Question about HP Pavilion dv6000z Notebook
I have a HP Pavilion dv6000 which has stopped working when i turn it on the blue lights come on and the fan starts up but only for a short while then the blue lights start to flash on and off but the screen stay's black, so i took the battery off and tried with just the mains although the fan cut's in and then off again the blue lights stay on but still the screen is black ..any ideas..?
  • HP Master
  • 5,660 Answers
I agree with net2005.
It is a video chip issue.
Video chip;
Chip and Chipset are slang terms for I.C.
Integrated Circuit.
http://en.wikipedia.org/wiki/Integrated_circuit
Video and graphics chip mean the same thing.
It is a GPU.
Graphics Processing Unit.
http://en.wikipedia.org/wiki/GPU
The GPU for the HP Pavilion dv6000 series of Notebook PC's, is an Nvidia GeForce 9200M GS
http://www.nvidia.com/object/product_geforce_9200m_gs_us.html
This GPU chipset does Not have pins on the bottom, and does Not sit in a socket on the motherboard.
The mounting of the chipset to the motherboard, is a surface mount called BGA.
Ball Grid Array.
The bottom of the chipset has solder balls for it's contact pins.
The area on the motherboard has small copper pads, which line up with the chipset's solder balls.
The chipset is set into position on the copper pads, and heat is used to melt the solder balls, and solder the chipset to the motherboard.
For cooling inside a laptop (Notebook), there is a Fan, and a Heatsink Assembly.
A Heatsink is typically a plate of metal, with tall, thin fins protruding from it.
The plate absorbs heat from whatever object it is placed against, and the fins absorb the heat from the plate.
The fins then radiate the heat away.
The fan pushes air over, and in-between the fins, and helps to carry the heat away.
For a laptop the Heatsink is often made of copper. There is a tube that is filled with Nitrogen, and connects to the Heatsink.
> Cooling Tube.
On the end away from the Heatsink on the Cooling Tube, there is a plate.
This plate sits on top of the Processor.
>Fan/Heatsink Assembly
There is also be a plate on top of the GPU chipset, connected to the Cooling Tube.
The Processor and GPU chipset are the two hottest chipsets operating inside a computer.
Laptop or Desktop.
Because there is not enough cooling provided for the GPU chipset, it becomes so hot that it partially melts the solder connections, in the BGA surface mount.
Poor connections to the GPU chipset, is what you are seeing with your laptop.
Here is a video on Youtube describing one solution to fix the problem.
It also states that there is a recall from HP.
(I would use a Heatgun instead of a torch)
http://www.youtube.com/watch?v=bnkQNmKauEc
To add:
1) With the heat involved inside a laptop the Thermal Paste often dries up.
Sometimes there was no Thermal Paste applied to the top of the GPU chipset, from the factory.
The Thermal Paste on the top of the Processor (Case), and the Thermal Paste on top of the GPU chipset, should ALWAYS be removed, and replaced when the Fan/Heatsink Assembly is removed.
Thermal Paste is cheap. It's a GOOD idea to replace it.
Need to know the CORRECT procedure, please state in a Comment.
2) ALWAYS follow Anti-Static Precautions when working on a laptop.
Suggest you buy, and wear an ESD wrist strap, and connect the alligator clip to a good ground source
3) Use a multi-compartment container for the various screws you will remove.
Mark each compartment for the area the screws come out of.
DO NOT mix them up!
4) Make notes and drawings as you disassemble.
It's nice to have a record to refer back to, in case you get interrupted.
Regards,
joecoolvette
Posted on Nov 24, 2010
Describe your HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook Problem SCREEN WONT TURN ON LED LIGHTS OF POWER BUTTON...
The dv6000 series was commonly affected by the video card heating up and reseating itself. This was usually a soldering issue. You have a few options, You can either replace the motherboard, or have the motherboard reflowed. Unfortunately the video card itself is not detachable or individually replaceable.
I personally would recommend the second option as purchasing another dv6000 board will likely end you up in the same situation a year or 2 later.
A repair / reflow services on ebay
Dv6000 Repair
This repair tech only does amd processor models, Not intel.
Hope this helps.
Aug 29, 2011 | HP Pavilion dv6000z Notebook
My "hp pavilion a220n" won't
Check all wires for loose connections--- if the memory was wrong or something, it would still attempt to boot but stop during the POST and start to beep
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
Ive had the same problem with my laptop, one day it just stopped charging. I would put in the charger and the blue light on the side would either be very dim or not show the blue light. I had to either...
If you have multimeter then check the output voltage of the charger, if charger is not working then replace it, if charger is working then there must be a problem with mother board, try to contact some reliable repairing engineer.
Regards;
Hasan
Dec 30, 2009 | HP Pavilion dv6000z Notebook
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Hp Pavilion dv6000 Won't start
If you have'nt done any upgrades like windows or memory
I think you just need a new fan
possibly power supply
if you take it to a small pc shop they will test power and fan for you usually on the spot at little or no cost
please don't forget to rate me
Feb 04, 2009 | HP Pavilion dv6000z Notebook
AUTO SHUT OFF HP DV6000
Youre cpu heatsink is clogged with dust not breathing properly and causing it to over heat and shut down.Must remove keyboard heat sink should be on top right removed heat sink and clean dust .Use air can and spray whole laptop.
Oct 02, 2008 | HP Pavilion dv6000z Notebook
My HP Pavilion dv6000 the wireless connection stopped working and the light does not go blue to connect to internet. This happened 2 days ago. I can connect using a cable.
Check if it is only a software problem. Usually the blue light indicator functions with the physical slider switch. So even it is disabled in the network properties the indicator still lights when the physical switch is at "on" position.
Sep 25, 2008 | Computers & Internet
Hp pavilion dv6000
This is a manufacturer trouble.
Starts with WiFi troubles, then no screen and no start with 1 long and 2 short beeps.
Here are those who came with same problem>
http://www.tabletquestions.com/notebooks/53305-hpdv6000-beep-codes-no-display-startup.html
Hp resolve this problem by changing the mainboard on good warranty notebooks
i have the same problem but can\t go to the supplier, had no warranty.
icq 475653626
Sep 01, 2007 | HP Pavilion dv9205us Notebook
HP Pavilion dv6000z Notebook Logo
406 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
