Question about Kitchen Ranges
I HAVE A BOSCH DISHWASHER THAT IS ABOUT 8 YEARS OLD. LAST WEEK AS IT WAS RUNNING I SMELLED SMOKE AND THERE WAS SMOKE COMING OUT OF THE CONTROL PANEL. IT SMELLED LIKE A ELECTICAL FIRE. I HIT THE BREAKER SWITCH, BUT MY HOUSE SMELLED LIKE BURNED WIRE.
  • 4,323 Answers
Hi
The issue is with the control panel that is bad, smell of burned wire and the smoke coming out of the control panel means that there was a short inside it. Before you replace the control, please check the wire connections to the control and the power plug to the unit. Hope this helps...please post back for further assistance.
Daniel
Posted on Nov 14, 2010
Dell Dimension 4400 NEVER froze (8-9 years old) until a week ago - kept freezing at start-up - - had to interrupt power SEVERAL times to restart - - tried to power up yesterday - - make a slight sound,...
You need a power supply! Go to Amazon and search for one that is the same specs as yours. Fairly easy to replace, don't use your old one anymore, it could be dangerous.
May 05, 2011 | Dell Dimension 4400 Power Supply ** FREE...
My bosch dishwasher model shu33a keeps running.At first the sanitized light would not light now it just keeps running and when i open the door its not real hot like before..the washer is only 3 years old.
change the control module. check to see if there is a recall on this module. bosch will tell you if it is.give them model # and serial #. by the way if the modell is arecall you will get a free fix. let me know if this info helps,
Feb 23, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
We have a Bosch shu33 it started running a longer cycle& no longer shows the sanitized light
I got answer from previous post on your site by 'boeschbrady'.Person had same problem,also said part was under Warranty. we called the store where unit was purchased and my unit is also under Warranty "less than 5 years old' repair man is coming next week.Thank you for a
great site Patee
Jan 11, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
My dishwasher is not draining
have you checked your float valve and float relay switch
Oct 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher smoking
I would shut down the circuit and open the door. Remove the lower basket and inspect/feel the heating element for breaks/"bumps"
I bet you will find that it is damaged and needs to be replaced. Not a real hard task with tools and patience.
Please report back what you find/do, OK?
Apr 13, 2009 | Dishwashers
Kenmore Elite 17483 Dishwasher Caught Fire!
Had the exact same problem (Control panel burning up, sparking, and smoking during wash cycle) last night with our Kenmore Elite DW model 665.16293400 purchased Nov. 2004. I have reported it to the CPSC and www.kitchenaidfire.com and will be contacting Sears first thing tomorrow. It is outrageous that this problem is apparently so widespread with nothing being done about it! I have no doubt my kitchen would have been in flames if I had not been sitting right here to shut off power to the D/W.
Feb 04, 2009 | Kenmore 24 in. 17483 Built-in Dishwasher
No water coming into machine. Programme not running because the machine is still trying to fill. If I add water the machine does drain. Was cleaned with a good dishwasher cleaner only last week. Nothing to...
Turns out that the dishwasher had a leak in the bottom. No water could be seen leaking out because Bosch machines have a cut-off valve that means if a tray in the bottom of the machine fills up with water, the float valve doesn't allow anymore water into the machine. we worked this out after we tipped the machine slightly, water ran out, when we put it back down and started it the inlet valve worked until the bottom had filled with water again.
New machine for us! However, not a critism of Bosch. We use our machine at least two or three times a day and have done for the last 5 years.
Sep 09, 2008 | Dishwashers
Bosch Dishwasher leaking
I had the same problem it turned out that the upper rack was not being pushed back all the way so the door was slightly ajar. If you open the door you should see a bit of water going past the seal If the door is not seating.
Henry in Toronto
Jun 30, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Dishwasher Classix
Had similar problem on my Siemens which is the same as Bosh. I started to take it apart to see what had gone wrong. Eventually I had to disconnect the cable going into the washer - its in a small box at the front at the bottom. The wire nut connectors had melted and shorted out. Unfortunately now it won't fill with water. The smell was not like wood so maybe a different problem.
Mar 21, 2008 | Dishwashers
Kitchen Ranges Logo
47 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
