all door panels and interior where stripped. It took me literally 20 seconds to pull the actuator. 16. To install new unit slide actuator onto door latch rails and let locking tab click into place. You might have to manually move the interior door lock stem up and down until the finger on the actuator lines up with a hole on the plastic part of the interior lock stem.
16. I Want to thank TommyRox in Texas on Ford Truck World and rivguy on automotiveforums.com for their posts.
1helpful
Need a diagram of a 2000 ford expidtion door
there should only be three rods at door latch one to door handle that has plastic locking clip one the goes from key cylinder to latch under locking clip and if power locks one to power lock actuator.
1998 ford taurus door llock actuator
More info needed. Is this a front door or a rear door? If a front door, you need to remove the plastic interior trim panel for access. With the interior panel removed, temporarily reinstall the window switch to raise the window glass. Look inside the door at the lower rear corner. You will see the lock actuator there. It's mounted on a steel U shaped bracket. It has a black rubber boot over it and a rod going up to the door latch. You may need to remove the bolt holding the steel U channel which guides the rear of the window, for improved access to the lock actuator. Unsnap the retaining clip for that rod at the latch mechanism. The U shaped bracket is riveted into the door frame. You will need a 3/16" or 1/4" cobalt drill bit [available at Ace Hardware] to drill out the retaining rivet(s). Partially remove the actuator for better access to the electrical connector. Disconnect the electrical connector and remove the actuator. Reverse this process to install the new actuator. You can use a Nyloc nut, washers and a bolt to mount the new actuator if you don't have a rivet gun and the proper sized rivet(s) to remount the new actuator.
How do I fix a rear door that qill not open the lock is off and both inside and outside handles will not work but you can here the latch move when pulling handle
remove door panel to access latch the handles are attached to the lock and actuator by rods which are held in place by plastic clips usually these clips wear down and break or become disconnected or sometimes the lock actuator can stick from rust [lube up and move back and forth usually fixes ]as to the clips any auto store usually carry replacement
2answers
Parts question
I don't know if your talking about a big bronco or a bronco ll. I'm really not sure about the difference in sheetmetal, you may have to take off the old door & match it up with the replacement door. As for the windows and locks, as long as both doors had power locks & windows, make sure the replacement door still has the window glass in the door assembly. You may want to take the time & test the motor on the new door, finally make sure your wires will connect with replacement door.
3helpful
How do you replace the regulator for the power window on the 2002 ford explorer
Regulator - Power Windows - Front Door
  1. Remove the front door trim panel as follows:
    1. Remove the front door handle bezel.
    2. Remove the front door window/lock control switch bezel.
    3. Disconnect the window/lock control switch electrical connectors.
    4. Remove the 3 front door trim panel screws.
      CAUTION To avoid damaging the trim panel, do not pull directly outward to carry out this step.
    5. Lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
    6. Remove the exterior mirror control switch from the front door trim panel.
  2. Remove the front door speaker.
  3. Remove the interior molding.
  4. Disconnect the door lock actuating rod at the door handle assembly:
    1. Release the door lock actuating rod clip.
    2. Position the door lock actuating rod aside.
  5. Remove the front door weather shield.
    CAUTION Make sure the holes in the glass bracket do not become enlarged during the rivet removal process. If the holes become enlarged, the new rivets may become loose, resulting in clicking noise concern.
    NOTE Some vehicles may use rivets to attach the window glass to the window regulator assembly. Use a 4.5 mm (0.1772 in) drill bit to drill out the glass-to-regulator rivets.
  6. Remove the 2 front door window glass-to-regulator bolts or rivets.
  7. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets.
  8. Secure the front door glass in the full up position with tape.
  9. Disconnect the window regulator motor electrical connector.
  10. Remove the 4 window regulator assembly nuts.
  11. Remove the window regulator assembly.
    Fig. Exploded view of the front door and power window components-2005 Explorer and Mountaineer
To install:
  1. Position the window regulator assembly.
  2. Install the 4 window regulator assembly nuts. Tighten to 89 inch lbs. (10 Nm).
  3. Connect the window regulator motor electrical connector.
  4. Remove the tape securing the front door glass in the full up position.
  5. Position the front door window glass as necessary to access the front door window glass-to-regulator bolts or rivets. Install the bolt and tighten the bolts to 62 inch lbs. (7 Nm), or install new rivets.
  6. Install the front door weather shield.
  7. Connect the door lock actuating rod at the door handle assembly:
    1. Position the door lock actuating rod into proper location.
    2. Attach the door lock actuating rod clip.
  8. Install the interior molding.
  9. Install the front door speaker.
  10. Install the front door trim panel as follows:
    1. Install the exterior mirror control switch from the front door trim panel.
    2. Position the door trim panel onto the armrest to engage the panel clips.
    3. Install the 3 front door trim panel screws.
    4. Connect the window/lock control switch electrical connectors.
    5. Install the front door window/lock control switch bezel.
    6. Install the front door handle bezel.
  1. Raise the front door window glass to the full up position.
  2. Remove the interior door handle.
  3. Support the front door window glass.
  4. Disconnect the front door window regulator motor electrical connector.
  5. Remove the equalizer bracket nuts.
    Fig. Remove the equalizer bracket nuts-2005 Explorer Sport-Trac
  6. Remove the front door window regulator by removing the rivets and nuts.
  7. Remove the front door window regulator motor retaining bolts and then remove the motor.
    Fig. Remove the front door window regulator motor retaining bolts and then remove the motor-2005 Explorer Sport-Trac
To install:
  1. Installation is the reverse of the removal procedure.
  2. Tighten the regulator motor mounting bolts to 8 ft. lbs. (11 Nm).
Hope this help (remember rated and comment this).
2helpful
Hello, I purchased a 1996 ford bronco xlt saturday. It has a viper alarm system & an ignition key only(does not fit the doors). It will lock you out of the vehicle & I have no other way to access...
you should be still able to use the vin to cut a new key at Ford,a locksmith is about $100.00----if not a complete lock set(2 doors,ignition and not sure about tail gate is about $75.00
2answers
The cross dock on the left side of the door on my 2003 Thunderbird broke. How do I replace it?
there is no part that i am aware of that is called a "CROSS DOCK" so to help you with this problem we need to know the correct name of the part, contact Ford parts and ID the part with the correct name
6helpful
2001 Ford Escape Rear Hatch won't unlock
The liftgate consists of the following components:
  • liftgate door lock actuator
  • liftgate lock cylinder (if equipped)
  • liftgate window glass
  • liftgate window latch/ajar switch
  • liftgate window glass release handle
  • liftgate latch remote control which consists of the following component:
    • liftgate release handle
  • liftgate latch, which consist of the following component:
    • liftgate latch door ajar switch
Liftgate Latch Actuator Removal and Installation
  1. Remove the liftgate latch remote control. For additional information, refer to Liftgate Latch Remote Control in this section.
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2001 Escape Workshop Manual
REMOVAL AND INSTALLATION Liftgate Latch Removal and Installation
  1. Remove the liftgate trim panel.
  1. Disconnect the liftgate ajar switch electrical connector.
  1. Disconnect the liftgate latch actuating rod.
    1. Open the clip.
    1. Disconnect the actuating rod.
  1. Remove and discard the liftgate latch bolts.
  1. Remove the liftgate latch.
  1. NOTE: Make sure the liftgate latch release rod is not preloading the latch. It should be clipped in a relaxed state with no slack.
    NOTE: Position the liftgate latch release rod by pushing outboard to remove the slack.
  1. Remove the screws and the liftgate latch actuator
1996 geo prizm
you'll have to pull off the interior panel. window in the up position. on the lock cylinder there is a clip that you have to pull off and an arm that actuates the lock. pop the lock out. reverse to install.
Door actuator 1991 bronco( passenger side)
you need to  take off the inside panel. if i remember correctly its just a couple screws and it should pop off.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
