Question about Samsung DMR57LF Builtin Dishwasher
My Samsung dishwasher has a error code 4E after i start it up could you please let met know what this means thanks
Most common error codes that are caused by installation errors are:
  • 4E. If your dishwasher is displaying error code 4E, it can be caused by the water supply valve. The water supply valve may be closed, or not fully open. Most water supply valves are not frequently opened or closed. Because of this, they may be difficult to turn. To make sure this is not your issue, turn the supply valve to the fully closed position, clockwise, and then turn the valve to the fully open position, counterclockwise.
    • Check your water pressure. Your dishwasher requires a minimum of 20 psi and a maximum of 120 psi.
    • Water filtration info.
Posted on Jan 21, 2011
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What does the error code ER5 for a EDW154E Eurotech D/W mean?
    e5 error is drain error. need to check all drain related items.
    drain pump, drain hose, and of course garbage disposal knock out.
    Jun 06, 2014 | EuroTech 24 in. EDW154E Built-in...
    How do we fix an error code "4e"
    What we do is we call the washing machine agent for Samsung Washing Machines and be ready to spend some money to have it fixed.
    That is why they put the "self-testing' feature into the machines electronics. It really does not matter for the user to know what the code might mean. At best it is only a preliminary guide to the Technician as to the possible root main cause and who may well find other things on your machine that are in need of attention. some Preventive Maintenance might save you lots of inconvenience and cost in the future if you have it attended to at the same time.
    Be smart !...........Get the Samsung Guy or Gal out to look at it !
    May 19, 2014 | Samsung Washing Machines
    Error code E3 on Samsung DMS500TRW dishwasher
    3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
    Apr 14, 2014 | Dishwashers
    SAMSUNG J1253 ERROR CODE 4E
    Did you leave out the complete model number?, If you haven't yet check your water supply, If you changed to or have the auto stop flood hoses some washers cause them to activate.
    The wires may be disconnected on the water valve(s) or a valve went bad or the main board went bad, You can use a meter to check that there is voltage going to the valve(s) when you start a fill cycle, Also some washers use a flow meter that checks water flow.
    May 03, 2017 | Samsung Washing Machines
    Samsung DMR77LHS Tall Tub Dishwasher displays HE code (flashing) and does not finish the cycle. I am very handy and would like to repair this myself. so as much detail as possible is appreciated.
    EE1/HE/HE1
  • The EE and HE codes refer to temperature errors. The EE1 designation refers to a thermistor issue, and the HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
  • 4E/4E1
  • The 4E codes indicate a problem with the water supply. If you see the 4E code, make sure the water supply line is correctly attached and open and not frozen or clogged. If you get a 4E1 code, check the temperature of the incoming water supply and ensure that it is below 176 degrees. If either of these issues persist despite your best efforts, contact a repair center.
  • 5E
  • The 5E code means there is a problem with the drain. Make sure the drain hose and openings are not clogged or obstructed. If they are not, and the code remains, disconnect the circuit breaker to reduce the risk of electric shock and contact a service center.
  • oE/9E
  • The oE and 9E codes refer to issues with the water level. The oE code means that the dishwasher is filling too much, and the 9E code means it is not filling enough. Disconnect the circuit breaker for safety and contact a repair center.
  • LE
  • The LE code indicates a leak. To keep from voiding your warranty, do not attempt to diagnose and repair the leak yourself. Close the water supply valve and disconnect the circuit breaker to avoid electric shock and contact a repair technician.
  • 6E2/PE
  • The 6E2 and PE codes both indicate functional errors that must be repaired by a professional. The 6E2 code indicates a pressed key error, and the PE code refers to a problem with the half-load function. Disconnect the circuit breaker in either case and contact a repair service.
  • Jan 14, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    My dishwasher model number dmr77lhb is showing error code le and there are no apparent external water leaks how can I rest
    I fixed mine by pulling out the unit then flipping over to access the white tray that covers the bottom of the unit. Remove this then dry it out...there's a sensor in there that triggers the LE code. It could be a leak but in most cases it's just built up condensation. EE1/HE/HE1
  • 4E/4E1
  • 5E
  • oE/9E
  • LE
  • 6E2/PE
  • Jan 10, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    Samsung DMR57LF Builtin Dishwasher Logo
    3,308 people viewed this question
    Top Samsung Dishwashers Experts
    Dale Copeland
    Dale Copeland
    Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
